RTEMS 6.2
| struct | _flexio_spi_master_edma_handle |
| FlexIO SPI eDMA transfer handle, users should not touch the content of the handle. More... | |
Driver version | |
| typedef struct _flexio_spi_master_edma_handle | flexio_spi_master_edma_handle_t |
| typedef for flexio_spi_master_edma_handle_t in advance. | |
| typedef flexio_spi_master_edma_handle_t | flexio_spi_slave_edma_handle_t |
| Slave handle is the same with master handle. | |
| typedef void(* | flexio_spi_master_edma_transfer_callback_t) (FLEXIO_SPI_Type *base, flexio_spi_master_edma_handle_t *handle, status_t status, void *userData) |
| FlexIO SPI master callback for finished transmit. | |
| typedef void(* | flexio_spi_slave_edma_transfer_callback_t) (FLEXIO_SPI_Type *base, flexio_spi_slave_edma_handle_t *handle, status_t status, void *userData) |
| FlexIO SPI slave callback for finished transmit. | |
| #define | FSL_FLEXIO_SPI_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 3, 0)) |
| FlexIO SPI EDMA driver version. | |
| void FLEXIO_SPI_MasterTransferAbortEDMA | ( | FLEXIO_SPI_Type * | base, |
| flexio_spi_master_edma_handle_t * | handle | ||
Aborts a FlexIO SPI transfer using eDMA.
| base | Pointer to FLEXIO_SPI_Type structure. |
| handle | FlexIO SPI eDMA handle pointer. |
brief Aborts a FlexIO SPI transfer using eDMA.
param base Pointer to FLEXIO_SPI_Type structure. param handle FlexIO SPI eDMA handle pointer.
| status_t FLEXIO_SPI_MasterTransferCreateHandleEDMA | ( | FLEXIO_SPI_Type * | base, |
| flexio_spi_master_edma_handle_t * | handle, | ||
| flexio_spi_master_edma_transfer_callback_t | callback, | ||
| void * | userData, | ||
| edma_handle_t * | txHandle, | ||
| edma_handle_t * | rxHandle | ||
Initializes the FlexIO SPI master eDMA handle.
This function initializes the FlexIO SPI master eDMA handle which can be used for other FlexIO SPI master transactional APIs. For a specified FlexIO SPI instance, call this API once to get the initialized handle.
| handle | Pointer to flexio_spi_master_edma_handle_t structure to store the transfer state. |
| callback | SPI callback, NULL means no callback. |
| userData | callback function parameter. |
| txHandle | User requested eDMA handle for FlexIO SPI RX eDMA transfer. |
| rxHandle | User requested eDMA handle for FlexIO SPI TX eDMA transfer. |
| kStatus_Success | Successfully create the handle. |
| kStatus_OutOfRange | The FlexIO SPI eDMA type/handle table out of range. |
brief Initializes the FlexIO SPI master eDMA handle.
param base Pointer to FLEXIO_SPI_Type structure. param handle Pointer to flexio_spi_master_edma_handle_t structure to store the transfer state. param callback SPI callback, NULL means no callback. param userData callback function parameter. param txHandle User requested eDMA handle for FlexIO SPI RX eDMA transfer. param rxHandle User requested eDMA handle for FlexIO SPI TX eDMA transfer. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO SPI eDMA type/handle table out of range.
| status_t FLEXIO_SPI_MasterTransferEDMA | ( | FLEXIO_SPI_Type * | base, |
| flexio_spi_transfer_t * | xfer | ||
Performs a non-blocking FlexIO SPI transfer using eDMA.
| xfer | Pointer to FlexIO SPI transfer structure. |
| kStatus_Success | Successfully start a transfer. |
| kStatus_InvalidArgument | Input argument is invalid. |
| kStatus_FLEXIO_SPI_Busy | FlexIO SPI is not idle, is running another transfer. |
brief Performs a non-blocking FlexIO SPI transfer using eDMA.
note This interface returns immediately after transfer initiates. Call FLEXIO_SPI_MasterGetTransferCountEDMA to poll the transfer status and check whether the FlexIO SPI transfer is finished.
param base Pointer to FLEXIO_SPI_Type structure. param handle Pointer to flexio_spi_master_edma_handle_t structure to store the transfer state. param xfer Pointer to FlexIO SPI transfer structure. retval kStatus_Success Successfully start a transfer. retval kStatus_InvalidArgument Input argument is invalid. retval kStatus_FLEXIO_SPI_Busy FlexIO SPI is not idle, is running another transfer.
| status_t FLEXIO_SPI_MasterTransferGetCountEDMA | ( | FLEXIO_SPI_Type * | base, |
| size_t * | count | ||
Gets the number of bytes transferred so far using FlexIO SPI master eDMA.
| count | Number of bytes transferred so far by the non-blocking transaction. |
brief Gets the remaining bytes for FlexIO SPI eDMA transfer.
param base Pointer to FLEXIO_SPI_Type structure. param handle FlexIO SPI eDMA handle pointer. param count Number of bytes transferred so far by the non-blocking transaction.
| status_t FLEXIO_SPI_SlaveTransferEDMA | ( | FLEXIO_SPI_Type * | base, |
| flexio_spi_slave_edma_handle_t * | handle, | ||
| handle | Pointer to flexio_spi_slave_edma_handle_t structure to store the transfer state. |
note This interface returns immediately after transfer initiates. Call FLEXIO_SPI_SlaveGetTransferCountEDMA to poll the transfer status and check whether the FlexIO SPI transfer is finished.
param base Pointer to FLEXIO_SPI_Type structure. param handle Pointer to flexio_spi_slave_edma_handle_t structure to store the transfer state. param xfer Pointer to FlexIO SPI transfer structure. retval kStatus_Success Successfully start a transfer. retval kStatus_InvalidArgument Input argument is invalid. retval kStatus_FLEXIO_SPI_Busy FlexIO SPI is not idle, is running another transfer.
