RTEMS 6.2
RTEMS Run-Time Linker Object Support. More...
#include <rtems.h>#include <rtems/chain.h>#include <rtems/rtl/rtl-sym.h>#include <rtems/rtl/rtl-unresolved.h>Go to the source code of this file.
| struct | rtems_rtl_loader_format |
| struct | rtems_rtl_loader_table |
| struct | rtems_rtl_obj_sect |
| struct | rtems_rtl_obj_depends |
| struct | rtems_rtl_obj |
Typedefs | |
| typedef struct rtems_rtl_loader_format | rtems_rtl_loader_format |
| typedef bool(* | rtems_rtl_loader_check) (rtems_rtl_obj *obj, int fd) |
| typedef bool(* | rtems_rtl_loader_load) (rtems_rtl_obj *obj, int fd) |
| typedef bool(* | rtems_rtl_loader_unload) (rtems_rtl_obj *obj) |
| typedef rtems_rtl_loader_format *(* | rtems_rtl_loader_sig) (void) |
| typedef struct rtems_rtl_loader_table | rtems_rtl_loader_table |
| typedef bool(* | rtems_rtl_obj_depends_iterator) (rtems_rtl_obj *obj, rtems_rtl_obj *dependent, void *data) |
| typedef bool(* | rtems_rtl_obj_sect_handler) (rtems_rtl_obj *obj, int fd, rtems_rtl_obj_sect *sect, void *data) |
| #define RTEMS_RTL_FMT_ELF (1 << 0) |
Loader format flags.
| #define RTEMS_RTL_OBJ_BASE (1 << 2) |
The base image.
| #define RTEMS_RTL_OBJ_CTOR_RUN (1 << 5) |
Constructors have been called.
| #define RTEMS_RTL_OBJ_DEP_VISITED (1 << 4) |
Dependency loop detection.
| #define RTEMS_RTL_OBJ_LOCKED (1 << 0) |
Object file descriptor flags. Lock the object file so it cannot be unloaded.
| #define RTEMS_RTL_OBJ_RELOC_TAG (1 << 3) |
Tag the object as visited when reloc parsing.
| #define RTEMS_RTL_OBJ_SECT_ALLOC (1 << 10 |
Section allocates runtime memory.
| #define RTEMS_RTL_OBJ_SECT_ARCH_ALLOC (1 << 19) |
Section use arch allocator.
| #define RTEMS_RTL_OBJ_SECT_BSS (1 << 3) |
Section holds program bss.
| #define RTEMS_RTL_OBJ_SECT_CONST (1 << 1) |
Section holds program text.
| #define RTEMS_RTL_OBJ_SECT_CTOR (1 << 16) |
Section contains constructors.
| #define RTEMS_RTL_OBJ_SECT_DATA (1 << 2) |
Section holds program data.
| #define RTEMS_RTL_OBJ_SECT_DTOR (1 << 17) |
Section contains destructors.
| #define RTEMS_RTL_OBJ_SECT_EH (1 << 4) |
Section holds exception data.
| #define RTEMS_RTL_OBJ_SECT_EXEC (1 << 13) |
Section is executable.
| #define RTEMS_RTL_OBJ_SECT_LINK (1 << 15) |
Section is link-ordered.
| #define RTEMS_RTL_OBJ_SECT_LOAD (1 << 11) |
Section is loaded from object file.
| #define RTEMS_RTL_OBJ_SECT_LOCD (1 << 18) |
Section has been located.
| #define RTEMS_RTL_OBJ_SECT_REL (1 << 6) |
Section holds relocation recs.
| #define RTEMS_RTL_OBJ_SECT_RELA (1 << 7) |
Section holds reloc addend recs.
| #define RTEMS_RTL_OBJ_SECT_STR (1 << 9) |
Section holds strings.
| #define RTEMS_RTL_OBJ_SECT_SYM (1 << 8) |
Section holds symbols.
| #define RTEMS_RTL_OBJ_SECT_TEXT (1 << 0) |
Flags for the various section types. Section holds program text.
| #define RTEMS_RTL_OBJ_SECT_TLS (1 << 5) |
Section holds TLS data.
| #define RTEMS_RTL_OBJ_SECT_TYPES |
Section types mask.
| #define RTEMS_RTL_OBJ_SECT_WRITE (1 << 12) |
Section is writable, ie data.
| #define RTEMS_RTL_OBJ_SECT_ZERO (1 << 14) |
Section is preset to zero.
| #define RTEMS_RTL_OBJ_UNRESOLVED (1 << 1) |
The object file has unresolved external symbols.
| typedef bool(* rtems_rtl_loader_check) (rtems_rtl_obj *obj, int fd) |
The type of the format loader check handler. This handler checks the format and if it is detected as suitable it returns true.
| typedef struct rtems_rtl_loader_format rtems_rtl_loader_format |
Loader format definition.
| typedef bool(* rtems_rtl_loader_load) (rtems_rtl_obj *obj, int fd) |
The type of the format loader load handler. This handler loads the specific format.
| typedef rtems_rtl_loader_format *(* rtems_rtl_loader_sig) (void) |
The type of the format loader signature handler. This handler checks the format signature.
| typedef struct rtems_rtl_loader_table rtems_rtl_loader_table |
Table for supported loadable formats.
| typedef bool(* rtems_rtl_loader_unload) (rtems_rtl_obj *obj) |
The type of the format loader unload handler. This handler unloads the specific format.
| typedef bool(* rtems_rtl_obj_depends_iterator) (rtems_rtl_obj *obj, rtems_rtl_obj *dependent, void *data) |
Dependency iterator.
| typedef bool(* rtems_rtl_obj_sect_handler) (rtems_rtl_obj *obj, int fd, rtems_rtl_obj_sect *sect, void *data) |
A section handler is called once for each section that needs to be processed by this handler. The handler is specific to a task.
| obj | The object file's descriptor the section belongs too. |
| fd | The file descriptor of the object file beling loaded. |
| sect | The section the handler is being invoked to handle. |
| data | A user supplied data variable. |
| true | The operation was successful. |
| false | The operation failed and the RTL has been set. |
| bool rtems_rtl_obj_add_dependent | ( | rtems_rtl_obj * | obj, |
| rtems_rtl_obj * | dependent | ||
Add an object file to the dependents table.
| obj | The object file's descriptor. |
| dependent | The dependent object file to add. |
| true | The dependent has been added to the table. |
| false | There is no space in the table. |
| bool rtems_rtl_obj_add_section | ( | rtems_rtl_obj * | obj, |
| int | section, | ||
| const char * | name, | ||
| size_t | size, | ||
| off_t | offset, | ||
| uint32_t | alignment, | ||
| int | link, | ||
| int | info, | ||
| uint32_t | flags | ||
Add a section to the object descriptor.
| section | The section's index number. |
| name | The name of the section. |
| size | The size of the section in memory. |
| offset | The offset of the section in the object file. |
| alignment | The alignment of the section in memory. |
| link | The section's link field (from the ELF format). |
| info | The section's info field (from the ELF format). |
| flags | The section's flags. |
| true | The section has been added. |
| false | The section has not been added. See the RTL error. |
| rtems_rtl_obj * rtems_rtl_obj_alloc | ( | void | ) |
Allocate an object structure on the heap.
| NULL | No memory for the object. |
| bool rtems_rtl_obj_alloc_dependents | ( | rtems_rtl_obj * | obj, |
| size_t | dependents | ||
Allocate a table for dependent objects.
| dependents | The size of the table. |
| true | The table was allocated. |
| false | The alloction failed. |
| bool rtems_rtl_obj_alloc_sections | ( | rtems_rtl_obj * | obj, |
| int | fd, | ||
| rtems_rtl_obj_sect_handler | handler, | ||
| void * | data | ||
Allocate the sections. If a handler is provided (not NULL) it is called for all section.
| fd | The object file's file descriptor. |
| handler | The object file's format specific allocation handler. |
| data | User specific data handle. |
| true | The object has been sucessfully loaded. |
| false | The load failed. The RTL error has been set. |
| uint32_t rtems_rtl_obj_bss_alignment | ( | const rtems_rtl_obj * | obj | ) |
The bss section alignment for the object file. Only use once all the sections has been added. The section alignment is the alignment of the first bss type section loaded the bss section.
You can assume the alignment is a positive integral power of 2 if not 0 or
| size_t rtems_rtl_obj_bss_size | ( | const rtems_rtl_obj * | obj | ) |
The bss section size. Only use once all the sections has been added. It includes alignments between sections that are part of the object's bss area.
| uint32_t rtems_rtl_obj_const_alignment | ( | const rtems_rtl_obj * | obj | ) |
The const section alignment for the object file. Only use once all the sections has been added. The section alignment is the alignment of the first const type section loaded the const section.
| size_t rtems_rtl_obj_const_size | ( | const rtems_rtl_obj * | obj | ) |
The const section size. Only use once all the sections has been added. It includes alignments between sections that are part of the object's const area. The consts sections are included in this section.
| bool rtems_rtl_obj_ctors_to_run | ( | rtems_rtl_obj * | obj | ) |
Does the object have constructors to run?
| uint32_t rtems_rtl_obj_data_alignment | ( | const rtems_rtl_obj * | obj | ) |
The data section alignment for the object file. Only use once all the sections has been added. The section alignment is the alignment of the first data type section loaded the data section.
| size_t rtems_rtl_obj_data_size | ( | const rtems_rtl_obj * | obj | ) |
The data section size. Only use once all the sections has been added. It includes alignments between sections that are part of the object's data area.
| void rtems_rtl_obj_dec_reference | ( | rtems_rtl_obj * | obj | ) |
Decrement the object file reference count.
| bool rtems_rtl_obj_dtors_to_run | ( | rtems_rtl_obj * | obj | ) |
Does the object have destructors to run?
| uint32_t rtems_rtl_obj_eh_alignment | ( | const rtems_rtl_obj * | obj | ) |
The eh section alignment for the object file. Only use once all the sections has been added. The section alignment is the alignment of the first bss type section loaded the bss section.
| size_t rtems_rtl_obj_eh_size | ( | const rtems_rtl_obj * | obj | ) |
The eh section size. Only use once all the sections has been added. It includes alignments between sections that are part of the object's bss area.
| void rtems_rtl_obj_erase_dependents | ( | rtems_rtl_obj * | obj | ) |
Erase the object file descriptor's dependents.
| void rtems_rtl_obj_erase_sections | ( | rtems_rtl_obj * | obj | ) |
Erase the object file descriptor's sections.
| bool rtems_rtl_obj_find_file | ( | rtems_rtl_obj * | obj, |
| const char * | name | ||
Find an object file on disk that matches the name. The object descriptor is fill in with the various parts of a name. A name can have archive, object file and offset components. The search path in the RTL is searched.
| name | The name to locate on disk. |
| true | The file has been found. |
| false | The file could not be located. The RTL error has been set. |
| rtems_rtl_obj_sect * rtems_rtl_obj_find_section | ( | const rtems_rtl_obj * | obj, |
Find the section given a name.
| name | The name of the section to find. |
| NULL | The section was not found. |
| rtems_rtl_obj_sect * rtems_rtl_obj_find_section_by_index | ( | const rtems_rtl_obj * | obj, |
| int | index | ||
Find a section given a section's index number.
| index | The section's index to find. |
| rtems_rtl_obj_sect * rtems_rtl_obj_find_section_by_mask | ( | const rtems_rtl_obj * | obj, |
| int | index, | ||
| uint32_t | mask | ||
Find a section given a section's mask. The index is the section after which the mask is matched. An index of -1 starts the search from the beginning of the section list. You can find multiple matches for a mask by passing the index of the last section that matched the mask on a subsequent call.
| index | The section's index to start searching from, -1 for the start. |
| mask | The section's mask to match against the section's flags. |
| bool rtems_rtl_obj_free | ( | rtems_rtl_obj * | obj | ) |
Free the object structure and related resources.
| obj | The object file's descriptor to free. |
| false | The object has dependences. |
| true | The object has been freed. |
| size_t rtems_rtl_obj_get_reference | ( | rtems_rtl_obj * | obj | ) |
Get the object file reference count.
| int | The object file's reference count. |
| void rtems_rtl_obj_inc_reference | ( | rtems_rtl_obj * | obj | ) |
Increment the object file reference count.
| bool rtems_rtl_obj_iterate_dependents | ( | rtems_rtl_obj * | obj, |
| rtems_rtl_obj_depends_iterator | iterator, | ||
| void * | data | ||
Iterate over the module dependenices.
| handler | The iterator handler. Returns true to end. |
| data | User data passed to the iterator. |
| true | The iterator handler returned true. |
| false | The iterator handler returned false. |
| bool rtems_rtl_obj_load | ( | rtems_rtl_obj * | obj | ) |
Load the object file, reading all sections into memory, symbols and performing any relocation fixups.
| true | The object file has been loaded. |
| bool rtems_rtl_obj_load_sections | ( | rtems_rtl_obj * | obj, |
| int | fd, | ||
| void * | data | ||
Load the sections that have been allocated memory in the target. The bss type section does not load any data, it is set to 0. The text and data sections read the detault data from the object file into the target memory.
| handler | The object file's format specific load handler. |
| bool rtems_rtl_obj_load_symbols | ( | rtems_rtl_obj * | obj, |
| int | fd, | ||
| void * | data | ||
Load the symbols from the object file. Only the exported or public symbols are read into memory and held in the global symbol table.
| handler | The object file's format specific symbol handler. |
| true | The object file's symbol where loaded. |
| false | The symbol loading failed. The RTL error is set. |
| bool rtems_rtl_obj_orphaned | ( | rtems_rtl_obj * | obj | ) |
Is the object file orphaned? An orphaned object file is not locked, has no users and it not being referenced.
| bool rtems_rtl_obj_relocate | ( | rtems_rtl_obj * | obj, |
| int | fd, | ||
| void * | data | ||
Relocate the object file. The object file's section are parsed for any relocation type sections.
| handler | The object file's format specific relocation handler. |
| true | The object file was relocated. |
| false | The relocation failed. The RTL error is set. |
| bool rtems_rtl_obj_relocate_unresolved | ( | rtems_rtl_unresolv_reloc * | reloc, |
| rtems_rtl_obj_sym * | sym | ||
Relocate an object file's unresolved reference.
| rec | The unresolved relocation record. |
| sym | The unresolved relocation's referenced symbol. |
| true | The object file record was relocated. |
| bool rtems_rtl_obj_remove_dependencies | ( | rtems_rtl_obj * | obj | ) |
Remove dependencies. This decrements the dependent object file references.
| true | The dependencies have been removed. |
| bool rtems_rtl_obj_resize_sections | ( | rtems_rtl_obj * | obj | ) |
Resize the sections.
| void rtems_rtl_obj_run_ctors | ( | rtems_rtl_obj * | obj | ) |
Invoke the constructors the object has. Constructors are a table of pointers to "void (*)(void);" where NULL pointers are skipped. The table's size is taken from the section's size. The objet ELF specific code is responisble for flagging which sections contain constructors.
| void rtems_rtl_obj_run_dtors | ( | rtems_rtl_obj * | obj | ) |
Invoke the destructors the object has. Destructors are a table of pointers to "void (*)(void);" where NULL pointers are skipped. The table's size is taken from the section's size. The objet ELF specific code is responisble for flagging which sections contain destructors.
| void rtems_rtl_obj_synchronize_cache | ( | rtems_rtl_obj * | obj | ) |
Synchronize caches to make code visible to CPU(s)
| uint32_t rtems_rtl_obj_text_alignment | ( | const rtems_rtl_obj * | obj | ) |
The text section alignment for the object file. Only use once all the sections has been added. The section alignment is the alignment of the first text type section loaded the text section.
| size_t rtems_rtl_obj_text_size | ( | const rtems_rtl_obj * | obj | ) |
The text section size. Only use once all the sections has been added. It includes alignments between sections that are part of the object's text area. The consts sections are included in this section.
| uint32_t rtems_rtl_obj_tramp_alignment | ( | const rtems_rtl_obj * | obj | ) |
The trampolinme alignment for the architecture.
This is implemented and set in the architecture backend.
| size_t rtems_rtl_obj_tramp_size | ( | const rtems_rtl_obj * | obj | ) |
The trampoline size.
| bool rtems_rtl_obj_unload | ( | rtems_rtl_obj * | obj | ) |
Unload the object file, erasing all symbols and releasing all memory.
| true | The object file has been unloaded. |
| false | The unload failed. The RTL error has been set. |
| bool rtems_rtl_obj_unresolved | ( | rtems_rtl_obj * | obj | ) |
Does the object file have unresolved external references ? If it does the results of executing code is unpredictable.
| true | The object file has unresolved externals. |
| false | The object file has all external references resolved. |
| bool rtems_rtl_parse_name | ( | const char * | name, |
| const char ** | aname, | ||
| const char ** | oname, | ||
| off_t * | ooffset | ||
Parses a filename and returns newly allocated strings with the archive name, object name, and the object's offset
| name | The filename of the object |
| aname | Address of a string pointer that holds the archive name |
| oname | Address of a string pointer that holds the object name |
| ooffset | Address of an int that holds the object offset |
| true | The parsing was successful |
| false | The parsing was unsuccessful |
