RTEMS 6.1
HAL configuration template file. This file should be copied to the application folder and renamed to stm32h7xx_hal_conf.h. More...
#include "stm32h7xx_hal_rcc.h"#include "stm32h7xx_hal_gpio.h"#include "stm32h7xx_hal_dma.h"#include "stm32h7xx_hal_mdma.h"#include "stm32h7xx_hal_hash.h"#include "stm32h7xx_hal_dcmi.h"#include "stm32h7xx_hal_dma2d.h"#include "stm32h7xx_hal_dsi.h"#include "stm32h7xx_hal_dfsdm.h"#include "stm32h7xx_hal_dts.h"#include "stm32h7xx_hal_eth.h"#include "stm32h7xx_hal_exti.h"#include "stm32h7xx_hal_cortex.h"#include "stm32h7xx_hal_adc.h"#include "stm32h7xx_hal_fdcan.h"#include "stm32h7xx_hal_cec.h"#include "stm32h7xx_hal_comp.h"#include "stm32h7xx_hal_cordic.h"#include "stm32h7xx_hal_crc.h"#include "stm32h7xx_hal_cryp.h"#include "stm32h7xx_hal_dac.h"#include "stm32h7xx_hal_flash.h"#include "stm32h7xx_hal_gfxmmu.h"#include "stm32h7xx_hal_fmac.h"#include "stm32h7xx_hal_hrtim.h"#include "stm32h7xx_hal_hsem.h"#include "stm32h7xx_hal_sram.h"#include "stm32h7xx_hal_nor.h"#include "stm32h7xx_hal_nand.h"#include "stm32h7xx_hal_i2c.h"#include "stm32h7xx_hal_i2s.h"#include "stm32h7xx_hal_iwdg.h"#include "stm32h7xx_hal_jpeg.h"#include "stm32h7xx_hal_mdios.h"#include "stm32h7xx_hal_mmc.h"#include "stm32h7xx_hal_lptim.h"#include "stm32h7xx_hal_ltdc.h"#include "stm32h7xx_hal_opamp.h"#include "stm32h7xx_hal_ospi.h"#include "stm32h7xx_hal_otfdec.h"#include "stm32h7xx_hal_pssi.h"#include "stm32h7xx_hal_pwr.h"#include "stm32h7xx_hal_qspi.h"#include "stm32h7xx_hal_ramecc.h"#include "stm32h7xx_hal_rng.h"#include "stm32h7xx_hal_rtc.h"#include "stm32h7xx_hal_sai.h"#include "stm32h7xx_hal_sd.h"#include "stm32h7xx_hal_sdram.h"#include "stm32h7xx_hal_spi.h"#include "stm32h7xx_hal_spdifrx.h"#include "stm32h7xx_hal_swpmi.h"#include "stm32h7xx_hal_tim.h"#include "stm32h7xx_hal_uart.h"#include "stm32h7xx_hal_usart.h"#include "stm32h7xx_hal_irda.h"#include "stm32h7xx_hal_smartcard.h"#include "stm32h7xx_hal_smbus.h"#include "stm32h7xx_hal_wwdg.h"#include "stm32h7xx_hal_pcd.h"#include "stm32h7xx_hal_hcd.h"Go to the source code of this file.
| #define | HAL_MODULE_ENABLED |
| This is the list of modules to be used in the HAL driver. | |
| #define | HAL_ADC_MODULE_ENABLED |
| #define | HAL_CEC_MODULE_ENABLED |
| #define | HAL_COMP_MODULE_ENABLED |
| #define | HAL_CORDIC_MODULE_ENABLED |
| #define | HAL_CORTEX_MODULE_ENABLED |
| #define | HAL_CRC_MODULE_ENABLED |
| #define | HAL_CRYP_MODULE_ENABLED |
| #define | HAL_DAC_MODULE_ENABLED |
| #define | HAL_DCMI_MODULE_ENABLED |
| #define | HAL_DFSDM_MODULE_ENABLED |
| #define | HAL_DMA_MODULE_ENABLED |
| #define | HAL_DMA2D_MODULE_ENABLED |
| #define | HAL_DTS_MODULE_ENABLED |
| #define | HAL_DSI_MODULE_ENABLED |
| #define | HAL_ETH_MODULE_ENABLED |
| #define | HAL_EXTI_MODULE_ENABLED |
| #define | HAL_FDCAN_MODULE_ENABLED |
| #define | HAL_FLASH_MODULE_ENABLED |
| #define | HAL_GFXMMU_MODULE_ENABLED |
| #define | HAL_FMAC_MODULE_ENABLED |
| #define | HAL_GPIO_MODULE_ENABLED |
| #define | HAL_HASH_MODULE_ENABLED |
| #define | HAL_HCD_MODULE_ENABLED |
| #define | HAL_HRTIM_MODULE_ENABLED |
| #define | HAL_HSEM_MODULE_ENABLED |
| #define | HAL_I2C_MODULE_ENABLED |
| #define | HAL_I2S_MODULE_ENABLED |
| #define | HAL_IRDA_MODULE_ENABLED |
| #define | HAL_IWDG_MODULE_ENABLED |
| #define | HAL_JPEG_MODULE_ENABLED |
| #define | HAL_LPTIM_MODULE_ENABLED |
| #define | HAL_LTDC_MODULE_ENABLED |
| #define | HAL_MDIOS_MODULE_ENABLED |
| #define | HAL_MDMA_MODULE_ENABLED |
| #define | HAL_MMC_MODULE_ENABLED |
| #define | HAL_NAND_MODULE_ENABLED |
| #define | HAL_NOR_MODULE_ENABLED |
| #define | HAL_OPAMP_MODULE_ENABLED |
| #define | HAL_OSPI_MODULE_ENABLED |
| #define | HAL_OTFDEC_MODULE_ENABLED |
| #define | HAL_PCD_MODULE_ENABLED |
| #define | HAL_PWR_MODULE_ENABLED |
| #define | HAL_PSSI_MODULE_ENABLED |
| #define | HAL_QSPI_MODULE_ENABLED |
| #define | HAL_RAMECC_MODULE_ENABLED |
| #define | HAL_RCC_MODULE_ENABLED |
| #define | HAL_RNG_MODULE_ENABLED |
| #define | HAL_RTC_MODULE_ENABLED |
| #define | HAL_SAI_MODULE_ENABLED |
| #define | HAL_SD_MODULE_ENABLED |
| #define | HAL_SDRAM_MODULE_ENABLED |
| #define | HAL_SMARTCARD_MODULE_ENABLED |
| #define | HAL_SMBUS_MODULE_ENABLED |
| #define | HAL_SPDIFRX_MODULE_ENABLED |
| #define | HAL_SPI_MODULE_ENABLED |
| #define | HAL_SRAM_MODULE_ENABLED |
| #define | HAL_SWPMI_MODULE_ENABLED |
| #define | HAL_TIM_MODULE_ENABLED |
| #define | HAL_UART_MODULE_ENABLED |
| #define | HAL_USART_MODULE_ENABLED |
| #define | HAL_WWDG_MODULE_ENABLED |
| #define | HSE_VALUE (25000000UL) |
| Adjust the value of External High Speed oscillator (HSE) used in your application. This value is used by the RCC HAL module to compute the system frequency (when HSE is used as system clock source, directly or through the PLL). | |
| #define | HSE_STARTUP_TIMEOUT (100UL) |
| #define | CSI_VALUE (4000000UL) |
| Internal oscillator (CSI) default value. This value is the default CSI value after Reset. | |
| #define | HSI_VALUE (64000000UL) |
| Internal High Speed oscillator (HSI) value. This value is used by the RCC HAL module to compute the system frequency (when HSI is used as system clock source, directly or through the PLL). | |
| #define | LSE_VALUE (32768UL) |
| External Low Speed oscillator (LSE) value. This value is used by the UART, RTC HAL module to compute the system frequency. | |
| #define | LSE_STARTUP_TIMEOUT (5000UL) |
| #define | LSI_VALUE (32000UL) |
| #define | EXTERNAL_CLOCK_VALUE 12288000UL |
| External clock source for I2S peripheral This value is used by the I2S HAL module to compute the I2S clock source frequency, this source is inserted directly through I2S_CKIN pad. | |
| #define | VDD_VALUE (3300UL) |
| This is the HAL system configuration section. | |
| #define | TICK_INT_PRIORITY (0x0FUL) |
| #define | USE_RTOS 0 |
| #define | USE_SD_TRANSCEIVER 0U |
| #define | USE_SPI_CRC 1U |
| #define | USE_FLASH_ECC 0U |
| #define | USE_HAL_ADC_REGISTER_CALLBACKS 0U /* ADC register callback disabled */ |
| #define | USE_HAL_CEC_REGISTER_CALLBACKS 0U /* CEC register callback disabled */ |
| #define | USE_HAL_COMP_REGISTER_CALLBACKS 0U /* COMP register callback disabled */ |
| #define | USE_HAL_CORDIC_REGISTER_CALLBACKS 0U /* CORDIC register callback disabled */ |
| #define | USE_HAL_CRYP_REGISTER_CALLBACKS 0U /* CRYP register callback disabled */ |
| #define | USE_HAL_DAC_REGISTER_CALLBACKS 0U /* DAC register callback disabled */ |
| #define | USE_HAL_DCMI_REGISTER_CALLBACKS 0U /* DCMI register callback disabled */ |
| #define | USE_HAL_DFSDM_REGISTER_CALLBACKS 0U /* DFSDM register callback disabled */ |
| #define | USE_HAL_DMA2D_REGISTER_CALLBACKS 0U /* DMA2D register callback disabled */ |
| #define | USE_HAL_DSI_REGISTER_CALLBACKS 0U /* DSI register callback disabled */ |
| #define | USE_HAL_DTS_REGISTER_CALLBACKS 0U /* DTS register callback disabled */ |
| #define | USE_HAL_ETH_REGISTER_CALLBACKS 0U /* ETH register callback disabled */ |
| #define | USE_HAL_FDCAN_REGISTER_CALLBACKS 0U /* FDCAN register callback disabled */ |
| #define | USE_HAL_FMAC_REGISTER_CALLBACKS 0U /* FMAC register callback disabled */ |
| #define | USE_HAL_NAND_REGISTER_CALLBACKS 0U /* NAND register callback disabled */ |
| #define | USE_HAL_NOR_REGISTER_CALLBACKS 0U /* NOR register callback disabled */ |
| #define | USE_HAL_SDRAM_REGISTER_CALLBACKS 0U /* SDRAM register callback disabled */ |
| #define | USE_HAL_SRAM_REGISTER_CALLBACKS 0U /* SRAM register callback disabled */ |
| #define | USE_HAL_HASH_REGISTER_CALLBACKS 0U /* HASH register callback disabled */ |
| #define | USE_HAL_HCD_REGISTER_CALLBACKS 0U /* HCD register callback disabled */ |
| #define | USE_HAL_GFXMMU_REGISTER_CALLBACKS 0U /* GFXMMU register callback disabled */ |
| #define | USE_HAL_HRTIM_REGISTER_CALLBACKS 0U /* HRTIM register callback disabled */ |
| #define | USE_HAL_I2C_REGISTER_CALLBACKS 0U /* I2C register callback disabled */ |
| #define | USE_HAL_I2S_REGISTER_CALLBACKS 0U /* I2S register callback disabled */ |
| #define | USE_HAL_IRDA_REGISTER_CALLBACKS 0U /* IRDA register callback disabled */ |
| #define | USE_HAL_JPEG_REGISTER_CALLBACKS 0U /* JPEG register callback disabled */ |
| #define | USE_HAL_LPTIM_REGISTER_CALLBACKS 0U /* LPTIM register callback disabled */ |
| #define | USE_HAL_LTDC_REGISTER_CALLBACKS 0U /* LTDC register callback disabled */ |
| #define | USE_HAL_MDIOS_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */ |
| #define | USE_HAL_MMC_REGISTER_CALLBACKS 0U /* MMC register callback disabled */ |
| #define | USE_HAL_OPAMP_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */ |
| #define | USE_HAL_OSPI_REGISTER_CALLBACKS 0U /* OSPI register callback disabled */ |
| #define | USE_HAL_OTFDEC_REGISTER_CALLBACKS 0U /* OTFDEC register callback disabled */ |
| #define | USE_HAL_PCD_REGISTER_CALLBACKS 0U /* PCD register callback disabled */ |
| #define | USE_HAL_QSPI_REGISTER_CALLBACKS 0U /* QSPI register callback disabled */ |
| #define | USE_HAL_RNG_REGISTER_CALLBACKS 0U /* RNG register callback disabled */ |
| #define | USE_HAL_RTC_REGISTER_CALLBACKS 0U /* RTC register callback disabled */ |
| #define | USE_HAL_SAI_REGISTER_CALLBACKS 0U /* SAI register callback disabled */ |
| #define | USE_HAL_SD_REGISTER_CALLBACKS 0U /* SD register callback disabled */ |
| #define | USE_HAL_SMARTCARD_REGISTER_CALLBACKS 0U /* SMARTCARD register callback disabled */ |
| #define | USE_HAL_SPDIFRX_REGISTER_CALLBACKS 0U /* SPDIFRX register callback disabled */ |
| #define | USE_HAL_SMBUS_REGISTER_CALLBACKS 0U /* SMBUS register callback disabled */ |
| #define | USE_HAL_SPI_REGISTER_CALLBACKS 0U /* SPI register callback disabled */ |
| #define | USE_HAL_SWPMI_REGISTER_CALLBACKS 0U /* SWPMI register callback disabled */ |
| #define | USE_HAL_TIM_REGISTER_CALLBACKS 0U /* TIM register callback disabled */ |
| #define | USE_HAL_UART_REGISTER_CALLBACKS 0U /* UART register callback disabled */ |
| #define | USE_HAL_USART_REGISTER_CALLBACKS 0U /* USART register callback disabled */ |
| #define | USE_HAL_WWDG_REGISTER_CALLBACKS 0U /* WWDG register callback disabled */ |
| #define | ETH_TX_DESC_CNT 4U /* number of Ethernet Tx DMA descriptors */ |
| #define | ETH_RX_DESC_CNT 4U /* number of Ethernet Rx DMA descriptors */ |
| #define | ETH_MAC_ADDR0 (0x02UL) |
| #define | ETH_MAC_ADDR1 (0x00UL) |
| #define | ETH_MAC_ADDR2 (0x00UL) |
| #define | ETH_MAC_ADDR3 (0x00UL) |
| #define | ETH_MAC_ADDR4 (0x00UL) |
| #define | ETH_MAC_ADDR5 (0x00UL) |
| #define | assert_param(expr) ((void)0U) |
| Uncomment the line below to expanse the "assert_param" macro in the HAL drivers code. | |
| #define assert_param | ( | expr | ) | ((void)0U) |
Include module's header file
| #define CSI_VALUE (4000000UL) |
Value of the Internal oscillator in Hz
| #define EXTERNAL_CLOCK_VALUE 12288000UL |
< Value of the Internal Low Speed oscillator in Hz The real value may vary depending on the variations in voltage and temperature. Value of the External clock in Hz
| #define HSE_STARTUP_TIMEOUT (100UL) |
Time out for HSE start up, in ms
| #define HSE_VALUE (25000000UL) |
Value of the External oscillator in Hz
| #define HSI_VALUE (64000000UL) |
| #define LSE_STARTUP_TIMEOUT (5000UL) |
Time out for LSE start up, in ms
| #define LSE_VALUE (32768UL) |
| #define LSI_VALUE (32000UL) |
LSI Typical Value in Hz
| #define TICK_INT_PRIORITY (0x0FUL) |
tick interrupt priority
| #define USE_FLASH_ECC 0U |
use ECC error management in FLASH
| #define USE_SD_TRANSCEIVER 0U |
use uSD Transceiver
| #define USE_SPI_CRC 1U |
use CRC in SPI
| #define VDD_VALUE (3300UL) |
Value of VDD in mv
