RTEMS 6.2
Data Structures | Macros | Typedefs | Enumerations | Functions
Rdc
struct  _rdc_hardware_config
 RDC hardware configuration. More...
struct  _rdc_domain_assignment
 Master domain assignment. More...
struct  _rdc_periph_access_config
 Peripheral domain access permission configuration. More...
struct  _rdc_mem_access_config
 Memory region domain access control configuration. More...
struct  _rdc_mem_status
 Memory region access violation status. More...
#define FSL_RDC_DRIVER_VERSION   (MAKE_VERSION(2, 2, 0))
#define RDC_ACCESS_POLICY(domainID, policy)   (uint16_t)((uint16_t)(policy) << ((domainID)*2U))
typedef struct _rdc_hardware_config rdc_hardware_config_t
typedef struct _rdc_domain_assignment rdc_domain_assignment_t
typedef struct _rdc_periph_access_config rdc_periph_access_config_t
typedef struct _rdc_mem_access_config rdc_mem_access_config_t
typedef struct _rdc_mem_status rdc_mem_status_t
enum  _rdc_interrupts { kRDC_RestoreCompleteInterrupt = RDC_INTCTRL_RCI_EN_MASK }
 RDC interrupts. More...
enum  _rdc_flags { kRDC_PowerDownDomainOn = RDC_STAT_PDS_MASK }
 RDC status. More...
enum  _rdc_access_policy { kRDC_NoAccess = 0 , kRDC_WriteOnly = 1 , kRDC_ReadOnly = 2 , kRDC_ReadWrite = 3 }
 Access permission policy. More...
void RDC_Init (RDC_Type *base)
 Initializes the RDC module.
void RDC_Deinit (RDC_Type *base)
 De-initializes the RDC module.
void RDC_GetHardwareConfig (RDC_Type *base, rdc_hardware_config_t *config)
 Gets the RDC hardware configuration.
void RDC_SetMasterDomainAssignment (RDC_Type *base, rdc_master_t master, const rdc_domain_assignment_t *domainAssignment)
 Set master domain assignment.
void RDC_GetDefaultMasterDomainAssignment (rdc_domain_assignment_t *domainAssignment)
 Get default master domain assignment.
void RDC_SetPeriphAccessConfig (RDC_Type *base, const rdc_periph_access_config_t *config)
 Set peripheral access policy.
void RDC_GetDefaultPeriphAccessConfig (rdc_periph_access_config_t *config)
 Get default peripheral access policy.
void RDC_SetMemAccessConfig (RDC_Type *base, const rdc_mem_access_config_t *config)
 Set memory region access policy.
void RDC_GetDefaultMemAccessConfig (rdc_mem_access_config_t *config)
 Get default memory region access policy.
void RDC_GetMemViolationStatus (RDC_Type *base, rdc_mem_t mem, rdc_mem_status_t *status)
 Get the memory region violation status.
Typedef Documentation
◆ rdc_mem_access_config_t
Note that when setting the baseAddress and endAddress, should be aligned to the region resolution, see rdc_mem_t definitions.
◆ _rdc_access_policy
kRDC_NoAccess
Could not read or write.
kRDC_WriteOnly
Write only.
kRDC_ReadOnly
Read only.
kRDC_ReadWrite
Read and write.
◆ _rdc_flags
enum _rdc_flags
RDC status.
Power down domain is ON.
◆ _rdc_interrupts
RDC interrupts.
Interrupt generated when the RDC has completed restoring state to a recently re-powered memory regions.
◆ RDC_Deinit()
void RDC_Deinit ( RDC_Type base)
This function disables the RDC clock.
Parameters
baseRDC peripheral base address.
brief De-initializes the RDC module.
param base RDC peripheral base address.
◆ RDC_GetDefaultMasterDomainAssignment()
void RDC_GetDefaultMasterDomainAssignment ( rdc_domain_assignment_t domainAssignment)
The default configuration is:
assignment->domainId = 0U;
assignment->lock = 0U;
Parameters
domainAssignmentPointer to the assignment.
brief Get default master domain assignment
The default configuration is: code assignment->domainId = 0U; assignment->lock = 0U; endcode
param domainAssignment Pointer to the assignment.
◆ RDC_GetDefaultMemAccessConfig()
void RDC_GetDefaultMemAccessConfig ( rdc_mem_access_config_t config)
config->lock = false;
config->baseAddress = 0;
config->endAddress = 0;
config->policy = RDC_ACCESS_POLICY(0, kRDC_ReadWrite) |
RDC_ACCESS_POLICY(1, kRDC_ReadWrite) |
RDC_ACCESS_POLICY(2, kRDC_ReadWrite) |
RDC_ACCESS_POLICY(3, kRDC_ReadWrite);
@ kRDC_ReadWrite
Definition: fsl_rdc.h:72
Definition: deflate.c:114
Parameters
configPointer to the policy configuration.
brief Get default memory region access policy.
The default configuration is: code config->lock = false; config->baseAddress = 0; config->endAddress = 0; config->policy = RDC_ACCESS_POLICY(0, kRDC_ReadWrite) | RDC_ACCESS_POLICY(1, kRDC_ReadWrite) | RDC_ACCESS_POLICY(2, kRDC_ReadWrite) | RDC_ACCESS_POLICY(3, kRDC_ReadWrite); endcode
param config Pointer to the policy configuration.
◆ RDC_GetDefaultPeriphAccessConfig()
void RDC_GetDefaultPeriphAccessConfig ( rdc_periph_access_config_t config)
config->enableSema = false;
Parameters
brief Get default peripheral access policy.
The default configuration is: code config->lock = false; config->enableSema = false; config->policy = RDC_ACCESS_POLICY(0, kRDC_ReadWrite) | RDC_ACCESS_POLICY(1, kRDC_ReadWrite) | RDC_ACCESS_POLICY(2, kRDC_ReadWrite) | RDC_ACCESS_POLICY(3, kRDC_ReadWrite); endcode
◆ RDC_GetHardwareConfig()
void RDC_GetHardwareConfig ( RDC_Type base,
rdc_hardware_config_t config
This function gets the RDC hardware configurations, including number of bus masters, number of domains, number of memory regions and number of peripherals.
Parameters
configPointer to the structure to get the configuration.
brief Gets the RDC hardware configuration.
param base RDC peripheral base address. param config Pointer to the structure to get the configuration.
◆ RDC_GetMemViolationStatus()
void RDC_GetMemViolationStatus ( RDC_Type base,
rdc_mem_t  mem,
rdc_mem_status_t status
The first access violation is captured. Subsequent violations are ignored until the status register is cleared. Contents are cleared upon reading the register. Clearing of contents occurs only when the status is read by the memory region's associated domain ID(s).
Parameters
memWhich memory region to get.
statusThe returned status.
brief Get the memory region violation status.
param base RDC peripheral base address. param mem Which memory region to get. param status The returned status.
◆ RDC_Init()
void RDC_Init ( RDC_Type base)
This function enables the RDC clock.
Parameters
brief Initializes the RDC module.
◆ RDC_SetMasterDomainAssignment()
void RDC_SetMasterDomainAssignment ( RDC_Type base,
const rdc_domain_assignment_t domainAssignment
Parameters
masterWhich master to set.
brief Set master domain assignment
param base RDC peripheral base address. param master Which master to set. param domainAssignment Pointer to the assignment.
◆ RDC_SetMemAccessConfig()
void RDC_SetMemAccessConfig ( RDC_Type base,
const rdc_mem_access_config_t config
Note that when setting the baseAddress and endAddress in config, should be aligned to the region resolution, see rdc_mem_t definitions.
Parameters
brief Set memory region access policy.
Note that when setting the baseAddress and endAddress in p config, should be aligned to the region resolution, see rdc_mem_t definitions.
param base RDC peripheral base address. param config Pointer to the policy configuration.
◆ RDC_SetPeriphAccessConfig()
void RDC_SetPeriphAccessConfig ( RDC_Type base,
const rdc_periph_access_config_t config
Parameters
brief Set peripheral access policy.
