RTEMS 6.2
Src
Driver version
enum  _src_reset_status_flags {
  kSRC_WarmBootIndicationFlag = SRC_SRSR_WBI_MASK , kSRC_TemperatureSensorResetFlag = SRC_SRSR_TSR_MASK , kSRC_JTAGSoftwareResetFlag = SRC_SRSR_SJC_MASK , kSRC_JTAGGeneratedResetFlag = SRC_SRSR_JTAG_MASK ,
  kSRC_WatchdogResetFlag = SRC_SRSR_WDOG_MASK
 SRC reset status flags. More...
enum  _src_warm_reset_bypass_count { kSRC_WarmResetWaitAlways = 0U , kSRC_WarmResetWaitClk16 = 1U , kSRC_WarmResetWaitClk32 = 2U , kSRC_WarmResetWaitClk64 = 3U }
 Selection of WARM reset bypass count. More...
typedef enum _src_warm_reset_bypass_count src_warm_reset_bypass_count_t
void SRC_ClearResetStatusFlags (SRC_Type *base, uint32_t flags)
 Clear the status flags of SRC.
#define FSL_SRC_DRIVER_VERSION   (MAKE_VERSION(2, 0, 1))
 SRC driver version 2.0.1.
Typedef Documentation
◆ src_warm_reset_bypass_count_t
This type defines the 32KHz clock cycles to count before bypassing the MMDC acknowledge for WARM reset. If the MMDC acknowledge is not asserted before this counter is elapsed, a COLD reset will be initiated.
◆ _src_reset_status_flags
WARM boot indication shows that WARM boot was initiated by software.
Indicates whether the reset was the result of software reset from on-chip Temperature Sensor. Temperature Sensor Interrupt needs to be served before this bit can be cleaned.
Indicates whether the reset was the result of setting SJC_GPCCR bit 31.
Indicates a reset has been caused by JTAG selection of certain IR codes: EXTEST or HIGHZ.
Indicates a reset has been caused by the watchdog timer timing out. This reset source can be blocked by disabling the watchdog.
◆ _src_warm_reset_bypass_count
System will wait until MMDC acknowledge is asserted.
Wait 16 32KHz clock cycles before switching the reset.
Wait 32 32KHz clock cycles before switching the reset.
Wait 64 32KHz clock cycles before switching the reset.
◆ SRC_ClearResetStatusFlags()
void SRC_ClearResetStatusFlags ( SRC_Type base,
uint32_t  flags
Parameters
baseSRC peripheral base address.
flagsvalue of status flags to be cleared, see to _src_reset_status_flags.
brief Clear the status flags of SRC.
param base SRC peripheral base address. param Mask value of status flags to be cleared, see to _src_reset_status_flags.
