RTEMS 6.2
Files | Macros | Typedefs
Thread States
This group contains the implementation to support thread states. More...
file  states.h
 This header file provides interfaces of the Thread States which are used by the implementation and the Application Configuration.
file  statesimpl.h
 This header file provides interfaces of the Thread States which are only used by the implementation.
#define STATES_READY   0x00000000
#define STATES_WAITING_FOR_MUTEX   0x00000001
#define STATES_WAITING_FOR_SEMAPHORE   0x00000002
#define STATES_WAITING_FOR_EVENT   0x00000004
#define STATES_WAITING_FOR_SYSTEM_EVENT   0x00000008
#define STATES_WAITING_FOR_MESSAGE   0x00000010
#define STATES_WAITING_FOR_CONDITION_VARIABLE   0x00000020
#define STATES_WAITING_FOR_FUTEX   0x00000040
#define STATES_WAITING_FOR_BSD_WAKEUP   0x00000080
#define STATES_WAITING_FOR_TIME   0x00000100
 This macro corresponds to a task which is waiting for a relative or absolute timeout.
#define STATES_WAITING_FOR_PERIOD   0x00000200
#define STATES_WAITING_FOR_SIGNAL   0x00000400
#define STATES_WAITING_FOR_BARRIER   0x00000800
#define STATES_WAITING_FOR_RWLOCK   0x00001000
#define STATES_WAITING_FOR_JOIN_AT_EXIT   0x00002000
#define STATES_WAITING_FOR_JOIN   0x00004000
#define STATES_SUSPENDED   0x00008000
#define STATES_WAITING_FOR_SEGMENT   0x00010000
#define STATES_LIFE_IS_CHANGING   0x00020000
#define STATES_DEBUGGER   0x08000000
#define STATES_INTERRUPTIBLE_BY_SIGNAL   0x10000000
#define STATES_WAITING_FOR_RPC_REPLY   0x20000000
#define STATES_ZOMBIE   0x40000000
#define STATES_DORMANT   0x80000000
#define STATES_LOCALLY_BLOCKED
#define STATES_BLOCKED
#define STATES_ALL_SET   0xffffffff
typedef uint32_t States_Control
This handler encapsulates functionality which relates to the management of the state bitmap associated with each thread.
◆ STATES_ALL_SET
All state bits set to one (provided for _Thread_Start())
◆ STATES_BLOCKED
Value:
Definition: statesimpl.h:127
Definition: statesimpl.h:74
Definition: statesimpl.h:139
Definition: statesimpl.h:92
Definition: statesimpl.h:130
Definition: statesimpl.h:95
Definition: statesimpl.h:71
This macro corresponds to a task waiting which is blocked.
◆ STATES_DEBUGGER
This macro corresponds to a task being held by the debugger.
◆ STATES_DORMANT
This macro corresponds to a task being created but not yet started.
◆ STATES_INTERRUPTIBLE_BY_SIGNAL
This macro corresponds to a task which is in an interruptible blocking state.
◆ STATES_LIFE_IS_CHANGING
This macro corresponds to a task those life is changing.
◆ STATES_LOCALLY_BLOCKED
Value:
Definition: statesimpl.h:116
Definition: statesimpl.h:101
Definition: statesimpl.h:98
Definition: statesimpl.h:83
Definition: statesimpl.h:68
Definition: statesimpl.h:110
Definition: statesimpl.h:65
Definition: statesimpl.h:80
Definition: statesimpl.h:86
Definition: statesimpl.h:104
Definition: statesimpl.h:77
This macro corresponds to a task waiting for a local object operation.
◆ STATES_READY
This macro corresponds to a task being ready.
◆ STATES_SUSPENDED
This macro corresponds to a task being suspended.
◆ STATES_WAITING_FOR_BARRIER
This macro corresponds to a task waiting for a barrier.
◆ STATES_WAITING_FOR_BSD_WAKEUP
This macro corresponds to a task waiting for BSD wakeup.
◆ STATES_WAITING_FOR_CONDITION_VARIABLE
This macro corresponds to a task waiting for a condition variable.
◆ STATES_WAITING_FOR_EVENT
This macro corresponds to a task waiting for an event.
◆ STATES_WAITING_FOR_FUTEX
This macro corresponds to a task waiting for a futex.
◆ STATES_WAITING_FOR_JOIN
This macro corresponds to a task waiting for a join.
◆ STATES_WAITING_FOR_JOIN_AT_EXIT
This macro corresponds to a task waiting for a join while exiting.
◆ STATES_WAITING_FOR_MESSAGE
This macro corresponds to a task waiting for a message.
◆ STATES_WAITING_FOR_MUTEX
This macro corresponds to a task waiting for a mutex.
◆ STATES_WAITING_FOR_PERIOD
This macro corresponds to a task waiting for a period.
◆ STATES_WAITING_FOR_RPC_REPLY
This macro corresponds to a task waiting for a reply to an MPCI request.
◆ STATES_WAITING_FOR_RWLOCK
This macro corresponds to a task waiting for a RWLock.
◆ STATES_WAITING_FOR_SEGMENT
This macro corresponds to a task waiting for a fixed size segment.
◆ STATES_WAITING_FOR_SEMAPHORE
This macro corresponds to a task waiting for a semaphore.
◆ STATES_WAITING_FOR_SIGNAL
This macro corresponds to a task waiting for a signal.
◆ STATES_WAITING_FOR_SYSTEM_EVENT
This macro corresponds to a task waiting for a system event.
◆ STATES_ZOMBIE
This macro corresponds to a task being a zombie.
Typedef Documentation
◆ States_Control
The following type defines the control block used to manage a thread's state.
