RTEMS 5.2-rc1
Modules | Files | Macros
TMS570 Board Support Package. More...
 System Clocks
 System clocks.
file  clock.c
 clock functions definitions.
file  printk-support.c
 definitions of serial line for debugging.
file  tms570-sci.c
 Serial communication interface (SCI) functions definitions.
file  bsp.h
 Global BSP definitions.
file  irq.h
 TMS570 interrupt definitions.
file  system-clocks.h
 System clocks.
file  tms570-pinmux.h
 I/O Multiplexing Module (IOMM) basic support.
file  tms570-pins.h
 Select pin mapping according to selected chip. Defaults to TMS570LS3137ZWT for now.
file  tms570-pom.h
 Parameter Overlay Module (POM) header file.
file  tms570-rti.h
 Real Time Interrupt module (RTI) header file.
file  tms570-sci-driver.h
 Declaration of serial's driver inner structure.
file  tms570-sci.h
 Serial Communication Interface (SCI) header file.
file  tms570-vim.h
 Vectored Interrupt Module (VIM) header file.
file  tms570_selftest.h
 Definition of TMS570 selftest error codes, addresses and functions.
file  tms570_selftest_parity.h
 Check of module parity based protection logic to work.
file  tms570lc4357-pins.h
 Specification of individual pins mapping to the package.
file  tms570ls3137zwt-pins.h
file  irq.c
 TMS570 interrupt support functions definitions.
file  bspreset.c
 Reset code.
file  bspstart.c
 Startup code.
file  bspstarthooks.c
 First configurations and initializations to the correct functionality of the board.
file  init_emif_sdram.c
 Initialization of external memory/SDRAM interface.
file  init_esm.c
 Error signaling module initialization.
file  init_pinmux.c
 Initialize pin multiplexers.
file  pinmux.c
file  tms570-pom.c
 TMS570 Parameter Overlay Module functions definitions.
file  tms570_selftest.c
 TMS570 selftest support functions implementation.
file  tms570_selftest_par_can.c
 Test CAN module parity based protection logic to work.
file  tms570_selftest_par_mibspi.c
 Test MibSPI module parity based protection logic to work.
file  tms570_selftest_par_std.c
 Generic parity based protection logic check applicable to HETx, HTUx, ADC, DMA and VIM.
file  tms570_selftest_parity.c
file  tms570_tcram_tests.c
 TCRAM selftest function.
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_OSCILATOR_CLOCK   8000000
#define BSP_PLL_OUT_CLOCK   160000000
