RTEMS 5.2-rc1
rtems_test_parallel_job Struct Reference
Basic parallel job description. More...
#include <test.h>
rtems_interval(* init )(rtems_test_parallel_context *ctx, void *arg, size_t active_workers)
 Job initialization handler. More...
void(* body )(rtems_test_parallel_context *ctx, void *arg, size_t active_workers, size_t worker_index)
 Job body handler. More...
void(* fini )(rtems_test_parallel_context *ctx, void *arg, size_t active_workers)
 Job finalization handler. More...
void * arg
 Job specific argument.
bool cascade
 Job cascading flag. More...
Field Documentation
◆ body
void(* rtems_test_parallel_job::body) (rtems_test_parallel_context *ctx, void *arg, size_t active_workers, size_t worker_index)
Job body handler.
Parameters
[in]ctxThe parallel context.
[in]argThe user specified argument.
[in]active_workersCount of active workers. Depends on the cascade option.
[in]worker_indexThe worker index. It ranges from 0 to the processor count minus one.
◆ cascade
bool rtems_test_parallel_job::cascade
Job cascading flag.
This flag indicates whether the job should be executed in a cascaded manner (the job is executed on one processor first, two processors afterwards and incremented step by step until all processors are used).
◆ fini
void(* rtems_test_parallel_job::fini) (rtems_test_parallel_context *ctx, void *arg, size_t active_workers)
This handler executes only in the context of the master worker after the job body handler.
Parameters
◆ init
rtems_interval(* rtems_test_parallel_job::init) (rtems_test_parallel_context *ctx, void *arg, size_t active_workers)
This handler executes only in the context of the master worker before the job body handler.
Parameters
Returns
The desired job body execution time in clock ticks. See rtems_test_parallel_stop_job().
