RTEMS 6.2
Data Structures | Enumerator | Variables
Flexspi_dma
struct  _flexspi_dma_handle
 FLEXSPI DMA transfer handle, users should not touch the content of the handle. More...
dma_handle_t * _flexspi_dma_handle::txDmaHandle
dma_handle_t * _flexspi_dma_handle::rxDmaHandle
size_t _flexspi_dma_handle::transferSize
flexspi_dma_transfer_nsize_t _flexspi_dma_handle::nsize
uint8_t _flexspi_dma_handle::nbytes
uint8_t _flexspi_dma_handle::count
uint32_t _flexspi_dma_handle::state
flexspi_dma_callback_t _flexspi_dma_handle::completionCallback
void * _flexspi_dma_handle::userData
Driver version
enum  _flexspi_dma_ntransfer_size { kFLEXPSI_DMAnSize1Bytes = 0x1U , kFLEXPSI_DMAnSize2Bytes = 0x2U , kFLEXPSI_DMAnSize4Bytes = 0x4U }
 dma transfer configuration More...
typedef struct _flexspi_dma_handle flexspi_dma_handle_t
typedef void(* flexspi_dma_callback_t) (FLEXSPI_Type *base, flexspi_dma_handle_t *handle, status_t status, void *userData)
 FLEXSPI dma transfer callback function for finish and error.
typedef enum _flexspi_dma_ntransfer_size flexspi_dma_transfer_nsize_t
#define FSL_FLEXSPI_DMA_DRIVER_VERSION   (MAKE_VERSION(2, 2, 1))
 FLEXSPI DMA driver version 2.2.1.
FLEXSPI dma Transactional
void FLEXSPI_TransferCreateHandleDMA (FLEXSPI_Type *base, flexspi_dma_handle_t *handle, flexspi_dma_callback_t callback, void *userData, dma_handle_t *txDmaHandle, dma_handle_t *rxDmaHandle)
 Initializes the FLEXSPI handle for transfer which is used in transactional functions and set the callback.
void FLEXSPI_TransferUpdateSizeDMA (FLEXSPI_Type *base, flexspi_dma_handle_t *handle, flexspi_dma_transfer_nsize_t nsize)
 Update FLEXSPI DMA transfer source data transfer size(SSIZE) and destination data transfer size(DSIZE).
status_t FLEXSPI_TransferDMA (FLEXSPI_Type *base, flexspi_dma_handle_t *handle, flexspi_transfer_t *xfer)
 Transfers FLEXSPI data using an dma non-blocking method.
void FLEXSPI_TransferAbortDMA (FLEXSPI_Type *base, flexspi_dma_handle_t *handle)
 Aborts the transfer data using dma.
status_t FLEXSPI_TransferGetTransferCountDMA (FLEXSPI_Type *base, flexspi_dma_handle_t *handle, size_t *count)
 Gets the transferred counts of transfer.
◆ _flexspi_dma_ntransfer_size
Source/Destination data transfer size is 1 byte every time
Source/Destination data transfer size is 2 bytes every time
Source/Destination data transfer size is 4 bytes every time
◆ FLEXSPI_TransferAbortDMA()
void FLEXSPI_TransferAbortDMA ( FLEXSPI_Type base,
flexspi_dma_handle_t handle
This function aborts the transfer data using dma.
Parameters
baseFLEXSPI peripheral base address.
handlePointer to flexspi_dma_handle_t structure
◆ FLEXSPI_TransferCreateHandleDMA()
void FLEXSPI_TransferCreateHandleDMA ( FLEXSPI_Type base,
flexspi_dma_handle_t handle,
void *  userData,
dma_handle_t *  txDmaHandle,
dma_handle_t *  rxDmaHandle
Parameters
callbackFLEXSPI callback, NULL means no callback.
userDataUser callback function data.
txDmaHandleUser requested DMA handle for TX DMA transfer.
rxDmaHandleUser requested DMA handle for RX DMA transfer.
◆ FLEXSPI_TransferDMA()
status_t FLEXSPI_TransferDMA ( FLEXSPI_Type base,
flexspi_transfer_t xfer
This function writes/receives data to/from the FLEXSPI transmit/receive FIFO. This function is non-blocking.
Parameters
xferFLEXSPI transfer structure.
Return values
kStatus_FLEXSPI_BusyFLEXSPI is busy transfer.
kStatus_InvalidArgumentThe watermark configuration is invalid, the watermark should be power of 2 to do successfully DMA transfer.
kStatus_SuccessFLEXSPI successfully start dma transfer.
◆ FLEXSPI_TransferGetTransferCountDMA()
status_t FLEXSPI_TransferGetTransferCountDMA ( FLEXSPI_Type base,
size_t *  count
Parameters
handlePointer to flexspi_dma_handle_t structure.
countBytes transfer.
Return values
kStatus_SuccessSucceed get the transfer count.
kStatus_NoTransferInProgressThere is not a non-blocking transaction currently in progress.
◆ FLEXSPI_TransferUpdateSizeDMA()
void FLEXSPI_TransferUpdateSizeDMA ( FLEXSPI_Type base,
Parameters
nsizeFLEXSPI DMA transfer data transfer size(SSIZE/DSIZE), by default the size is kFLEXPSI_DMAnSize1Bytes(one byte).
See also
flexspi_dma_transfer_nsize_t .
Variable Documentation
◆ completionCallback
A callback function called after the dma transfer is finished.
◆ count
The transfer data count in a DMA request.
◆ nbytes
dma minor byte transfer count initially configured.
◆ nsize
dma SSIZE/DSIZE in each transfer.
◆ rxDmaHandle
dma_handle_t* _flexspi_dma_handle::rxDmaHandle
dma handler for FLEXSPI Rx.
◆ state
Internal state for FLEXSPI dma transfer.
◆ transferSize
Bytes need to transfer.
◆ txDmaHandle
dma_handle_t* _flexspi_dma_handle::txDmaHandle
dma handler for FLEXSPI Tx.
◆ userData
void* _flexspi_dma_handle::userData
User callback parameter
