RTEMS 6.2
Macros | Enumerator
Ksdk_common
#define FSL_DRIVER_TRANSFER_DOUBLE_WEAK_IRQ   1
 Macro to use the default weak IRQ handler in drivers.
#define MAKE_STATUS(group, code)   ((((group)*100L) + (code)))
 Construct a status code value from a group and code number.
#define MAKE_VERSION(major, minor, bugfix)   (((major)*65536L) + ((minor)*256L) + (bugfix))
 Construct the version number for drivers.
Driver version
enum  _status_groups {
  kStatusGroup_Generic = 0 , kStatusGroup_FLASH = 1 , kStatusGroup_LPSPI = 4 , kStatusGroup_FLEXIO_SPI = 5 ,
  kStatusGroup_DSPI = 6 , kStatusGroup_FLEXIO_UART = 7 , kStatusGroup_FLEXIO_I2C = 8 , kStatusGroup_LPI2C = 9 ,
  kStatusGroup_UART = 10 , kStatusGroup_I2C = 11 , kStatusGroup_LPSCI = 12 , kStatusGroup_LPUART = 13 ,
  kStatusGroup_SPI = 14 , kStatusGroup_XRDC = 15 , kStatusGroup_SEMA42 = 16 , kStatusGroup_SDHC = 17 ,
  kStatusGroup_SDMMC = 18 , kStatusGroup_SAI = 19 , kStatusGroup_MCG = 20 , kStatusGroup_SCG = 21 ,
  kStatusGroup_SDSPI = 22 , kStatusGroup_FLEXIO_I2S = 23 , kStatusGroup_FLEXIO_MCULCD = 24 , kStatusGroup_FLASHIAP = 25 ,
  kStatusGroup_FLEXCOMM_I2C = 26 , kStatusGroup_I2S = 27 , kStatusGroup_IUART = 28 , kStatusGroup_CSI = 29 ,
  kStatusGroup_MIPI_DSI = 30 , kStatusGroup_SDRAMC = 35 , kStatusGroup_POWER = 39 , kStatusGroup_ENET = 40 ,
  kStatusGroup_PHY = 41 , kStatusGroup_TRGMUX = 42 , kStatusGroup_SMARTCARD = 43 , kStatusGroup_LMEM = 44 ,
  kStatusGroup_QSPI = 45 , kStatusGroup_DMA = 50 , kStatusGroup_EDMA = 51 , kStatusGroup_DMAMGR = 52 ,
  kStatusGroup_FLEXCAN = 53 , kStatusGroup_LTC = 54 , kStatusGroup_FLEXIO_CAMERA = 55 , kStatusGroup_LPC_SPI = 56 ,
  kStatusGroup_LPC_USART = 57 , kStatusGroup_DMIC = 58 , kStatusGroup_SDIF = 59 , kStatusGroup_SPIFI = 60 ,
  kStatusGroup_OTP = 61 , kStatusGroup_MCAN = 62 , kStatusGroup_CAAM = 63 , kStatusGroup_ECSPI = 64 ,
  kStatusGroup_USDHC = 65 , kStatusGroup_LPC_I2C = 66 , kStatusGroup_DCP = 67 , kStatusGroup_MSCAN = 68 ,
  kStatusGroup_ESAI = 69 , kStatusGroup_FLEXSPI = 70 , kStatusGroup_MMDC = 71 , kStatusGroup_PDM = 72 ,
  kStatusGroup_SDMA = 73 , kStatusGroup_ICS = 74 , kStatusGroup_SPDIF = 75 , kStatusGroup_LPC_MINISPI = 76 ,
  kStatusGroup_HASHCRYPT = 77 , kStatusGroup_LPC_SPI_SSP = 78 , kStatusGroup_I3C = 79 , kStatusGroup_LPC_I2C_1 = 97 ,
  kStatusGroup_NOTIFIER = 98 , kStatusGroup_DebugConsole = 99 , kStatusGroup_SEMC = 100 , kStatusGroup_ApplicationRangeStart = 101 ,
  kStatusGroup_IAP = 102 , kStatusGroup_SFA = 103 , kStatusGroup_SPC = 104 , kStatusGroup_PUF = 105 ,
  kStatusGroup_TOUCH_PANEL = 106 , kStatusGroup_VBAT = 107 , kStatusGroup_HAL_GPIO = 121 , kStatusGroup_HAL_UART = 122 ,
  kStatusGroup_HAL_TIMER = 123 , kStatusGroup_HAL_SPI = 124 , kStatusGroup_HAL_I2C = 125 , kStatusGroup_HAL_FLASH = 126 ,
  kStatusGroup_HAL_PWM = 127 , kStatusGroup_HAL_RNG = 128 , kStatusGroup_HAL_I2S = 129 , kStatusGroup_TIMERMANAGER = 135 ,
  kStatusGroup_SERIALMANAGER = 136 , kStatusGroup_LED = 137 , kStatusGroup_BUTTON = 138 , kStatusGroup_EXTERN_EEPROM = 139 ,
  kStatusGroup_SHELL = 140 , kStatusGroup_MEM_MANAGER = 141 , kStatusGroup_LIST = 142 , kStatusGroup_OSA = 143 ,
  kStatusGroup_COMMON_TASK = 144 , kStatusGroup_MSG = 145 , kStatusGroup_SDK_OCOTP = 146 , kStatusGroup_SDK_FLEXSPINOR = 147 ,
  kStatusGroup_CODEC = 148 , kStatusGroup_ASRC = 149 , kStatusGroup_OTFAD = 150 , kStatusGroup_SDIOSLV = 151 ,
  kStatusGroup_MECC = 152 , kStatusGroup_ENET_QOS = 153 , kStatusGroup_LOG = 154 , kStatusGroup_I3CBUS = 155 ,
  kStatusGroup_QSCI = 156 , kStatusGroup_SNT = 157 , kStatusGroup_QUEUEDSPI = 158 , kStatusGroup_POWER_MANAGER = 159 ,
  kStatusGroup_IPED = 160 , kStatusGroup_CSS_PKC = 161 , kStatusGroup_HOSTIF = 162 , kStatusGroup_CLIF = 163 ,
  kStatusGroup_BMA = 164 , kStatusGroup_NETC = 165
 Status group numbers. More...
enum  {
  kStatus_Success = MAKE_STATUS(kStatusGroup_Generic, 0) , kStatus_Fail = MAKE_STATUS(kStatusGroup_Generic, 1) , kStatus_ReadOnly = MAKE_STATUS(kStatusGroup_Generic, 2) , kStatus_OutOfRange = MAKE_STATUS(kStatusGroup_Generic, 3) ,
  kStatus_InvalidArgument = MAKE_STATUS(kStatusGroup_Generic, 4) , kStatus_Timeout = MAKE_STATUS(kStatusGroup_Generic, 5) , kStatus_NoTransferInProgress , kStatus_Busy = MAKE_STATUS(kStatusGroup_Generic, 7) ,
  kStatus_NoData
 Generic status return codes. More...
typedef int32_t status_t
 Type used for all status and error return values.
#define FSL_COMMON_DRIVER_VERSION   (MAKE_VERSION(2, 4, 0))
 common driver version.
#define DEBUG_CONSOLE_DEVICE_TYPE_NONE   0U
#define DEBUG_CONSOLE_DEVICE_TYPE_UART   1U
#define DEBUG_CONSOLE_DEVICE_TYPE_LPUART   2U
#define DEBUG_CONSOLE_DEVICE_TYPE_LPSCI   3U
#define DEBUG_CONSOLE_DEVICE_TYPE_USBCDC   4U
#define DEBUG_CONSOLE_DEVICE_TYPE_FLEXCOMM   5U
#define DEBUG_CONSOLE_DEVICE_TYPE_IUART   6U
#define DEBUG_CONSOLE_DEVICE_TYPE_VUSART   7U
#define DEBUG_CONSOLE_DEVICE_TYPE_MINI_USART   8U
#define DEBUG_CONSOLE_DEVICE_TYPE_SWO   9U
#define DEBUG_CONSOLE_DEVICE_TYPE_QSCI   10U
Suppress fallthrough warning macro
void * SDK_Malloc (size_t size, size_t alignbytes)
 Allocate memory with given alignment and aligned size.
void SDK_Free (void *ptr)
 Free memory.
void SDK_DelayAtLeastUs (uint32_t delayTime_us, uint32_t coreClock_Hz)
 Delay at least for some time. Please note that, this API uses while loop for delay, different run-time environments make the time not precise, if precise delay count was needed, please implement a new delay function with hardware timer.
#define SUPPRESS_FALL_THROUGH_WARNING()
Min/max macros
#define MIN(a, b)   (((a) < (b)) ? (a) : (b))
#define MAX(a, b)   (((a) > (b)) ? (a) : (b))
#define ARRAY_SIZE(x)   (sizeof(x) / sizeof((x)[0]))
 Computes the number of elements in an array.
UINT16_MAX/UINT32_MAX value
#define UINT16_MAX   ((uint16_t)-1)
#define UINT32_MAX   ((uint32_t)-1)
UINTPTR_SIZE value
#define UINTPTR_SIZE   8 /* 64-bit processor */
Atomic modification
These macros are used for atomic access, such as read-modify-write to the peripheral registers.
  • SDK_ATOMIC_LOCAL_ADD
  • SDK_ATOMIC_LOCAL_SET
  • SDK_ATOMIC_LOCAL_CLEAR
  • SDK_ATOMIC_LOCAL_TOGGLE
  • SDK_ATOMIC_LOCAL_CLEAR_AND_SET
Take SDK_ATOMIC_LOCAL_CLEAR_AND_SET as an example: the parameter addr means the address of the peripheral register or variable you want to modify atomically, the parameter clearBits is the bits to clear, the parameter setBits it the bits to set. For example, to set a 32-bit register bit1:bit0 to 0b10, use like this:
volatile uint32_t * reg = (volatile uint32_t *)REG_ADDR;
SDK_ATOMIC_LOCAL_CLEAR_AND_SET(reg, 0x03, 0x02);
In this example, the register bit1:bit0 are cleared and bit1 is set, as a result, register bit1:bit0 = 0b10.
Note
For the platforms don't support exclusive load and store, these macros disable the global interrupt to pretect the modification.
These macros only guarantee the local processor atomic operations. For the multi-processor devices, use hardware semaphore such as SEMA42 to guarantee exclusive access if necessary.
#define SDK_ATOMIC_LOCAL_ADD(addr, val)
#define SDK_ATOMIC_LOCAL_SET(addr, bits)
#define SDK_ATOMIC_LOCAL_CLEAR(addr, bits)
#define SDK_ATOMIC_LOCAL_TOGGLE(addr, bits)
#define SDK_ATOMIC_LOCAL_CLEAR_AND_SET(addr, clearBits, setBits)
Timer utilities
#define USEC_TO_COUNT(us, clockFreqInHz)   (uint64_t)(((uint64_t)(us) * (clockFreqInHz)) / 1000000U)
#define COUNT_TO_USEC(count, clockFreqInHz)   (uint64_t)((uint64_t)(count)*1000000U / (clockFreqInHz))
#define MSEC_TO_COUNT(ms, clockFreqInHz)   (uint64_t)((uint64_t)(ms) * (clockFreqInHz) / 1000U)
#define COUNT_TO_MSEC(count, clockFreqInHz)   (uint64_t)((uint64_t)(count)*1000U / (clockFreqInHz))
Alignment variable definition macros
#define SDK_SIZEALIGN(var, alignbytes)    ((unsigned int)((var) + ((alignbytes)-1U)) & (unsigned int)(~(unsigned int)((alignbytes)-1U)))
Non-cacheable region definition macros
#define AT_NONCACHEABLE_SECTION(var)   var
#define AT_NONCACHEABLE_SECTION_ALIGN(var, alignbytes)   SDK_ALIGN(var, alignbytes)
#define AT_NONCACHEABLE_SECTION_INIT(var)   var
#define AT_NONCACHEABLE_SECTION_ALIGN_INIT(var, alignbytes)   SDK_ALIGN(var, alignbytes)
Timer utilities
#define COUNT_TO_USEC(count, clockFreqInHz)   (uint64_t)((uint64_t)(count) * 1000000U / (clockFreqInHz))
#define COUNT_TO_MSEC(count, clockFreqInHz)   (uint64_t)((uint64_t)(count) * 1000U / (clockFreqInHz))
#define SDK_ISR_EXIT_BARRIER
#define SDK_ALIGN(var, alignbytes)   var __attribute__((aligned(alignbytes)))
#define AT_NONCACHEABLE_SECTION_INIT(var)   __attribute__((section("NonCacheable.init"))) var
#define AT_NONCACHEABLE_SECTION(var)   __attribute__((section("NonCacheable"))) var
#define AT_NONCACHEABLE_SECTION_ALIGN_INIT(var, alignbytes)    __attribute__((section("NonCacheable.init"))) var __attribute__((aligned(alignbytes)))
#define AT_NONCACHEABLE_SECTION_ALIGN(var, alignbytes)    __attribute__((section("NonCacheable"))) var __attribute__((aligned(alignbytes)))
Time sensitive region
#define AT_QUICKACCESS_SECTION_CODE(func)   func
#define AT_QUICKACCESS_SECTION_DATA(func)   func
#define NVIC_SetPriorityGrouping(value)   do {} while(0)
#define NVIC_GetPriorityGrouping()   do {} while(0)
#define NVIC_EnableIRQ(value)   do {} while(0)
#define NVIC_GetEnableIRQ(value)   do {} while(0)
#define NVIC_DisableIRQ(value)   do {} while(0)
#define NVIC_GetPendingIRQ(value)   do {} while(0)
#define NVIC_SetPendingIRQ(value)   do {} while(0)
#define NVIC_ClearPendingIRQ(value)   do {} while(0)
#define NVIC_GetActive(value)   do {} while(0)
◆ COUNT_TO_MSEC [1/2]
#define COUNT_TO_MSEC (   count,
  clockFreqInHz
Macro to convert a raw count value to millisecond
◆ COUNT_TO_MSEC [2/2]
  clockFreqInHz
◆ COUNT_TO_USEC [1/2]
#define COUNT_TO_USEC (   count,
  clockFreqInHz
Macro to convert a raw count value to microsecond
◆ COUNT_TO_USEC [2/2]
  clockFreqInHz
◆ DEBUG_CONSOLE_DEVICE_TYPE_FLEXCOMM
Debug console based on FLEXCOMM.
◆ DEBUG_CONSOLE_DEVICE_TYPE_IUART
Debug console based on i.MX UART.
◆ DEBUG_CONSOLE_DEVICE_TYPE_LPSCI
Debug console based on LPSCI.
◆ DEBUG_CONSOLE_DEVICE_TYPE_LPUART
Debug console based on LPUART.
◆ DEBUG_CONSOLE_DEVICE_TYPE_MINI_USART
Debug console based on LPC_USART.
◆ DEBUG_CONSOLE_DEVICE_TYPE_NONE
No debug console.
◆ DEBUG_CONSOLE_DEVICE_TYPE_QSCI
Debug console based on QSCI.
◆ DEBUG_CONSOLE_DEVICE_TYPE_SWO
Debug console based on SWO.
◆ DEBUG_CONSOLE_DEVICE_TYPE_UART
Debug console based on UART.
◆ DEBUG_CONSOLE_DEVICE_TYPE_USBCDC
Debug console based on USBCDC.
◆ DEBUG_CONSOLE_DEVICE_TYPE_VUSART
Debug console based on LPC_VUSART.
◆ MAKE_VERSION
#define MAKE_VERSION (   major,
  minor,
  bugfix
The driver version is a 32-bit number, for both 32-bit platforms(such as Cortex M) and 16-bit platforms(such as DSC).
| Unused    || Major Version || Minor Version ||  Bug Fix    |
31        25  24           17  16            9  8            0
◆ MSEC_TO_COUNT [1/2]
#define MSEC_TO_COUNT (   ms,
  clockFreqInHz
Macro to convert a millisecond period to raw count value
◆ MSEC_TO_COUNT [2/2]
  clockFreqInHz
◆ SDK_ALIGN
#define SDK_ALIGN (   var,
  alignbytes
Macro to define a variable with alignbytes alignment
◆ SDK_ATOMIC_LOCAL_ADD
#define SDK_ATOMIC_LOCAL_ADD (   addr,
  val
Value:
do \
uint32_t s_atomicOldInt; \
s_atomicOldInt = DisableGlobalIRQ(); \
*(addr) += (val); \
EnableGlobalIRQ(s_atomicOldInt); \
} while (0)
◆ SDK_ATOMIC_LOCAL_CLEAR
#define SDK_ATOMIC_LOCAL_CLEAR (   addr,
  bits
Value:
do \
*(addr) &= ~(bits); \
} while (0)
◆ SDK_ATOMIC_LOCAL_CLEAR_AND_SET
#define SDK_ATOMIC_LOCAL_CLEAR_AND_SET (   addr,
  clearBits,
  setBits
Value:
do \
*(addr) = (*(addr) & ~(clearBits)) | (setBits); \
} while (0)
◆ SDK_ATOMIC_LOCAL_SET
#define SDK_ATOMIC_LOCAL_SET (   addr,
  bits
Value:
do \
*(addr) |= (bits); \
} while (0)
◆ SDK_ATOMIC_LOCAL_TOGGLE
#define SDK_ATOMIC_LOCAL_TOGGLE (   addr,
  bits
Value:
do \
*(addr) ^= (bits); \
} while (0)
◆ SDK_SIZEALIGN [1/2]
#define SDK_SIZEALIGN (   var,
  alignbytes
Macro to define a variable with L1 d-cache line size alignment
Macro to define a variable with L2 cache line size alignment
Macro to change a value to a given size aligned value
◆ SDK_SIZEALIGN [2/2]
  alignbytes
◆ USEC_TO_COUNT [1/2]
#define USEC_TO_COUNT (   us,
  clockFreqInHz
Macro to convert a microsecond period to raw count value
◆ USEC_TO_COUNT [2/2]
  clockFreqInHz
◆ anonymous enum
anonymous enum
kStatus_Success
Generic status for Success.
kStatus_Fail
Generic status for Fail.
kStatus_ReadOnly
Generic status for read only failure.
kStatus_OutOfRange
Generic status for out of range access.
Generic status for invalid argument check.
kStatus_Timeout
Generic status for timeout.
Generic status for no transfer in progress.
kStatus_Busy
Generic status for module is busy.
kStatus_NoData
Generic status for no data is found for the operation.
◆ _status_groups
Group number for generic status codes.
kStatusGroup_FLASH
Group number for FLASH status codes.
kStatusGroup_LPSPI
Group number for LPSPI status codes.
Group number for FLEXIO SPI status codes.
kStatusGroup_DSPI
Group number for DSPI status codes.
Group number for FLEXIO UART status codes.
Group number for FLEXIO I2C status codes.
kStatusGroup_LPI2C
Group number for LPI2C status codes.
kStatusGroup_UART
Group number for UART status codes.
kStatusGroup_I2C
kStatusGroup_LPSCI
Group number for LPSCI status codes.
kStatusGroup_LPUART
Group number for LPUART status codes.
kStatusGroup_SPI
Group number for SPI status code.
kStatusGroup_XRDC
Group number for XRDC status code.
kStatusGroup_SEMA42
Group number for SEMA42 status code.
kStatusGroup_SDHC
Group number for SDHC status code
kStatusGroup_SDMMC
Group number for SDMMC status code
kStatusGroup_SAI
Group number for SAI status code
kStatusGroup_MCG
Group number for MCG status codes.
kStatusGroup_SCG
Group number for SCG status codes.
kStatusGroup_SDSPI
Group number for SDSPI status codes.
Group number for FLEXIO I2S status codes
Group number for FLEXIO LCD status codes
Group number for FLASHIAP status codes
Group number for FLEXCOMM I2C status codes
kStatusGroup_I2S
Group number for I2S status codes
kStatusGroup_IUART
Group number for IUART status codes
kStatusGroup_CSI
Group number for CSI status codes
Group number for MIPI DSI status codes
kStatusGroup_SDRAMC
Group number for SDRAMC status codes.
kStatusGroup_POWER
Group number for POWER status codes.
kStatusGroup_ENET
Group number for ENET status codes.
kStatusGroup_PHY
Group number for PHY status codes.
kStatusGroup_TRGMUX
Group number for TRGMUX status codes.
Group number for SMARTCARD status codes.
kStatusGroup_LMEM
Group number for LMEM status codes.
kStatusGroup_QSPI
Group number for QSPI status codes.
kStatusGroup_DMA
Group number for DMA status codes.
kStatusGroup_EDMA
Group number for EDMA status codes.
kStatusGroup_DMAMGR
Group number for DMAMGR status codes.
Group number for FlexCAN status codes.
kStatusGroup_LTC
Group number for LTC status codes.
Group number for FLEXIO CAMERA status codes.
Group number for LPC_SPI status codes.
Group number for LPC_USART status codes.
kStatusGroup_DMIC
Group number for DMIC status codes.
kStatusGroup_SDIF
Group number for SDIF status codes.
kStatusGroup_SPIFI
Group number for SPIFI status codes.
kStatusGroup_OTP
Group number for OTP status codes.
kStatusGroup_MCAN
Group number for MCAN status codes.
kStatusGroup_CAAM
Group number for CAAM status codes.
kStatusGroup_ECSPI
Group number for ECSPI status codes.
kStatusGroup_USDHC
Group number for USDHC status codes.
Group number for LPC_I2C status codes.
kStatusGroup_DCP
Group number for DCP status codes.
kStatusGroup_MSCAN
Group number for MSCAN status codes.
kStatusGroup_ESAI
Group number for ESAI status codes.
Group number for FLEXSPI status codes.
kStatusGroup_MMDC
Group number for MMDC status codes.
kStatusGroup_PDM
Group number for MIC status codes.
kStatusGroup_SDMA
Group number for SDMA status codes.
kStatusGroup_ICS
Group number for ICS status codes.
kStatusGroup_SPDIF
Group number for SPDIF status codes.
Group number for LPC_MINISPI status codes.
Group number for Hashcrypt status codes
Group number for LPC_SPI_SSP status codes.
kStatusGroup_I3C
Group number for I3C status codes
Group number for LPC_I2C_1 status codes.
Group number for NOTIFIER status codes.
Group number for debug console status codes.
kStatusGroup_SEMC
Group number for SEMC status codes.
Starting number for application groups.
kStatusGroup_IAP
Group number for IAP status codes
kStatusGroup_SFA
Group number for SFA status codes
kStatusGroup_SPC
Group number for SPC status codes.
kStatusGroup_PUF
Group number for PUF status codes.
Group number for touch panel status codes
kStatusGroup_VBAT
Group number for VBAT status codes
Group number for HAL GPIO status codes.
Group number for HAL UART status codes.
Group number for HAL TIMER status codes.
Group number for HAL SPI status codes.
Group number for HAL I2C status codes.
Group number for HAL FLASH status codes.
Group number for HAL PWM status codes.
Group number for HAL RNG status codes.
Group number for HAL I2S status codes.
Group number for TiMER MANAGER status codes.
Group number for SERIAL MANAGER status codes.
kStatusGroup_LED
Group number for LED status codes.
kStatusGroup_BUTTON
Group number for BUTTON status codes.
Group number for EXTERN EEPROM status codes.
kStatusGroup_SHELL
Group number for SHELL status codes.
Group number for MEM MANAGER status codes.
kStatusGroup_LIST
Group number for List status codes.
kStatusGroup_OSA
Group number for OSA status codes.
Group number for Common task status codes.
kStatusGroup_MSG
Group number for messaging status codes.
Group number for OCOTP status codes.
Group number for FLEXSPINOR status codes.
kStatusGroup_CODEC
Group number for codec status codes.
kStatusGroup_ASRC
Group number for codec status ASRC.
kStatusGroup_OTFAD
Group number for SDIOSLV status codes.
kStatusGroup_MECC
Group number for MECC status codes.
Group number for ENET_QOS status codes.
kStatusGroup_LOG
Group number for LOG status codes.
kStatusGroup_I3CBUS
Group number for I3CBUS status codes.
kStatusGroup_QSCI
Group number for QSCI status codes.
kStatusGroup_SNT
Group number for SNT status codes.
Group number for POWER_MANAGER status codes.
kStatusGroup_IPED
Group number for IPED status codes.
Group number for CSS PKC status codes.
kStatusGroup_HOSTIF
Group number for HOSTIF status codes.
kStatusGroup_CLIF
Group number for CLIF status codes.
kStatusGroup_BMA
Group number for BMA status codes.
kStatusGroup_NETC
Group number for NETC status codes.
◆ SDK_DelayAtLeastUs()
void SDK_DelayAtLeastUs ( uint32_t  delayTime_us,
Parameters
delayTime_usDelay time in unit of microsecond.
coreClock_HzCore clock frequency with Hz.
Parameters
◆ SDK_Free()
void SDK_Free ( void *  ptr)
Free memory.
Parameters
ptrThe memory to be release.
◆ SDK_Malloc()
void * SDK_Malloc ( size_t  size,
size_t  alignbytes
This is provided to support the dynamically allocated memory used in cache-able region.
Parameters
sizeThe length required to malloc.
alignbytesThe alignment size.
Return values
Theallocated memory.
