RTEMS 5.2-rc1
drvmgr_dev Struct Reference
#include <drvmgr.h>
int obj_type
struct drvmgr_devnext
struct drvmgr_devnext_in_bus
struct drvmgr_devnext_in_drv
struct drvmgr_drvdrv
struct drvmgr_busparent
short minor_drv
short minor_bus
char * name
void * priv
void * businfo
struct drvmgr_busbus
unsigned int state
int level
int error
Device information
Field Documentation
◆ bus
struct drvmgr_bus* drvmgr_dev::bus
Pointer to bus, set only if this is a bridge
◆ businfo
void* drvmgr_dev::businfo
Host bus specific information
◆ drv
struct drvmgr_drv* drvmgr_dev::drv
The driver owning this device
◆ error
int drvmgr_dev::error
Error state returned by driver
◆ level
int drvmgr_dev::level
Init Level
◆ minor_bus
short drvmgr_dev::minor_bus
Device number on bus (for device separation)
◆ minor_drv
short drvmgr_dev::minor_drv
Device number within driver
◆ name
char* drvmgr_dev::name
Name of Device Hardware
◆ next
struct drvmgr_dev* drvmgr_dev::next
Next device
◆ next_in_bus
struct drvmgr_dev* drvmgr_dev::next_in_bus
Next device on the same bus
◆ next_in_drv
struct drvmgr_dev* drvmgr_dev::next_in_drv
Next device using the same driver
◆ obj_type
int drvmgr_dev::obj_type
DRVMGR_OBJ_DEV
◆ parent
struct drvmgr_bus* drvmgr_dev::parent
Bus that this device resides on
◆ priv
void* drvmgr_dev::priv
Pointer to driver private device structure
◆ state
unsigned int drvmgr_dev::state
State of device, see DEV_STATE_*
