RTEMS 6.2
Snvs_hp
struct  _snvs_hp_rtc_datetime
 Structure is used to hold the date and time. More...
struct  _snvs_hp_rtc_config
 SNVS config structure. More...
Driver version
enum  _snvs_hp_interrupts { kSNVS_RTC_AlarmInterrupt = SNVS_HPCR_HPTA_EN_MASK , kSNVS_RTC_PeriodicInterrupt = SNVS_HPCR_PI_EN_MASK }
 List of SNVS interrupts. More...
enum  _snvs_hp_status_flags { kSNVS_RTC_AlarmInterruptFlag = SNVS_HPSR_HPTA_MASK , kSNVS_RTC_PeriodicInterruptFlag = SNVS_HPSR_PI_MASK , kSNVS_ZMK_ZeroFlag = (int)SNVS_HPSR_ZMK_ZERO_MASK , kSNVS_OTPMK_ZeroFlag = SNVS_HPSR_OTPMK_ZERO_MASK }
 List of SNVS flags. More...
enum  _snvs_hp_sv_status_flags {
  kSNVS_LP_ViolationFlag = SNVS_HPSVSR_SW_LPSV_MASK , kSNVS_ZMK_EccFailFlag = SNVS_HPSVSR_ZMK_ECC_FAIL_MASK , kSNVS_LP_SoftwareViolationFlag = SNVS_HPSVSR_SW_LPSV_MASK , kSNVS_FatalSoftwareViolationFlag = SNVS_HPSVSR_SW_FSV_MASK ,
  kSNVS_SoftwareViolationFlag = SNVS_HPSVSR_SW_SV_MASK , kSNVS_Violation0Flag = SNVS_HPSVSR_SV0_MASK , kSNVS_Violation1Flag = SNVS_HPSVSR_SV1_MASK , kSNVS_Violation2Flag = SNVS_HPSVSR_SV2_MASK ,
  kSNVS_Violation4Flag = SNVS_HPSVSR_SV4_MASK , kSNVS_Violation5Flag = SNVS_HPSVSR_SV5_MASK
 List of SNVS security violation flags. More...
enum  _snvs_hp_ssm_state {
  kSNVS_SSMInit = 0x00 , kSNVS_SSMHardFail = 0x01 , kSNVS_SSMSoftFail = 0x03 , kSNVS_SSMInitInter = 0x08 ,
  kSNVS_SSMCheck = 0x09 , kSNVS_SSMNonSecure = 0x0B , kSNVS_SSMTrusted = 0x0D , kSNVS_SSMSecure = 0x0F
 List of SNVS Security State Machine State. More...
typedef enum _snvs_hp_interrupts snvs_hp_interrupts_t
typedef enum _snvs_hp_status_flags snvs_hp_status_flags_t
 List of SNVS flags.
typedef enum _snvs_hp_sv_status_flags snvs_hp_sv_status_flags_t
typedef struct _snvs_hp_rtc_datetime snvs_hp_rtc_datetime_t
typedef struct _snvs_hp_rtc_config snvs_hp_rtc_config_t
typedef enum _snvs_hp_ssm_state snvs_hp_ssm_state_t
#define FSL_SNVS_HP_DRIVER_VERSION   (MAKE_VERSION(2, 3, 2))
#define SNVS_HPSVSR_SV0_MASK   SNVS_HPSVSR_CAAM_MASK
#define SNVS_HPSVSR_SV1_MASK   SNVS_HPSVSR_JTAGC_MASK
#define SNVS_HPSVSR_SV2_MASK   SNVS_HPSVSR_WDOG2_MASK
#define SNVS_HPSVSR_SV4_MASK   SNVS_HPSVSR_SRC_MASK
#define SNVS_HPSVSR_SV5_MASK   SNVS_HPSVSR_OCOTP_MASK
#define SNVS_MAKE_HP_SV_FLAG(x)   (1U << (SNVS_HPSVSR_SV0_SHIFT + (x)))
 Macro to make security violation flag.
Initialization and deinitialization
void SNVS_HP_Init (SNVS_Type *base)
 Initialize the SNVS.
void SNVS_HP_Deinit (SNVS_Type *base)
 Deinitialize the SNVS.
void SNVS_HP_RTC_Init (SNVS_Type *base, const snvs_hp_rtc_config_t *config)
 Ungates the SNVS clock and configures the peripheral for basic operation.
void SNVS_HP_RTC_Deinit (SNVS_Type *base)
 Stops the RTC and SRTC timers.
void SNVS_HP_RTC_GetDefaultConfig (snvs_hp_rtc_config_t *config)
 Fills in the SNVS config struct with the default settings.
Non secure RTC current Time & Alarm
status_t SNVS_HP_RTC_SetDatetime (SNVS_Type *base, const snvs_hp_rtc_datetime_t *datetime)
 Sets the SNVS RTC date and time according to the given time structure.
void SNVS_HP_RTC_GetDatetime (SNVS_Type *base, snvs_hp_rtc_datetime_t *datetime)
 Gets the SNVS RTC time and stores it in the given time structure.
status_t SNVS_HP_RTC_SetAlarm (SNVS_Type *base, const snvs_hp_rtc_datetime_t *alarmTime)
 Sets the SNVS RTC alarm time.
void SNVS_HP_RTC_GetAlarm (SNVS_Type *base, snvs_hp_rtc_datetime_t *datetime)
 Returns the SNVS RTC alarm time.
Interrupt Interface
uint32_t SNVS_HP_RTC_GetEnabledInterrupts (SNVS_Type *base)
 Gets the enabled SNVS interrupts.
Status Interface
uint32_t SNVS_HP_RTC_GetStatusFlags (SNVS_Type *base)
 Gets the SNVS status flags.
◆ FSL_SNVS_HP_DRIVER_VERSION
Version 2.3.2
◆ SNVS_MAKE_HP_SV_FLAG
#define SNVS_MAKE_HP_SV_FLAG (   x)    (1U << (SNVS_HPSVSR_SV0_SHIFT + (x)))
Macro help to make security violation flag kSNVS_Violation0Flag to kSNVS_Violation5Flag, For example, SNVS_MAKE_HP_SV_FLAG(0) is kSNVS_Violation0Flag.
Typedef Documentation
◆ snvs_hp_rtc_config_t
This structure holds the configuration settings for the SNVS peripheral. To initialize this structure to reasonable defaults, call the SNVS_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
◆ _snvs_hp_interrupts
RTC time alarm
RTC periodic interrupt
◆ _snvs_hp_ssm_state
kSNVS_SSMInit
Init
kSNVS_SSMHardFail
Hard Fail
kSNVS_SSMSoftFail
Soft Fail
kSNVS_SSMInitInter
Init Intermediate (transition state between Init and Check)
kSNVS_SSMCheck
Check
kSNVS_SSMNonSecure
Non-Secure
kSNVS_SSMTrusted
Trusted
kSNVS_SSMSecure
Secure
◆ _snvs_hp_status_flags
List of SNVS flags.
RTC time alarm flag
RTC periodic interrupt flag
kSNVS_ZMK_ZeroFlag
The ZMK is zero
The OTPMK is zero
◆ _snvs_hp_sv_status_flags
Low Power section Security Violation
Zeroizable Master Key Error Correcting Code Check Failure
LP Software Security Violation
Software Fatal Security Violation
Security Violation 0
Security Violation 1
Security Violation 2
Security Violation 4
Security Violation 5
◆ SNVS_HP_Deinit()
void SNVS_HP_Deinit ( SNVS_Type base)
Parameters
baseSNVS peripheral base address
brief Deinitialize the SNVS.
param base SNVS peripheral base address
◆ SNVS_HP_Init()
void SNVS_HP_Init ( SNVS_Type base)
Note
This API should be called at the beginning of the application using the SNVS driver.
Parameters
brief Initialize the SNVS.
note This API should be called at the beginning of the application using the SNVS driver.
◆ SNVS_HP_RTC_Deinit()
void SNVS_HP_RTC_Deinit ( SNVS_Type base)
Parameters
brief Stops the RTC and SRTC timers.
◆ SNVS_HP_RTC_GetAlarm()
void SNVS_HP_RTC_GetAlarm ( SNVS_Type base,
snvs_hp_rtc_datetime_t datetime
Parameters
datetimePointer to the structure where the alarm date and time details are stored.
brief Returns the SNVS RTC alarm time.
param base SNVS peripheral base address param datetime Pointer to the structure where the alarm date and time details are stored.
◆ SNVS_HP_RTC_GetDatetime()
void SNVS_HP_RTC_GetDatetime ( SNVS_Type base,
Parameters
datetimePointer to the structure where the date and time details are stored.
brief Gets the SNVS RTC time and stores it in the given time structure.
param base SNVS peripheral base address param datetime Pointer to the structure where the date and time details are stored.
◆ SNVS_HP_RTC_GetDefaultConfig()
void SNVS_HP_RTC_GetDefaultConfig ( snvs_hp_rtc_config_t config)
The default values are as follows.
config->rtccalenable = false;
config->rtccalvalue = 0U;
config->PIFreq = 0U;
Definition: deflate.c:114
Parameters
configPointer to the user's SNVS configuration structure.
brief Fills in the SNVS config struct with the default settings.
The default values are as follows. code config->rtccalenable = false; config->rtccalvalue = 0U; config->PIFreq = 0U; endcode param config Pointer to the user's SNVS configuration structure.
◆ SNVS_HP_RTC_GetEnabledInterrupts()
uint32_t SNVS_HP_RTC_GetEnabledInterrupts ( SNVS_Type base)
Parameters
Returns
The enabled interrupts. This is the logical OR of members of the enumeration :: _snvs_hp_interrupts_t
brief Gets the enabled SNVS interrupts.
return The enabled interrupts. This is the logical OR of members of the enumeration ::snvs_interrupt_enable_t
◆ SNVS_HP_RTC_GetStatusFlags()
uint32_t SNVS_HP_RTC_GetStatusFlags ( SNVS_Type base)
Parameters
Returns
The status flags. This is the logical OR of members of the enumeration :: _snvs_hp_status_flags_t
brief Gets the SNVS status flags.
return The status flags. This is the logical OR of members of the enumeration ::snvs_status_flags_t
◆ SNVS_HP_RTC_Init()
void SNVS_HP_RTC_Init ( SNVS_Type base,
const snvs_hp_rtc_config_t config
Note
Parameters
brief Ungates the SNVS clock and configures the peripheral for basic operation.
param base SNVS peripheral base address param config Pointer to the user's SNVS configuration structure.
◆ SNVS_HP_RTC_SetAlarm()
status_t SNVS_HP_RTC_SetAlarm ( SNVS_Type base,
const snvs_hp_rtc_datetime_t alarmTime
The function sets the RTC alarm. It also checks whether the specified alarm time is greater than the present time. If not, the function does not set the alarm and returns an error.
Parameters
alarmTimePointer to the structure where the alarm time is stored.
Returns
kStatus_Success: success in setting the SNVS RTC alarm kStatus_InvalidArgument: Error because the alarm datetime format is incorrect kStatus_Fail: Error because the alarm time has already passed
brief Sets the SNVS RTC alarm time.
param base SNVS peripheral base address param alarmTime Pointer to the structure where the alarm time is stored.
return kStatus_Success: success in setting the SNVS RTC alarm kStatus_InvalidArgument: Error because the alarm datetime format is incorrect kStatus_Fail: Error because the alarm time has already passed
◆ SNVS_HP_RTC_SetDatetime()
status_t SNVS_HP_RTC_SetDatetime ( SNVS_Type base,
const snvs_hp_rtc_datetime_t datetime
Parameters
Returns
kStatus_Success: Success in setting the time and starting the SNVS RTC kStatus_InvalidArgument: Error because the datetime format is incorrect
brief Sets the SNVS RTC date and time according to the given time structure.
return kStatus_Success: Success in setting the time and starting the SNVS RTC kStatus_InvalidArgument: Error because the datetime format is incorrect
