RTEMS 5.2-rc1
Test support functions. More...
| struct | rtems_test_parallel_context |
| Internal context for parallel job execution. More... | |
| struct | rtems_test_parallel_job |
| Basic parallel job description. More... | |
| #define | RTEMS_TEST_INITIAL_EXTENSION { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension } |
| Initial extension for tests. | |
| #define | TEST_STATE RTEMS_TEST_STATE_PASS |
| #define | RTEMS_TEST_PARALLEL_PROCESSOR_MAX 32 |
Typedefs | |
| typedef struct rtems_test_parallel_job | rtems_test_parallel_job |
| typedef void(* | rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
| Worker task setup handler. More... | |
Enumerations | |
| enum | RTEMS_TEST_STATE { RTEMS_TEST_STATE_PASS , RTEMS_TEST_STATE_FAIL , RTEMS_TEST_STATE_USER_INPUT , RTEMS_TEST_STATE_INDETERMINATE , RTEMS_TEST_STATE_BENCHMARK } |
| Test states. | |
| void | rtems_test_fatal_extension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| Fatal extension for tests. | |
| int | rtems_test_begin (const char *name, const RTEMS_TEST_STATE state) |
| Prints a begin of test message using printf(). More... | |
| int | rtems_test_end (const char *name) |
| Prints an end of test message using printf(). More... | |
| void | rtems_test_exit (int status) RTEMS_NO_RETURN |
| Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code. | |
| int | rtems_test_printf (const char *format,...) RTEMS_PRINTFLIKE(1 |
| Prints via the RTEMS printer. More... | |
| void | rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count) |
| Runs a bunch of jobs in parallel on all processors of the system. More... | |
| void | rtems_test_busy_cpu_usage (time_t seconds, long nanoseconds) |
| Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executing thread. More... | |
| void | rtems_test_busy (uint_fast32_t count) |
| Performs a busy loop with the specified iteration count. More... | |
| uint_fast32_t | rtems_test_get_one_tick_busy_count (void) |
| Returns a count value for rtems_test_busy() which yields roughly a duration of one clock tick. | |
| const char | rtems_test_name [] |
| Each test must define a test name string. | |
| rtems_printer | rtems_test_printer |
| Each test must define a printer. | |
| typedef void(* rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
Called during rtems_test_parallel() to optionally setup a worker task before it is started.
| [in] | ctx | The parallel context. |
| [in] | worker_index | The worker index. |
| [in] | worker_id | The worker task identifier. |
| int rtems_test_begin | ( | const char * | name, |
| const RTEMS_TEST_STATE | state | ||
| void rtems_test_busy | ( | uint_fast32_t | count | ) |
This function is optimized to not perform memory accesses and should have a small jitter.
| [in] | count | The iteration count. |
| void rtems_test_busy_cpu_usage | ( | time_t | seconds, |
| long | nanoseconds | ||
This function continuously reads the CPU usage of the executing thread. This operation may lead to a scheduler instance lock contention in SMP configurations.
| [in] | seconds | The busy seconds. |
| [in] | nanoseconds | The busy nanoseconds. |
| int rtems_test_end | ( | const char * | name | ) |
| void rtems_test_parallel | ( | rtems_test_parallel_context * | ctx, |
| rtems_test_parallel_worker_setup | worker_setup, | ||
| const rtems_test_parallel_job * | jobs, | ||
| size_t | job_count | ||
The worker tasks inherit the priority of the executing task.
There are SMP barriers before and after the job body.
| [in] | worker_setup | Optional handler to setup a worker task before it is started. |
| [in] | jobs | The table of jobs. |
| [in] | job_count | The count of jobs in the job table. |
| int rtems_test_printf | ( | const char * | format, |
