RTEMS 5.2-rc1
tms570_selftest_parity.h File Reference
Check of module parity based protection logic to work. More...
#include <stdint.h>
struct  tms570_selftest_par_desc
#define TMS570_SELFTEST_PAR_CR_KEY   0xA
typedef struct tms570_selftest_par_desc tms570_selftest_par_desc_t
typedef void tms570_selftest_par_fnc_t(const tms570_selftest_par_desc_t *desc)
void tms570_selftest_par_check_std (const tms570_selftest_par_desc_t *desc)
 run test to check that parity protection works for modules with common setup structure. More...
void tms570_selftest_par_check_can (const tms570_selftest_par_desc_t *desc)
 run test to check that parity protection works for CAN modules RAM More...
void tms570_selftest_par_check_mibspi (const tms570_selftest_par_desc_t *desc)
 run test to check that parity protection works for MibSPI modules RAM More...
void tms570_selftest_par_run (const tms570_selftest_par_desc_t *const *desc_arr, int desc_cnt)
 run parity protection mechanism check for set of modules described by list. More...
const tms570_selftest_par_desc_t tms570_selftest_par_het1_desc
const tms570_selftest_par_desc_t tms570_selftest_par_htu1_desc
const tms570_selftest_par_desc_t tms570_selftest_par_het2_desc
const tms570_selftest_par_desc_t tms570_selftest_par_htu2_desc
const tms570_selftest_par_desc_t tms570_selftest_par_adc1_desc
const tms570_selftest_par_desc_t tms570_selftest_par_adc2_desc
const tms570_selftest_par_desc_t tms570_selftest_par_can1_desc
const tms570_selftest_par_desc_t tms570_selftest_par_can2_desc
const tms570_selftest_par_desc_t tms570_selftest_par_can3_desc
const tms570_selftest_par_desc_t tms570_selftest_par_vim_desc
const tms570_selftest_par_desc_t tms570_selftest_par_dma_desc
const tms570_selftest_par_desc_t tms570_selftest_par_spi1_desc
const tms570_selftest_par_desc_t tms570_selftest_par_spi3_desc
const tms570_selftest_par_desc_t tms570_selftest_par_spi5_desc
const tms570_selftest_par_desc_t *const tms570_selftest_par_list []
const int tms570_selftest_par_list_size
◆ TMS570_SELFTEST_PAR_CR_KEY
The magic number used to switch most of the peripherals into parity protection test mode
◆ tms570_selftest_par_check_can()
void tms570_selftest_par_check_can ( const tms570_selftest_par_desc_t desc)
Parameters
[in]descmodule registers addresses end ESM channels descriptor
Returns
Void, in the case of error invokes bsp_selftest_fail_notification()
The descriptor provides address of the module registers and address of internal RAM memory and corresponding parity area test access window.
◆ tms570_selftest_par_check_mibspi()
void tms570_selftest_par_check_mibspi ( const tms570_selftest_par_desc_t desc)
Parameters
Returns
◆ tms570_selftest_par_check_std()
void tms570_selftest_par_check_std ( const tms570_selftest_par_desc_t desc)
Parameters
Returns
The descriptor provides address of the module registers and address of internal RAM memory and corresponding parity area test access window. This test function is usable for HETx, HTUx, ADC, DMA and VIM TMS570 peripherals.
◆ tms570_selftest_par_run()
void tms570_selftest_par_run ( const tms570_selftest_par_desc_t *const *  desc_arr,
int  desc_cnt
Parameters
[in]desc_arrarray of pointers to descriptors providing addresses and ESM channels for individual peripherals.
[in]desc_cntcount of pointers in the array
Returns
