RTEMS 6.1
stm32h7xx_hal_conf_template.h
1
21/* Define to prevent recursive inclusion -------------------------------------*/
22#ifndef STM32H7xx_HAL_CONF_H
23#define STM32H7xx_HAL_CONF_H
24
25#ifdef __cplusplus
26 extern "C" {
27#endif
28
29/* Exported types ------------------------------------------------------------*/
30/* Exported constants --------------------------------------------------------*/
31
32/* ########################## Module Selection ############################## */
36#define HAL_MODULE_ENABLED
37#define HAL_ADC_MODULE_ENABLED
38#define HAL_CEC_MODULE_ENABLED
39#define HAL_COMP_MODULE_ENABLED
40#define HAL_CORDIC_MODULE_ENABLED
41#define HAL_CORTEX_MODULE_ENABLED
42#define HAL_CRC_MODULE_ENABLED
43#define HAL_CRYP_MODULE_ENABLED
44#define HAL_DAC_MODULE_ENABLED
45#define HAL_DCMI_MODULE_ENABLED
46#define HAL_DFSDM_MODULE_ENABLED
47#define HAL_DMA_MODULE_ENABLED
48#define HAL_DMA2D_MODULE_ENABLED
49#define HAL_DTS_MODULE_ENABLED
50#define HAL_DSI_MODULE_ENABLED
51#define HAL_ETH_MODULE_ENABLED
52/* #define HAL_ETH_LEGACY_MODULE_ENABLED */
53#define HAL_EXTI_MODULE_ENABLED
54#define HAL_FDCAN_MODULE_ENABLED
55#define HAL_FLASH_MODULE_ENABLED
56#define HAL_GFXMMU_MODULE_ENABLED
57#define HAL_FMAC_MODULE_ENABLED
58#define HAL_GPIO_MODULE_ENABLED
59#define HAL_HASH_MODULE_ENABLED
60#define HAL_HCD_MODULE_ENABLED
61#define HAL_HRTIM_MODULE_ENABLED
62#define HAL_HSEM_MODULE_ENABLED
63#define HAL_I2C_MODULE_ENABLED
64#define HAL_I2S_MODULE_ENABLED
65#define HAL_IRDA_MODULE_ENABLED
66#define HAL_IWDG_MODULE_ENABLED
67#define HAL_JPEG_MODULE_ENABLED
68#define HAL_LPTIM_MODULE_ENABLED
69#define HAL_LTDC_MODULE_ENABLED
70#define HAL_MDIOS_MODULE_ENABLED
71#define HAL_MDMA_MODULE_ENABLED
72#define HAL_MMC_MODULE_ENABLED
73#define HAL_NAND_MODULE_ENABLED
74#define HAL_NOR_MODULE_ENABLED
75#define HAL_OPAMP_MODULE_ENABLED
76#define HAL_OSPI_MODULE_ENABLED
77#define HAL_OTFDEC_MODULE_ENABLED
78#define HAL_PCD_MODULE_ENABLED
79#define HAL_PWR_MODULE_ENABLED
80#define HAL_PSSI_MODULE_ENABLED
81#define HAL_QSPI_MODULE_ENABLED
82#define HAL_RAMECC_MODULE_ENABLED
83#define HAL_RCC_MODULE_ENABLED
84#define HAL_RNG_MODULE_ENABLED
85#define HAL_RTC_MODULE_ENABLED
86#define HAL_SAI_MODULE_ENABLED
87#define HAL_SD_MODULE_ENABLED
88#define HAL_SDRAM_MODULE_ENABLED
89#define HAL_SMARTCARD_MODULE_ENABLED
90#define HAL_SMBUS_MODULE_ENABLED
91#define HAL_SPDIFRX_MODULE_ENABLED
92#define HAL_SPI_MODULE_ENABLED
93#define HAL_SRAM_MODULE_ENABLED
94#define HAL_SWPMI_MODULE_ENABLED
95#define HAL_TIM_MODULE_ENABLED
96#define HAL_UART_MODULE_ENABLED
97#define HAL_USART_MODULE_ENABLED
98#define HAL_WWDG_MODULE_ENABLED
99
100/* ########################## Oscillator Values adaptation ####################*/
106#if !defined (HSE_VALUE)
107#define HSE_VALUE (25000000UL)
108#endif /* HSE_VALUE */
109
110#if !defined (HSE_STARTUP_TIMEOUT)
111 #define HSE_STARTUP_TIMEOUT (100UL)
112#endif /* HSE_STARTUP_TIMEOUT */
113
118#if !defined (CSI_VALUE)
119 #define CSI_VALUE (4000000UL)
120#endif /* CSI_VALUE */
121
127#if !defined (HSI_VALUE)
128 #define HSI_VALUE (64000000UL)
129#endif /* HSI_VALUE */
130
135#if !defined (LSE_VALUE)
136 #define LSE_VALUE (32768UL)
137#endif /* LSE_VALUE */
138
139
140#if !defined (LSE_STARTUP_TIMEOUT)
141 #define LSE_STARTUP_TIMEOUT (5000UL)
142#endif /* LSE_STARTUP_TIMEOUT */
143
144#if !defined (LSI_VALUE)
145 #define LSI_VALUE (32000UL)
146#endif /* LSI_VALUE */
155#if !defined (EXTERNAL_CLOCK_VALUE)
156 #define EXTERNAL_CLOCK_VALUE 12288000UL
157#endif /* EXTERNAL_CLOCK_VALUE */
158
159/* Tip: To avoid modifying this file each time you need to use different HSE,
160 === you can define the HSE value in your toolchain compiler preprocessor. */
161
162/* ########################### System Configuration ######################### */
166#define VDD_VALUE (3300UL)
167#define TICK_INT_PRIORITY (0x0FUL)
168#define USE_RTOS 0
169#define USE_SD_TRANSCEIVER 0U
170#define USE_SPI_CRC 1U
171#define USE_FLASH_ECC 0U
173#define USE_HAL_ADC_REGISTER_CALLBACKS 0U /* ADC register callback disabled */
174#define USE_HAL_CEC_REGISTER_CALLBACKS 0U /* CEC register callback disabled */
175#define USE_HAL_COMP_REGISTER_CALLBACKS 0U /* COMP register callback disabled */
176#define USE_HAL_CORDIC_REGISTER_CALLBACKS 0U /* CORDIC register callback disabled */
177#define USE_HAL_CRYP_REGISTER_CALLBACKS 0U /* CRYP register callback disabled */
178#define USE_HAL_DAC_REGISTER_CALLBACKS 0U /* DAC register callback disabled */
179#define USE_HAL_DCMI_REGISTER_CALLBACKS 0U /* DCMI register callback disabled */
180#define USE_HAL_DFSDM_REGISTER_CALLBACKS 0U /* DFSDM register callback disabled */
181#define USE_HAL_DMA2D_REGISTER_CALLBACKS 0U /* DMA2D register callback disabled */
182#define USE_HAL_DSI_REGISTER_CALLBACKS 0U /* DSI register callback disabled */
183#define USE_HAL_DTS_REGISTER_CALLBACKS 0U /* DTS register callback disabled */
184#define USE_HAL_ETH_REGISTER_CALLBACKS 0U /* ETH register callback disabled */
185#define USE_HAL_FDCAN_REGISTER_CALLBACKS 0U /* FDCAN register callback disabled */
186#define USE_HAL_FMAC_REGISTER_CALLBACKS 0U /* FMAC register callback disabled */
187#define USE_HAL_NAND_REGISTER_CALLBACKS 0U /* NAND register callback disabled */
188#define USE_HAL_NOR_REGISTER_CALLBACKS 0U /* NOR register callback disabled */
189#define USE_HAL_SDRAM_REGISTER_CALLBACKS 0U /* SDRAM register callback disabled */
190#define USE_HAL_SRAM_REGISTER_CALLBACKS 0U /* SRAM register callback disabled */
191#define USE_HAL_HASH_REGISTER_CALLBACKS 0U /* HASH register callback disabled */
192#define USE_HAL_HCD_REGISTER_CALLBACKS 0U /* HCD register callback disabled */
193#define USE_HAL_GFXMMU_REGISTER_CALLBACKS 0U /* GFXMMU register callback disabled */
194#define USE_HAL_HRTIM_REGISTER_CALLBACKS 0U /* HRTIM register callback disabled */
195#define USE_HAL_I2C_REGISTER_CALLBACKS 0U /* I2C register callback disabled */
196#define USE_HAL_I2S_REGISTER_CALLBACKS 0U /* I2S register callback disabled */
197#define USE_HAL_IRDA_REGISTER_CALLBACKS 0U /* IRDA register callback disabled */
198#define USE_HAL_JPEG_REGISTER_CALLBACKS 0U /* JPEG register callback disabled */
199#define USE_HAL_LPTIM_REGISTER_CALLBACKS 0U /* LPTIM register callback disabled */
200#define USE_HAL_LTDC_REGISTER_CALLBACKS 0U /* LTDC register callback disabled */
201#define USE_HAL_MDIOS_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */
202#define USE_HAL_MMC_REGISTER_CALLBACKS 0U /* MMC register callback disabled */
203#define USE_HAL_OPAMP_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */
204#define USE_HAL_OSPI_REGISTER_CALLBACKS 0U /* OSPI register callback disabled */
205#define USE_HAL_OTFDEC_REGISTER_CALLBACKS 0U /* OTFDEC register callback disabled */
206#define USE_HAL_PCD_REGISTER_CALLBACKS 0U /* PCD register callback disabled */
207#define USE_HAL_QSPI_REGISTER_CALLBACKS 0U /* QSPI register callback disabled */
208#define USE_HAL_RNG_REGISTER_CALLBACKS 0U /* RNG register callback disabled */
209#define USE_HAL_RTC_REGISTER_CALLBACKS 0U /* RTC register callback disabled */
210#define USE_HAL_SAI_REGISTER_CALLBACKS 0U /* SAI register callback disabled */
211#define USE_HAL_SD_REGISTER_CALLBACKS 0U /* SD register callback disabled */
212#define USE_HAL_SMARTCARD_REGISTER_CALLBACKS 0U /* SMARTCARD register callback disabled */
213#define USE_HAL_SPDIFRX_REGISTER_CALLBACKS 0U /* SPDIFRX register callback disabled */
214#define USE_HAL_SMBUS_REGISTER_CALLBACKS 0U /* SMBUS register callback disabled */
215#define USE_HAL_SPI_REGISTER_CALLBACKS 0U /* SPI register callback disabled */
216#define USE_HAL_SWPMI_REGISTER_CALLBACKS 0U /* SWPMI register callback disabled */
217#define USE_HAL_TIM_REGISTER_CALLBACKS 0U /* TIM register callback disabled */
218#define USE_HAL_UART_REGISTER_CALLBACKS 0U /* UART register callback disabled */
219#define USE_HAL_USART_REGISTER_CALLBACKS 0U /* USART register callback disabled */
220#define USE_HAL_WWDG_REGISTER_CALLBACKS 0U /* WWDG register callback disabled */
221
222/* ########################### Ethernet Configuration ######################### */
223#define ETH_TX_DESC_CNT 4U /* number of Ethernet Tx DMA descriptors */
224#define ETH_RX_DESC_CNT 4U /* number of Ethernet Rx DMA descriptors */
225
226#define ETH_MAC_ADDR0 (0x02UL)
227#define ETH_MAC_ADDR1 (0x00UL)
228#define ETH_MAC_ADDR2 (0x00UL)
229#define ETH_MAC_ADDR3 (0x00UL)
230#define ETH_MAC_ADDR4 (0x00UL)
231#define ETH_MAC_ADDR5 (0x00UL)
232
233/* ########################## Assert Selection ############################## */
238/* #define USE_FULL_ASSERT 1 */
239
240
241/* Includes ------------------------------------------------------------------*/
246#ifdef HAL_RCC_MODULE_ENABLED
247 #include "stm32h7xx_hal_rcc.h"
248#endif /* HAL_RCC_MODULE_ENABLED */
249
250#ifdef HAL_GPIO_MODULE_ENABLED
251 #include "stm32h7xx_hal_gpio.h"
252#endif /* HAL_GPIO_MODULE_ENABLED */
253
254#ifdef HAL_DMA_MODULE_ENABLED
255 #include "stm32h7xx_hal_dma.h"
256#endif /* HAL_DMA_MODULE_ENABLED */
257
258#ifdef HAL_MDMA_MODULE_ENABLED
259 #include "stm32h7xx_hal_mdma.h"
260#endif /* HAL_MDMA_MODULE_ENABLED */
261
262#ifdef HAL_HASH_MODULE_ENABLED
263 #include "stm32h7xx_hal_hash.h"
264#endif /* HAL_HASH_MODULE_ENABLED */
265
266#ifdef HAL_DCMI_MODULE_ENABLED
267 #include "stm32h7xx_hal_dcmi.h"
268#endif /* HAL_DCMI_MODULE_ENABLED */
269
270#ifdef HAL_DMA2D_MODULE_ENABLED
271 #include "stm32h7xx_hal_dma2d.h"
272#endif /* HAL_DMA2D_MODULE_ENABLED */
273
274#ifdef HAL_DSI_MODULE_ENABLED
275 #include "stm32h7xx_hal_dsi.h"
276#endif /* HAL_DSI_MODULE_ENABLED */
277
278#ifdef HAL_DFSDM_MODULE_ENABLED
279 #include "stm32h7xx_hal_dfsdm.h"
280#endif /* HAL_DFSDM_MODULE_ENABLED */
281
282#ifdef HAL_DTS_MODULE_ENABLED
283 #include "stm32h7xx_hal_dts.h"
284#endif /* HAL_DTS_MODULE_ENABLED */
285
286#ifdef HAL_ETH_MODULE_ENABLED
287 #include "stm32h7xx_hal_eth.h"
288#endif /* HAL_ETH_MODULE_ENABLED */
289
290#ifdef HAL_ETH_LEGACY_MODULE_ENABLED
292#endif /* HAL_ETH_LEGACY_MODULE_ENABLED */
293
294#ifdef HAL_EXTI_MODULE_ENABLED
295 #include "stm32h7xx_hal_exti.h"
296#endif /* HAL_EXTI_MODULE_ENABLED */
297
298#ifdef HAL_CORTEX_MODULE_ENABLED
299 #include "stm32h7xx_hal_cortex.h"
300#endif /* HAL_CORTEX_MODULE_ENABLED */
301
302#ifdef HAL_ADC_MODULE_ENABLED
303 #include "stm32h7xx_hal_adc.h"
304#endif /* HAL_ADC_MODULE_ENABLED */
305
306#ifdef HAL_FDCAN_MODULE_ENABLED
307 #include "stm32h7xx_hal_fdcan.h"
308#endif /* HAL_FDCAN_MODULE_ENABLED */
309
310#ifdef HAL_CEC_MODULE_ENABLED
311 #include "stm32h7xx_hal_cec.h"
312#endif /* HAL_CEC_MODULE_ENABLED */
313
314#ifdef HAL_COMP_MODULE_ENABLED
315 #include "stm32h7xx_hal_comp.h"
316#endif /* HAL_COMP_MODULE_ENABLED */
317
318#ifdef HAL_CORDIC_MODULE_ENABLED
319 #include "stm32h7xx_hal_cordic.h"
320#endif /* HAL_CORDIC_MODULE_ENABLED */
321
322#ifdef HAL_CRC_MODULE_ENABLED
323 #include "stm32h7xx_hal_crc.h"
324#endif /* HAL_CRC_MODULE_ENABLED */
325
326#ifdef HAL_CRYP_MODULE_ENABLED
327 #include "stm32h7xx_hal_cryp.h"
328#endif /* HAL_CRYP_MODULE_ENABLED */
329
330#ifdef HAL_DAC_MODULE_ENABLED
331 #include "stm32h7xx_hal_dac.h"
332#endif /* HAL_DAC_MODULE_ENABLED */
333
334#ifdef HAL_FLASH_MODULE_ENABLED
335 #include "stm32h7xx_hal_flash.h"
336#endif /* HAL_FLASH_MODULE_ENABLED */
337
338#ifdef HAL_GFXMMU_MODULE_ENABLED
339 #include "stm32h7xx_hal_gfxmmu.h"
340#endif /* HAL_GFXMMU_MODULE_ENABLED */
341
342#ifdef HAL_FMAC_MODULE_ENABLED
343 #include "stm32h7xx_hal_fmac.h"
344#endif /* HAL_FMAC_MODULE_ENABLED */
345
346#ifdef HAL_HRTIM_MODULE_ENABLED
347 #include "stm32h7xx_hal_hrtim.h"
348#endif /* HAL_HRTIM_MODULE_ENABLED */
349
350#ifdef HAL_HSEM_MODULE_ENABLED
351 #include "stm32h7xx_hal_hsem.h"
352#endif /* HAL_HSEM_MODULE_ENABLED */
353
354#ifdef HAL_SRAM_MODULE_ENABLED
355 #include "stm32h7xx_hal_sram.h"
356#endif /* HAL_SRAM_MODULE_ENABLED */
357
358#ifdef HAL_NOR_MODULE_ENABLED
359 #include "stm32h7xx_hal_nor.h"
360#endif /* HAL_NOR_MODULE_ENABLED */
361
362#ifdef HAL_NAND_MODULE_ENABLED
363 #include "stm32h7xx_hal_nand.h"
364#endif /* HAL_NAND_MODULE_ENABLED */
365
366#ifdef HAL_I2C_MODULE_ENABLED
367 #include "stm32h7xx_hal_i2c.h"
368#endif /* HAL_I2C_MODULE_ENABLED */
369
370#ifdef HAL_I2S_MODULE_ENABLED
371 #include "stm32h7xx_hal_i2s.h"
372#endif /* HAL_I2S_MODULE_ENABLED */
373
374#ifdef HAL_IWDG_MODULE_ENABLED
375 #include "stm32h7xx_hal_iwdg.h"
376#endif /* HAL_IWDG_MODULE_ENABLED */
377
378#ifdef HAL_JPEG_MODULE_ENABLED
379 #include "stm32h7xx_hal_jpeg.h"
380#endif /* HAL_JPEG_MODULE_ENABLED */
381
382#ifdef HAL_MDIOS_MODULE_ENABLED
383 #include "stm32h7xx_hal_mdios.h"
384#endif /* HAL_MDIOS_MODULE_ENABLED */
385
386#ifdef HAL_MMC_MODULE_ENABLED
387 #include "stm32h7xx_hal_mmc.h"
388#endif /* HAL_MMC_MODULE_ENABLED */
389
390#ifdef HAL_LPTIM_MODULE_ENABLED
391#include "stm32h7xx_hal_lptim.h"
392#endif /* HAL_LPTIM_MODULE_ENABLED */
393
394#ifdef HAL_LTDC_MODULE_ENABLED
395#include "stm32h7xx_hal_ltdc.h"
396#endif /* HAL_LTDC_MODULE_ENABLED */
397
398#ifdef HAL_OPAMP_MODULE_ENABLED
399#include "stm32h7xx_hal_opamp.h"
400#endif /* HAL_OPAMP_MODULE_ENABLED */
401
402#ifdef HAL_OSPI_MODULE_ENABLED
403 #include "stm32h7xx_hal_ospi.h"
404#endif /* HAL_OSPI_MODULE_ENABLED */
405
406#ifdef HAL_OTFDEC_MODULE_ENABLED
407#include "stm32h7xx_hal_otfdec.h"
408#endif /* HAL_OTFDEC_MODULE_ENABLED */
409
410#ifdef HAL_PSSI_MODULE_ENABLED
411 #include "stm32h7xx_hal_pssi.h"
412#endif /* HAL_PSSI_MODULE_ENABLED */
413
414#ifdef HAL_PWR_MODULE_ENABLED
415 #include "stm32h7xx_hal_pwr.h"
416#endif /* HAL_PWR_MODULE_ENABLED */
417
418#ifdef HAL_QSPI_MODULE_ENABLED
419 #include "stm32h7xx_hal_qspi.h"
420#endif /* HAL_QSPI_MODULE_ENABLED */
421
422#ifdef HAL_RAMECC_MODULE_ENABLED
423 #include "stm32h7xx_hal_ramecc.h"
424#endif /* HAL_RAMECC_MODULE_ENABLED */
425
426#ifdef HAL_RNG_MODULE_ENABLED
427 #include "stm32h7xx_hal_rng.h"
428#endif /* HAL_RNG_MODULE_ENABLED */
429
430#ifdef HAL_RTC_MODULE_ENABLED
431 #include "stm32h7xx_hal_rtc.h"
432#endif /* HAL_RTC_MODULE_ENABLED */
433
434#ifdef HAL_SAI_MODULE_ENABLED
435 #include "stm32h7xx_hal_sai.h"
436#endif /* HAL_SAI_MODULE_ENABLED */
437
438#ifdef HAL_SD_MODULE_ENABLED
439 #include "stm32h7xx_hal_sd.h"
440#endif /* HAL_SD_MODULE_ENABLED */
441
442#ifdef HAL_SDRAM_MODULE_ENABLED
443 #include "stm32h7xx_hal_sdram.h"
444#endif /* HAL_SDRAM_MODULE_ENABLED */
445
446#ifdef HAL_SPI_MODULE_ENABLED
447 #include "stm32h7xx_hal_spi.h"
448#endif /* HAL_SPI_MODULE_ENABLED */
449
450#ifdef HAL_SPDIFRX_MODULE_ENABLED
451 #include "stm32h7xx_hal_spdifrx.h"
452#endif /* HAL_SPDIFRX_MODULE_ENABLED */
453
454#ifdef HAL_SWPMI_MODULE_ENABLED
455 #include "stm32h7xx_hal_swpmi.h"
456#endif /* HAL_SWPMI_MODULE_ENABLED */
457
458#ifdef HAL_TIM_MODULE_ENABLED
459 #include "stm32h7xx_hal_tim.h"
460#endif /* HAL_TIM_MODULE_ENABLED */
461
462#ifdef HAL_UART_MODULE_ENABLED
463 #include "stm32h7xx_hal_uart.h"
464#endif /* HAL_UART_MODULE_ENABLED */
465
466#ifdef HAL_USART_MODULE_ENABLED
467 #include "stm32h7xx_hal_usart.h"
468#endif /* HAL_USART_MODULE_ENABLED */
469
470#ifdef HAL_IRDA_MODULE_ENABLED
471 #include "stm32h7xx_hal_irda.h"
472#endif /* HAL_IRDA_MODULE_ENABLED */
473
474#ifdef HAL_SMARTCARD_MODULE_ENABLED
476#endif /* HAL_SMARTCARD_MODULE_ENABLED */
477
478#ifdef HAL_SMBUS_MODULE_ENABLED
479 #include "stm32h7xx_hal_smbus.h"
480#endif /* HAL_SMBUS_MODULE_ENABLED */
481
482#ifdef HAL_WWDG_MODULE_ENABLED
483 #include "stm32h7xx_hal_wwdg.h"
484#endif /* HAL_WWDG_MODULE_ENABLED */
485
486#ifdef HAL_PCD_MODULE_ENABLED
487 #include "stm32h7xx_hal_pcd.h"
488#endif /* HAL_PCD_MODULE_ENABLED */
489
490#ifdef HAL_HCD_MODULE_ENABLED
491 #include "stm32h7xx_hal_hcd.h"
492#endif /* HAL_HCD_MODULE_ENABLED */
493
494/* Exported macro ------------------------------------------------------------*/
495#ifdef USE_FULL_ASSERT
504 #define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
505/* Exported functions ------------------------------------------------------- */
506 void assert_failed(uint8_t *file, uint32_t line);
507#else
508 #define assert_param(expr) ((void)0U)
509#endif /* USE_FULL_ASSERT */
510
511#ifdef __cplusplus
512}
513#endif
514
515#endif /* STM32H7xx_HAL_CONF_H */
516
517
518
Header file of ADC HAL module.
Header file of CEC HAL module.
Header file of COMP HAL module.
This file contains all the functions prototypes for the CORDIC firmware library.
Header file of CORTEX HAL module.
Header file of CRC HAL module.
Header file of CRYP HAL module.
Header file of DAC HAL module.
Header file of DCMI HAL module.
Header file of DFSDM HAL module.
Header file of DMA2D HAL module.
Header file of DMA HAL module.
Header file of DSI HAL module.
Header file of DTS HAL module.
Header file of ETH HAL module.
Header file of EXTI HAL module.
Header file of FDCAN HAL module.
Header file of FLASH HAL module.
Header for stm32h7xx_hal_fmac.c module.
Header file of GFXMMU HAL module.
Header file of GPIO HAL module.
Header file of HASH HAL module.
Header file of HCD HAL module.
Header file of HRTIM HAL module.
Header file of HSEM HAL module.
Header file of I2C HAL module.
Header file of I2S HAL module.
Header file of IRDA HAL module.
Header file of IWDG HAL module.
Header file of JPEG HAL module.
Header file of LPTIM HAL module.
Header file of LTDC HAL module.
Header file of MDIOS HAL module.
Header file of MMC HAL module.
Header file of NAND HAL module.
Header file of NOR HAL module.
Header file of OPAMP HAL module.
Header file of OSPI HAL module.
Header file of OTFDEC HAL module.
Header file of PCD HAL module.
Header file of PSSI HAL module.
Header file of PWR HAL module.
Header file of QSPI HAL module.
Header file of RAMECC HAL module.
Header file of RCC HAL module.
Header file of RNG HAL module.
Header file of RTC HAL module.
Header file of SAI HAL module.
Header file of SD HAL module.
Header file of SDRAM HAL module.
Header file of SMARTCARD HAL module.
Header file of SMBUS HAL module.
Header file of SPDIFRX HAL module.
Header file of SPI HAL module.
Header file of SRAM HAL module.
Header file of SWPMI HAL module.
Header file of TIM HAL module.
Header file of UART HAL module.
Header file of USART HAL module.
Header file of WWDG HAL module.
Definition: mongoose.c:448
