RTEMS 6.2
Data Structures | Typedefs | Enumerations | Enumerator | Variables
Lpi2c_slave_driver
struct  _lpi2c_slave_config
 Structure with settings to initialize the LPI2C slave module. More...
struct  _lpi2c_slave_transfer
 LPI2C slave transfer structure. More...
struct  _lpi2c_slave_handle
 LPI2C slave handle structure. More...
typedef enum _lpi2c_slave_address_match lpi2c_slave_address_match_t
 LPI2C slave address match options.
typedef struct _lpi2c_slave_config lpi2c_slave_config_t
typedef enum _lpi2c_slave_transfer_event lpi2c_slave_transfer_event_t
 Set of events sent to the callback for non blocking slave transfers.
typedef struct _lpi2c_slave_transfer lpi2c_slave_transfer_t
typedef struct _lpi2c_slave_handle lpi2c_slave_handle_t
typedef void(* lpi2c_slave_transfer_callback_t) (LPI2C_Type *base, lpi2c_slave_transfer_t *transfer, void *userData)
 Slave event callback function pointer type.
enum  _lpi2c_slave_flags {
  kLPI2C_SlaveTxReadyFlag = LPI2C_SSR_TDF_MASK , kLPI2C_SlaveRxReadyFlag = LPI2C_SSR_RDF_MASK , kLPI2C_SlaveAddressValidFlag = LPI2C_SSR_AVF_MASK , kLPI2C_SlaveTransmitAckFlag = LPI2C_SSR_TAF_MASK ,
  kLPI2C_SlaveRepeatedStartDetectFlag = LPI2C_SSR_RSF_MASK , kLPI2C_SlaveStopDetectFlag = LPI2C_SSR_SDF_MASK , kLPI2C_SlaveBitErrFlag = LPI2C_SSR_BEF_MASK , kLPI2C_SlaveFifoErrFlag = LPI2C_SSR_FEF_MASK ,
  kLPI2C_SlaveAddressMatch0Flag = LPI2C_SSR_AM0F_MASK , kLPI2C_SlaveAddressMatch1Flag = LPI2C_SSR_AM1F_MASK , kLPI2C_SlaveGeneralCallFlag = LPI2C_SSR_GCF_MASK , kLPI2C_SlaveBusyFlag = LPI2C_SSR_SBF_MASK ,
  kLPI2C_SlaveBusBusyFlag = LPI2C_SSR_BBF_MASK , kLPI2C_SlaveClearFlags , kLPI2C_SlaveIrqFlags , kLPI2C_SlaveErrorFlags = kLPI2C_SlaveFifoErrFlag | kLPI2C_SlaveBitErrFlag
 LPI2C slave peripheral flags. More...
enum  _lpi2c_slave_address_match { kLPI2C_MatchAddress0 = 0U , kLPI2C_MatchAddress0OrAddress1 = 2U , kLPI2C_MatchAddress0ThroughAddress1 = 6U }
 LPI2C slave address match options. More...
enum  _lpi2c_slave_transfer_event {
  kLPI2C_SlaveAddressMatchEvent = 0x01U , kLPI2C_SlaveTransmitEvent = 0x02U , kLPI2C_SlaveReceiveEvent = 0x04U , kLPI2C_SlaveTransmitAckEvent = 0x08U ,
  kLPI2C_SlaveRepeatedStartEvent = 0x10U , kLPI2C_SlaveCompletionEvent = 0x20U , kLPI2C_SlaveAllEvents
 Set of events sent to the callback for non blocking slave transfers. More...
bool _lpi2c_master_config::enableMaster
bool _lpi2c_master_config::enableDoze
bool _lpi2c_master_config::debugEnable
bool _lpi2c_master_config::ignoreAck
lpi2c_master_pin_config_t _lpi2c_master_config::pinConfig
uint32_t _lpi2c_master_config::baudRate_Hz
uint32_t _lpi2c_master_config::busIdleTimeout_ns
uint32_t _lpi2c_master_config::pinLowTimeout_ns
uint8_t _lpi2c_master_config::sdaGlitchFilterWidth_ns
uint8_t _lpi2c_master_config::sclGlitchFilterWidth_ns
lpi2c_host_request_source_t   _lpi2c_master_config::source
lpi2c_host_request_polarity_t   _lpi2c_master_config::polarity
struct {
_lpi2c_master_config::hostRequest
lpi2c_data_match_config_mode_t _lpi2c_match_config::matchMode
bool _lpi2c_match_config::rxDataMatchOnly
uint32_t _lpi2c_match_config::match0
uint32_t _lpi2c_match_config::match1
uint32_t _lpi2c_master_transfer::flags
uint16_t _lpi2c_master_transfer::slaveAddress
lpi2c_direction_t _lpi2c_master_transfer::direction
uint32_t _lpi2c_master_transfer::subaddress
size_t _lpi2c_master_transfer::subaddressSize
void * _lpi2c_master_transfer::data
size_t _lpi2c_master_transfer::dataSize
uint8_t _lpi2c_master_handle::state
uint16_t _lpi2c_master_handle::remainingBytes
uint8_t * _lpi2c_master_handle::buf
uint16_t _lpi2c_master_handle::commandBuffer [6]
lpi2c_master_transfer_t _lpi2c_master_handle::transfer
lpi2c_master_transfer_callback_t _lpi2c_master_handle::completionCallback
void * _lpi2c_master_handle::userData
bool _lpi2c_slave_config::enableSlave
uint8_t _lpi2c_slave_config::address0
uint8_t _lpi2c_slave_config::address1
lpi2c_slave_address_match_t _lpi2c_slave_config::addressMatchMode
bool _lpi2c_slave_config::filterDozeEnable
bool _lpi2c_slave_config::filterEnable
bool _lpi2c_slave_config::enableGeneralCall
bool   _lpi2c_slave_config::enableAck
bool   _lpi2c_slave_config::enableTx
bool   _lpi2c_slave_config::enableRx
bool   _lpi2c_slave_config::enableAddress
struct {
_lpi2c_slave_config::sclStall
bool _lpi2c_slave_config::ignoreAck
bool _lpi2c_slave_config::enableReceivedAddressRead
uint32_t _lpi2c_slave_config::sdaGlitchFilterWidth_ns
uint32_t _lpi2c_slave_config::sclGlitchFilterWidth_ns
uint32_t _lpi2c_slave_config::dataValidDelay_ns
uint32_t _lpi2c_slave_config::clockHoldTime_ns
lpi2c_slave_transfer_event_t _lpi2c_slave_transfer::event
uint8_t _lpi2c_slave_transfer::receivedAddress
uint8_t * _lpi2c_slave_transfer::data
size_t _lpi2c_slave_transfer::dataSize
status_t _lpi2c_slave_transfer::completionStatus
size_t _lpi2c_slave_transfer::transferredCount
lpi2c_slave_transfer_t _lpi2c_slave_handle::transfer
bool _lpi2c_slave_handle::isBusy
bool _lpi2c_slave_handle::wasTransmit
uint32_t _lpi2c_slave_handle::eventMask
uint32_t _lpi2c_slave_handle::transferredCount
lpi2c_slave_transfer_callback_t _lpi2c_slave_handle::callback
void * _lpi2c_slave_handle::userData
Slave initialization and deinitialization
void LPI2C_SlaveGetDefaultConfig (lpi2c_slave_config_t *slaveConfig)
 Provides a default configuration for the LPI2C slave peripheral.
void LPI2C_SlaveInit (LPI2C_Type *base, const lpi2c_slave_config_t *slaveConfig, uint32_t sourceClock_Hz)
 Initializes the LPI2C slave peripheral.
void LPI2C_SlaveDeinit (LPI2C_Type *base)
 Deinitializes the LPI2C slave peripheral.
Slave bus operations
status_t LPI2C_SlaveSend (LPI2C_Type *base, void *txBuff, size_t txSize, size_t *actualTxSize)
 Performs a polling send transfer on the I2C bus.
status_t LPI2C_SlaveReceive (LPI2C_Type *base, void *rxBuff, size_t rxSize, size_t *actualRxSize)
 Performs a polling receive transfer on the I2C bus.
Slave non-blocking
void LPI2C_SlaveTransferCreateHandle (LPI2C_Type *base, lpi2c_slave_handle_t *handle, lpi2c_slave_transfer_callback_t callback, void *userData)
 Creates a new handle for the LPI2C slave non-blocking APIs.
status_t LPI2C_SlaveTransferNonBlocking (LPI2C_Type *base, lpi2c_slave_handle_t *handle, uint32_t eventMask)
 Starts accepting slave transfers.
status_t LPI2C_SlaveTransferGetCount (LPI2C_Type *base, lpi2c_slave_handle_t *handle, size_t *count)
 Gets the slave transfer status during a non-blocking transfer.
void LPI2C_SlaveTransferAbort (LPI2C_Type *base, lpi2c_slave_handle_t *handle)
 Aborts the slave non-blocking transfers.
Slave IRQ handler
void LPI2C_SlaveTransferHandleIRQ (LPI2C_Type *base, lpi2c_slave_handle_t *handle)
 Reusable routine to handle slave interrupts.
Typedef Documentation
◆ lpi2c_slave_config_t
This structure holds configuration settings for the LPI2C slave peripheral. To initialize this structure to reasonable defaults, call the LPI2C_SlaveGetDefaultConfig() function and pass a pointer to your configuration structure instance.
The configuration structure can be made constant so it resides in flash.
◆ lpi2c_slave_transfer_callback_t
This callback is used only for the slave non-blocking transfer API. To install a callback, use the LPI2C_SlaveSetCallback() function after you have created a handle.
Parameters
baseBase address for the LPI2C instance on which the event occurred.
transferPointer to transfer descriptor containing values passed to and/or from the callback.
userDataArbitrary pointer-sized value passed from the application.
◆ lpi2c_slave_transfer_event_t
These event enumerations are used for two related purposes. First, a bit mask created by OR'ing together events is passed to LPI2C_SlaveTransferNonBlocking() in order to specify which events to enable. Then, when the slave callback is invoked, it is passed the current event through its transfer parameter.
Note
These enumerations are meant to be OR'd together to form a bit mask of events.
◆ _lpi2c_slave_address_match
Match only address 0.
Match either address 0 or address 1.
Match a range of slave addresses from address 0 through address 1.
◆ _lpi2c_slave_flags
The following status register flags can be cleared:
All flags except kLPI2C_SlaveBusyFlag and kLPI2C_SlaveBusBusyFlag can be enabled as interrupts.
Note
These enumerations are meant to be OR'd together to form a bit mask.
Transmit data flag
Receive data flag
Address valid flag
Transmit ACK flag
Repeated start detect flag
Stop detect flag
Bit error flag
FIFO error flag
Address match 0 flag
Address match 1 flag
General call flag
Master busy flag
Bus busy flag
All flags which are cleared by the driver upon starting a transfer.
IRQ sources enabled by the non-blocking transactional API.
Errors to check for.
◆ _lpi2c_slave_transfer_event
Note
Received the slave address after a start or repeated start.
Callback is requested to provide data to transmit (slave-transmitter role).
Callback is requested to provide a buffer in which to place received data (slave-receiver role).
Callback needs to either transmit an ACK or NACK.
A repeated start was detected.
A stop was detected, completing the transfer.
Bit mask of all available events.
◆ LPI2C_SlaveDeinit()
void LPI2C_SlaveDeinit ( LPI2C_Type base)
This function disables the LPI2C slave peripheral and gates the clock. It also performs a software reset to restore the peripheral to reset conditions.
Parameters
baseThe LPI2C peripheral base address.
brief Deinitializes the LPI2C slave peripheral.
param base The LPI2C peripheral base address.
◆ LPI2C_SlaveGetDefaultConfig()
void LPI2C_SlaveGetDefaultConfig ( lpi2c_slave_config_t slaveConfig)
This function provides the following default configuration for the LPI2C slave peripheral:
slaveConfig->enableSlave = true;
slaveConfig->address0 = 0U;
slaveConfig->address1 = 0U;
slaveConfig->addressMatchMode = kLPI2C_MatchAddress0;
slaveConfig->filterDozeEnable = true;
slaveConfig->filterEnable = true;
slaveConfig->enableGeneralCall = false;
slaveConfig->sclStall.enableAck = false;
slaveConfig->sclStall.enableTx = true;
slaveConfig->sclStall.enableRx = true;
slaveConfig->sclStall.enableAddress = true;
slaveConfig->ignoreAck = false;
slaveConfig->enableReceivedAddressRead = false;
slaveConfig->sdaGlitchFilterWidth_ns = 0;
slaveConfig->sclGlitchFilterWidth_ns = 0;
slaveConfig->dataValidDelay_ns = 0;
slaveConfig->clockHoldTime_ns = 0;
@ kLPI2C_MatchAddress0
Definition: fsl_lpi2c.h:314
After calling this function, override any settings to customize the configuration, prior to initializing the master driver with LPI2C_SlaveInit(). Be sure to override at least the address0 member of the configuration structure with the desired slave address.
Parameters
[out]slaveConfigUser provided configuration structure that is set to default values. Refer to lpi2c_slave_config_t.
brief Provides a default configuration for the LPI2C slave peripheral.
This function provides the following default configuration for the LPI2C slave peripheral: code slaveConfig->enableSlave = true; slaveConfig->address0 = 0U; slaveConfig->address1 = 0U; slaveConfig->addressMatchMode = kLPI2C_MatchAddress0; slaveConfig->filterDozeEnable = true; slaveConfig->filterEnable = true; slaveConfig->enableGeneralCall = false; slaveConfig->sclStall.enableAck = false; slaveConfig->sclStall.enableTx = true; slaveConfig->sclStall.enableRx = true; slaveConfig->sclStall.enableAddress = true; slaveConfig->ignoreAck = false; slaveConfig->enableReceivedAddressRead = false; slaveConfig->sdaGlitchFilterWidth_ns = 0; slaveConfig->sclGlitchFilterWidth_ns = 0; slaveConfig->dataValidDelay_ns = 0; slaveConfig->clockHoldTime_ns = 0; endcode
After calling this function, override any settings to customize the configuration, prior to initializing the master driver with LPI2C_SlaveInit(). Be sure to override at least the a address0 member of the configuration structure with the desired slave address.
param[out] slaveConfig User provided configuration structure that is set to default values. Refer to lpi2c_slave_config_t.
◆ LPI2C_SlaveInit()
void LPI2C_SlaveInit ( LPI2C_Type base,
const lpi2c_slave_config_t slaveConfig,
This function enables the peripheral clock and initializes the LPI2C slave peripheral as described by the user provided configuration.
Parameters
slaveConfigUser provided peripheral configuration. Use LPI2C_SlaveGetDefaultConfig() to get a set of defaults that you can override.
sourceClock_HzFrequency in Hertz of the LPI2C functional clock. Used to calculate the filter widths, data valid delay, and clock hold time.
brief Initializes the LPI2C slave peripheral.
param base The LPI2C peripheral base address. param slaveConfig User provided peripheral configuration. Use LPI2C_SlaveGetDefaultConfig() to get a set of defaults that you can override. param sourceClock_Hz Frequency in Hertz of the LPI2C functional clock. Used to calculate the filter widths, data valid delay, and clock hold time.
◆ LPI2C_SlaveReceive()
status_t LPI2C_SlaveReceive ( LPI2C_Type base,
void *  rxBuff,
size_t  rxSize,
size_t *  actualRxSize
Parameters
rxBuffThe pointer to the data to be transferred.
rxSizeThe length in bytes of the data to be transferred.
[out]actualRxSize
Returns
Error or success status returned by API.
brief Performs a polling receive transfer on the I2C bus.
param base The LPI2C peripheral base address. param rxBuff The pointer to the data to be transferred. param rxSize The length in bytes of the data to be transferred. param[out] actualRxSize return Error or success status returned by API.
◆ LPI2C_SlaveSend()
status_t LPI2C_SlaveSend ( LPI2C_Type base,
void *  txBuff,
size_t  txSize,
size_t *  actualTxSize
Parameters
txBuffThe pointer to the data to be transferred.
txSizeThe length in bytes of the data to be transferred.
[out]actualTxSize
Returns
brief Performs a polling send transfer on the I2C bus.
param base The LPI2C peripheral base address. param txBuff The pointer to the data to be transferred. param txSize The length in bytes of the data to be transferred. param[out] actualTxSize return Error or success status returned by API.
◆ LPI2C_SlaveTransferAbort()
void LPI2C_SlaveTransferAbort ( LPI2C_Type base,
lpi2c_slave_handle_t handle
Note
This API could be called at any time to stop slave for handling the bus events.
Parameters
handlePointer to lpi2c_slave_handle_t structure which stores the transfer state.
Return values
kStatus_Success
kStatus_LPI2C_Idle
brief Aborts the slave non-blocking transfers. note This API could be called at any time to stop slave for handling the bus events. param base The LPI2C peripheral base address. param handle Pointer to lpi2c_slave_handle_t structure which stores the transfer state. retval kStatus_Success retval kStatus_LPI2C_Idle
◆ LPI2C_SlaveTransferCreateHandle()
void LPI2C_SlaveTransferCreateHandle ( LPI2C_Type base,
lpi2c_slave_handle_t handle,
void *  userData
The creation of a handle is for use with the non-blocking APIs. Once a handle is created, there is not a corresponding destroy handle. If the user wants to terminate a transfer, the LPI2C_SlaveTransferAbort() API shall be called.
Note
The function also enables the NVIC IRQ for the input LPI2C. Need to notice that on some SoCs the LPI2C IRQ is connected to INTMUX, in this case user needs to enable the associated INTMUX IRQ in application.
Parameters
[out]handlePointer to the LPI2C slave driver handle.
callbackUser provided pointer to the asynchronous callback function.
userDataUser provided pointer to the application callback data.
brief Creates a new handle for the LPI2C slave non-blocking APIs.
note The function also enables the NVIC IRQ for the input LPI2C. Need to notice that on some SoCs the LPI2C IRQ is connected to INTMUX, in this case user needs to enable the associated INTMUX IRQ in application.
param base The LPI2C peripheral base address. param[out] handle Pointer to the LPI2C slave driver handle. param callback User provided pointer to the asynchronous callback function. param userData User provided pointer to the application callback data.
◆ LPI2C_SlaveTransferGetCount()
status_t LPI2C_SlaveTransferGetCount ( LPI2C_Type base,
size_t *  count
Parameters
handlePointer to i2c_slave_handle_t structure.
[out]countPointer to a value to hold the number of bytes transferred. May be NULL if the count is not required.
Return values
kStatus_Success
kStatus_NoTransferInProgress
brief Gets the slave transfer status during a non-blocking transfer. param base The LPI2C peripheral base address. param handle Pointer to i2c_slave_handle_t structure. param[out] count Pointer to a value to hold the number of bytes transferred. May be NULL if the count is not required. retval kStatus_Success retval kStatus_NoTransferInProgress
◆ LPI2C_SlaveTransferHandleIRQ()
void LPI2C_SlaveTransferHandleIRQ ( LPI2C_Type base,
Note
This function does not need to be called unless you are reimplementing the non blocking API's interrupt handler routines to add special functionality.
Parameters
brief Reusable routine to handle slave interrupts. note This function does not need to be called unless you are reimplementing the non blocking API's interrupt handler routines to add special functionality. param base The LPI2C peripheral base address. param handle Pointer to lpi2c_slave_handle_t structure which stores the transfer state.
◆ LPI2C_SlaveTransferNonBlocking()
status_t LPI2C_SlaveTransferNonBlocking ( LPI2C_Type base,
uint32_t  eventMask
Call this API after calling I2C_SlaveInit() and LPI2C_SlaveTransferCreateHandle() to start processing transactions driven by an I2C master. The slave monitors the I2C bus and pass events to the callback that was passed into the call to LPI2C_SlaveTransferCreateHandle(). The callback is always invoked from the interrupt context.
The set of events received by the callback is customizable. To do so, set the eventMask parameter to the OR'd combination of lpi2c_slave_transfer_event_t enumerators for the events you wish to receive. The kLPI2C_SlaveTransmitEvent and kLPI2C_SlaveReceiveEvent events are always enabled and do not need to be included in the mask. Alternatively, you can pass 0 to get a default set of only the transmit and receive events that are always enabled. In addition, the kLPI2C_SlaveAllEvents constant is provided as a convenient way to enable all events.
Parameters
eventMaskBit mask formed by OR'ing together lpi2c_slave_transfer_event_t enumerators to specify which events to send to the callback. Other accepted values are 0 to get a default set of only the transmit and receive events, and kLPI2C_SlaveAllEvents to enable all events.
Return values
kStatus_SuccessSlave transfers were successfully started.
kStatus_LPI2C_BusySlave transfers have already been started on this handle.
brief Starts accepting slave transfers.
The set of events received by the callback is customizable. To do so, set the a eventMask parameter to the OR'd combination of lpi2c_slave_transfer_event_t enumerators for the events you wish to receive. The kLPI2C_SlaveTransmitEvent and kLPI2C_SlaveReceiveEvent events are always enabled and do not need to be included in the mask. Alternatively, you can pass 0 to get a default set of only the transmit and receive events that are always enabled. In addition, the kLPI2C_SlaveAllEvents constant is provided as a convenient way to enable all events.
param base The LPI2C peripheral base address. param handle Pointer to lpi2c_slave_handle_t structure which stores the transfer state. param eventMask Bit mask formed by OR'ing together lpi2c_slave_transfer_event_t enumerators to specify which events to send to the callback. Other accepted values are 0 to get a default set of only the transmit and receive events, and kLPI2C_SlaveAllEvents to enable all events.
retval kStatus_Success Slave transfers were successfully started. retval kStatus_LPI2C_Busy Slave transfers have already been started on this handle.
Variable Documentation
◆ address0
Slave's 7-bit address.
◆ address1
Alternate slave 7-bit address.
◆ addressMatchMode
Address matching options.
◆ baudRate_Hz
Desired baud rate in Hertz.
◆ buf
uint8_t* _lpi2c_master_handle::buf
Buffer pointer for current state.
◆ busIdleTimeout_ns
Bus idle timeout in nanoseconds. Set to 0 to disable.
◆ callback
Callback function called at transfer event.
◆ clockHoldTime_ns
Width in nanoseconds of the clock hold time.
◆ commandBuffer
uint16_t _lpi2c_master_handle::commandBuffer[6]
LPI2C command sequence. When all 6 command words are used: Start&addr&write[1 word] + subaddr[4 words] + restart&addr&read[1 word]
◆ completionCallback
Callback function pointer.
◆ completionStatus
Success or error code describing how the transfer completed. Only applies for kLPI2C_SlaveCompletionEvent.
◆ data [1/2]
void* _lpi2c_master_transfer::data
Pointer to data to transfer.
◆ data [2/2]
uint8_t* _lpi2c_slave_transfer::data
Transfer buffer
◆ dataSize [1/2]
Number of bytes to transfer.
◆ dataSize [2/2]
Transfer size
◆ dataValidDelay_ns
Width in nanoseconds of the data valid delay.
◆ debugEnable
Enable transfers to continue when halted in debug mode.
◆ direction
◆ enable [1/2]
Enable host request.
◆  [2/2]
bool { ... } ::enable
◆  [1/2]
bool { ... } ::enableAck
Enables SCL clock stretching during slave-transmit address byte(s) and slave-receiver address and data byte(s) to allow software to write the Transmit ACK Register before the ACK or NACK is transmitted. Clock stretching occurs when transmitting the 9th bit. When enableAckSCLStall is enabled, there is no need to set either enableRxDataSCLStall or enableAddressSCLStall.
◆ enableAck [2/2]
◆  [1/2]
bool { ... } ::enableAddress
Enables SCL clock stretching when the address valid flag is asserted.
◆ enableAddress [2/2]
◆ enableDoze
Whether master is enabled in doze mode.
◆ enableGeneralCall
Enable general call address matching.
◆ enableMaster
Whether to enable master mode.
◆ enableReceivedAddressRead
Enable reading the address received address as the first byte of data.
◆  [1/2]
bool { ... } ::enableRx
Enables SCL clock stretching when receive data flag is set during a slave-receive transfer.
◆ enableRx [2/2]
◆ enableSlave
Enable slave mode.
◆ enableTx [1/2]
Enables SCL clock stretching when the transmit data flag is set during a slave-transmit transfer.
◆  [2/2]
bool { ... } ::enableTx
◆ event
Reason the callback is being invoked.
◆ eventMask
Mask of enabled events.
◆ filterDozeEnable
Enable digital glitch filter in doze mode.
◆ filterEnable
Enable digital glitch filter.
◆ flags
Bit mask of options for the transfer. See enumeration _lpi2c_master_transfer_flags for available options. Set to 0 or kLPI2C_TransferDefaultFlag for normal transfers.
struct { ... } _lpi2c_master_config::hostRequest
Host request options.
◆ ignoreAck [1/2]
Whether to ignore ACK/NACK.
◆ ignoreAck [2/2]
Continue transfers after a NACK is detected.
◆ isBusy
Whether transfer is busy.
◆ match0
Match value 0.
◆ match1
Match value 1.
◆ matchMode
Data match configuration setting.
◆ pinConfig
The pin configuration option.
◆ pinLowTimeout_ns
Pin low timeout in nanoseconds. Set to 0 to disable.
◆  [1/2]
lpi2c_host_request_polarity_t { ... } ::polarity
Host request pin polarity.
◆ polarity [2/2]
◆ receivedAddress
Matching address send by master.
◆ remainingBytes
Remaining byte count in current state.
◆ rxDataMatchOnly
When set to true, received data is ignored until a successful match.
◆ sclGlitchFilterWidth_ns [1/2]
Width in nanoseconds of glitch filter on SCL pin. Set to 0 to disable.
◆ sclGlitchFilterWidth_ns [2/2]
Width in nanoseconds of the digital filter on the SCL signal. Set to 0 to disable.
◆ sdaGlitchFilterWidth_ns [1/2]
Width in nanoseconds of glitch filter on SDA pin. Set to 0 to disable.
◆ sdaGlitchFilterWidth_ns [2/2]
Width in nanoseconds of the digital filter on the SDA signal. Set to 0 to disable.
◆ slaveAddress
The 7-bit slave address.
◆ source [1/2]
Host request source.
◆  [2/2]
lpi2c_host_request_source_t { ... } ::source
◆ state
Transfer state machine current state.
◆ subaddress
Sub address. Transferred MSB first.
◆ subaddressSize
Length of sub address to send in bytes. Maximum size is 4 bytes.
◆ transfer [1/2]
Copy of the current transfer info.
◆ transfer [2/2]
LPI2C slave transfer copy.
◆ transferredCount [1/2]
Number of bytes actually transferred since start or last repeated start.
◆ transferredCount [2/2]
Count of bytes transferred.
◆ userData [1/2]
void* _lpi2c_master_handle::userData
Application data passed to callback.
◆ userData [2/2]
void* _lpi2c_slave_handle::userData
Callback parameter passed to callback.
◆ wasTransmit
Whether the last transfer was a transmit.
