RTEMS 6.2
rtl Directory Reference
file  dlfcn-shell.h [code]
file  rap-shell.h [code]
file  rap.h [code]
 RTEMS Application Loader.
file  rtl-allocator.h [code]
 RTEMS Run-Time Linker Allocator.
file  rtl-archive.h [code]
 RTEMS Run-Time Linker Archive.
file  rtl-fwd.h [code]
 RTEMS Run-Time Linker ELF Headers.
file  rtl-indirect-ptr.h [code]
 RTEMS Run-Time Linker Indirect Pointer Management allows memory compaction in the allocator.
file  rtl-obj-cache.h [code]
 RTEMS Run-Time Linker Object File cache buffers a section of the object file in a buffer to localise read performance.
file  rtl-obj-comp.h [code]
 RTEMS Run-Time Linker Object File Compression manages a compressed stream of data.
file  rtl-obj-fwd.h [code]
file  rtl-obj.h [code]
 RTEMS Run-Time Linker Object Support.
file  rtl-shell.h [code]
 RTEMS Run-Time Linker ELF Shell Support.
file  rtl-sym.h [code]
 RTEMS Run-Time Linker Object File Symbol Table.
file  rtl-trace.h [code]
 RTEMS Run-Time Linker ELF Trace Support.
file  rtl-unresolved.h [code]
 RTEMS Run-Time Linker Object File Unresolved Relocations Table.
file  rtl.h [code]
 RTEMS Run-Time Linker.
