RTEMS 5.2-rc1
drvmgr.h
1/* Driver Manager Interface.
2 *
3 * COPYRIGHT (c) 2009 Cobham Gaisler AB.
4 *
5 * The license and distribution terms for this file may be
6 * found in the file LICENSE in this distribution or at
7 * http://www.rtems.org/license/LICENSE.
8 */
9
10#ifndef _DRIVER_MANAGER_H_
11#define _DRIVER_MANAGER_H_
12
13#include <rtems.h>
14#include <drvmgr/drvmgr_list.h>
15#include <stdint.h>
17#include <rtems/score/smpimpl.h>
18
19#ifdef __cplusplus
20extern "C" {
21#endif
22
23/*** Configure Driver manager ***/
24
25/* Define the number of initialization levels of device drivers */
26#define DRVMGR_LEVEL_MAX 4
27
28/* Default to use semahpores for protection. Initialization works without
29 * locks and after initialization too if devices are not removed.
30 */
31#ifndef DRVMGR_USE_LOCKS
32#define DRVMGR_USE_LOCKS 1
33#endif
34
35struct drvmgr_dev; /* Device */
36struct drvmgr_bus; /* Bus */
37struct drvmgr_drv; /* Driver */
38
39/*** List Interface shortcuts ***/
40#define BUS_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_bus)
41#define BUS_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_bus)
42#define DEV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_dev)
43#define DEV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_dev)
44#define DRV_LIST_HEAD(list) LIST_HEAD(list, struct drvmgr_drv)
45#define DRV_LIST_TAIL(list) LIST_TAIL(list, struct drvmgr_drv)
46
47/*** Bus indentification ***/
48#define DRVMGR_BUS_TYPE_NONE 0 /* Not a valid bus */
49#define DRVMGR_BUS_TYPE_ROOT 1 /* Hard coded bus */
50#define DRVMGR_BUS_TYPE_PCI 2 /* PCI bus */
51#define DRVMGR_BUS_TYPE_AMBAPP 3 /* AMBA Plug & Play bus */
52#define DRVMGR_BUS_TYPE_LEON2_AMBA 4 /* LEON2 hardcoded bus */
53#define DRVMGR_BUS_TYPE_AMBAPP_DIST 5 /* Distibuted AMBA Plug & Play bus accessed using a communication interface */
54#define DRVMGR_BUS_TYPE_SPW_RMAP 6 /* SpaceWire Network bus */
55#define DRVMGR_BUS_TYPE_AMBAPP_RMAP 7 /* SpaceWire RMAP accessed AMBA Plug & Play bus */
56
57enum {
58 DRVMGR_OBJ_NONE = 0,
59 DRVMGR_OBJ_DRV = 1,
60 DRVMGR_OBJ_BUS = 2,
61 DRVMGR_OBJ_DEV = 3,
62};
63
64/*** Driver indentification ***
65 *
66 * 64-bit identification integer definition
67 * * Bus ID 8-bit [7..0]
68 * * Reserved 8-bit field [63..56]
69 * * Device ID specific for bus type 48-bit [55..8] (Different buses have
70 * different unique identifications for hardware/driver.)
71 *
72 * ID Rules
73 * * A root bus driver must always have device ID set to 0. There can only by
74 * one root bus driver for a certain bus type.
75 * * A Driver ID must identify a unique hardware core
76 *
77 */
78
79/* Bus ID Mask */
80#define DRIVER_ID_BUS_MASK 0x00000000000000FFULL
81
82/* Reserved Mask for future use */
83#define DRIVER_ID_RSV_MASK 0xFF00000000000000ULL
84
85/* Reserved Mask for future use */
86#define DRIVER_ID_DEV_MASK 0x00FFFFFFFFFFFF00ULL
87
88/* Set Bus ID Mask. */
89#define DRIVER_ID(busid, devid) ((unsigned long long) \
90 ((((unsigned long long)(devid) << 8) & DRIVER_ID_DEV_MASK) | \
91 ((unsigned long long)(busid) & DRIVER_ID_BUS_MASK)))
92
93/* Get IDs */
94#define DRIVER_BUSID_GET(id) ((unsigned long long)(id) & DRIVER_ID_BUS_MASK)
95#define DRIVER_DEVID_GET(id) (((unsigned long long)(id) & DRIVER_ID_DEV_MASK) >> 8)
96
97#define DRIVER_ROOTBUS_ID(bus_type) DRIVER_ID(bus_type, 0)
98
99/*** Root Bus drivers ***/
100
101/* Generic Hard coded Root bus: Driver ID */
102#define DRIVER_ROOT_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_ROOT)
103
104/* PCI Plug & Play bus: Driver ID */
105#define DRIVER_PCIBUS_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_PCI)
106
107/* AMBA Plug & Play bus: Driver ID */
108#define DRIVER_GRLIB_AMBAPP_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP)
109
110/* AMBA Hard coded bus: Driver ID */
111#define DRIVER_LEON2_AMBA_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_LEON2_AMBA)
112
113/* Distributed AMBA Plug & Play bus: Driver ID */
114#define DRIVER_AMBAPP_DIST_ID DRIVER_ROOTBUS_ID(DRVMGR_BUS_TYPE_AMBAPP_DIST)
115
123};
124
125/* Interrupt Service Routine (ISR) */
126typedef void (*drvmgr_isr)(void *arg);
127
130 /* Functions used internally within driver manager */
131 int (*init[DRVMGR_LEVEL_MAX])(struct drvmgr_bus *);
132 int (*remove)(struct drvmgr_bus *);
133 int (*unite)(struct drvmgr_drv *, struct drvmgr_dev *);
135 /* Functions called indirectly from drivers */
136 int (*int_register)(struct drvmgr_dev *, int index, const char *info, drvmgr_isr isr, void *arg);
137 int (*int_unregister)(struct drvmgr_dev *, int index, drvmgr_isr isr, void *arg);
138 int (*int_clear)(struct drvmgr_dev *, int index);
139 int (*int_mask)(struct drvmgr_dev *, int index);
140 int (*int_unmask)(struct drvmgr_dev *, int index);
141#ifdef RTEMS_SMP
142 int (*int_set_affinity)(struct drvmgr_dev *, int index,
143 const Processor_mask *cpus);
144#endif
145
146 /* Get Parameters */
147 int (*get_params)(struct drvmgr_dev *, struct drvmgr_bus_params *);
148 /* Get Frequency of Bus */
149 int (*get_freq)(struct drvmgr_dev*, int, unsigned int*);
153 void (*get_info_dev)(struct drvmgr_dev *,
154 void (*print)(void *p, char *str), void *p);
155};
156#define BUS_OPS_NUM (sizeof(struct drvmgr_bus_ops)/sizeof(void (*)(void)))
157
159 int funcid;
160 void *func;
161};
162#define DRVMGR_FUNC(_ID_, _FUNC_) {(int)(_ID_), (void *)(_FUNC_)}
163#define DRVMGR_FUNC_END {0, NULL}
164
165/*** Resource definitions ***
166 *
167 * Overview of structures:
168 * All bus resources entries (_bus_res) are linked together per bus
169 * (bus_info->reslist). One bus resource entry has a pointer to an array of
170 * driver resources (_drv_res). One driver resouces is made out of an array
171 * of keys (drvmgr_key). All keys belongs to the same driver and harwdare
172 * device. Each key has a Name, Type ID and Data interpreted differently
173 * depending on the Type ID (union drvmgr_key_value).
174 *
175 */
176
177/* Key Data Types */
178enum drvmgr_kt {
179 DRVMGR_KT_ANY = -1,
180 DRVMGR_KT_NONE = 0,
181 DRVMGR_KT_INT = 1,
182 DRVMGR_KT_STRING = 2,
183 DRVMGR_KT_POINTER = 3,
184};
185
186#define DRVMGR_KEY_EMPTY {NULL, DRVMGR_KT_NONE, {0}}
187#define DRVMGR_RES_EMPTY {0, 0, NULL}
188#define MMAP_EMPTY {0, 0, 0}
189
192 unsigned int i;
193 char *str;
194 void *ptr;
195};
196
197/* One key. One Value. Holding information relevant to the driver. */
199 char *key_name; /* Name of key */
200 enum drvmgr_kt key_type; /* How to interpret key_value */
201 union drvmgr_key_value key_value; /* The value or pointer to value */
202};
203
208 uint64_t drv_id;
210 struct drvmgr_key *keys;
211};
212
217};
218
226 char *name;
227 unsigned int size;
228 char *from_adr;
230 char *to_adr;
232};
233#define DRVMGR_TRANSLATE_ONE2ONE NULL
234#define DRVMGR_TRANSLATE_NO_BRIDGE ((void *)1) /* No bridge, error */
235
239 unsigned char bus_type;
240 unsigned char depth;
241 struct drvmgr_bus *next;
242 struct drvmgr_dev *dev;
243 void *priv;
252 /* Bus status */
253 int level;
254 int state;
255 int error;
256};
257
258/* States of a bus */
259#define BUS_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */
260#define BUS_STATE_LIST_INACTIVE 0x00001000 /* In inactive bus list */
261#define BUS_STATE_DEPEND_FAILED 0x00000004 /* Device init failed */
262
263/* States of a device */
264#define DEV_STATE_INIT_FAILED 0x00000001 /* Initialization Failed */
265#define DEV_STATE_INIT_DONE 0x00000002 /* All init levels completed */
266#define DEV_STATE_DEPEND_FAILED 0x00000004 /* Parent Bus init failed */
267#define DEV_STATE_UNITED 0x00000100 /* Device United with Device Driver */
268#define DEV_STATE_REMOVED 0x00000200 /* Device has been removed (unregistered) */
269#define DEV_STATE_IGNORED 0x00000400 /* Device was ignored according to user's request, the device
270 * was never reported to it's driver (as expected).
271 */
272#define DEV_STATE_LIST_INACTIVE 0x00001000 /* In inactive device list */
277 struct drvmgr_dev *next;
278 struct drvmgr_dev *next_in_bus;
281 struct drvmgr_drv *drv;
283 short minor_drv;
284 short minor_bus;
285 char *name;
286 void *priv;
287 void *businfo;
288 struct drvmgr_bus *bus;
290 /* Device Status */
291 unsigned int state;
292 int level;
293 int error;
294};
298 int (*init[DRVMGR_LEVEL_MAX])(struct drvmgr_dev *);
299 int (*remove)(struct drvmgr_dev *);
300 int (*info)(struct drvmgr_dev *, void (*print)(void *p, char *str), void *p, int, char *argv[]);
301};
302#define DRVMGR_OPS_NUM(x) (sizeof(x)/sizeof(void (*)(void)))
307 struct drvmgr_drv *next;
308 struct drvmgr_dev *dev;
310 uint64_t drv_id;
311 char *name;
315 unsigned int dev_cnt;
316 unsigned int dev_priv_size;
317};
318
323typedef void (*drvmgr_drv_reg_func)(void);
324
325/*** DRIVER | DEVICE | BUS FUNCTIONS ***/
326
327/* Return Codes */
328enum {
329 DRVMGR_OK = 0, /* Sucess */
330 DRVMGR_NOMEM = 1, /* Memory allocation error */
331 DRVMGR_EIO = 2, /* I/O error */
332 DRVMGR_EINVAL = 3, /* Invalid parameter */
333 DRVMGR_ENOSYS = 4,
334 DRVMGR_TIMEDOUT = 5, /* Operation timeout error */
335 DRVMGR_EBUSY = 6,
336 DRVMGR_ENORES = 7, /* Not enough resources */
337 DRVMGR_FAIL = -1 /* Unspecified failure */
338};
339
344extern void _DRV_Manager_initialization(void);
345
351extern void _DRV_Manager_init_level(int level);
352
358extern int drvmgr_init(void);
359
360/* Take registered buses and devices into the correct init level,
361 * this function is called from _init_level() so normally
362 * we don't need to call it directly.
363 */
364extern void drvmgr_init_update(void);
365
367extern int drvmgr_root_drv_register(struct drvmgr_drv *drv);
368
370extern int drvmgr_drv_register(struct drvmgr_drv *drv);
371
373extern int drvmgr_dev_register(struct drvmgr_dev *dev);
374
385extern int drvmgr_dev_unregister(struct drvmgr_dev *dev);
386
388extern int drvmgr_bus_register(struct drvmgr_bus *bus);
389
391extern int drvmgr_bus_unregister(struct drvmgr_bus *bus);
392
398extern int drvmgr_children_unregister(struct drvmgr_bus *bus);
399
400/* Separate a device from the driver it has been united with */
401extern int drvmgr_dev_drv_separate(struct drvmgr_dev *dev);
402
409extern int drvmgr_alloc_dev(struct drvmgr_dev **pdev, int extra);
410
417extern int drvmgr_alloc_bus(struct drvmgr_bus **pbus, int extra);
418
419/*** DRIVER RESOURCE FUNCTIONS ***/
420
427extern void drvmgr_bus_res_add(struct drvmgr_bus *bus,
428 struct drvmgr_bus_res *bres);
429
436extern int drvmgr_keys_get(struct drvmgr_dev *dev, struct drvmgr_key **keys);
437
444extern struct drvmgr_key *drvmgr_key_get(struct drvmgr_key *keys, char *key_name);
445
458extern union drvmgr_key_value *drvmgr_key_val_get(
459 struct drvmgr_key *keys,
460 char *key_name,
461 enum drvmgr_kt key_type);
462
475extern union drvmgr_key_value *drvmgr_dev_key_get(
476 struct drvmgr_dev *dev,
477 char *key_name,
478 enum drvmgr_kt key_type);
479
480/*** DRIVER INTERACE USED TO REQUEST INFORMATION/SERVICES FROM BUS DRIVER ***/
481
483RTEMS_INLINE_ROUTINE struct drvmgr_bus *drvmgr_get_parent(
484 struct drvmgr_dev *dev)
485{
486 if (dev)
487 return dev->parent;
488 else
489 return NULL;
490}
491
493RTEMS_INLINE_ROUTINE struct drvmgr_drv *drvmgr_get_drv(struct drvmgr_dev *dev)
494{
495 if (dev)
496 return dev->drv;
497 else
498 return NULL;
499}
500
513#define DRVMGR_FED_BF 1 /* Breadth-first search */
514#define DRVMGR_FED_DF 0 /* Depth first search */
515extern intptr_t drvmgr_for_each_dev(
516 intptr_t (*func)(struct drvmgr_dev *dev, void *arg),
517 void *arg,
518 int options);
519
528extern int drvmgr_get_dev(
529 struct drvmgr_drv *drv,
530 int minor,
531 struct drvmgr_dev **pdev);
532
539extern int drvmgr_freq_get(
540 struct drvmgr_dev *dev,
541 int options,
542 unsigned int *freq_hz);
543
545extern int drvmgr_on_rootbus(struct drvmgr_dev *dev);
546
553extern int drvmgr_get_dev_prefix(struct drvmgr_dev *dev, char *dev_prefix);
554
568extern int drvmgr_interrupt_register(
569 struct drvmgr_dev *dev,
570 int index,
571 const char *info,
572 drvmgr_isr isr,
573 void *arg);
574
585extern int drvmgr_interrupt_unregister(
586 struct drvmgr_dev *dev,
587 int index,
588 drvmgr_isr isr,
589 void *arg);
590
600extern int drvmgr_interrupt_clear(
601 struct drvmgr_dev *dev,
602 int index);
603
614extern int drvmgr_interrupt_unmask(
615 struct drvmgr_dev *dev,
616 int index);
617
626extern int drvmgr_interrupt_mask(
627 struct drvmgr_dev *dev,
628 int index);
629
638#ifdef RTEMS_SMP
639extern int drvmgr_interrupt_set_affinity(
640 struct drvmgr_dev *dev,
641 int index,
642 const Processor_mask *cpus);
643#endif
644
646enum drvmgr_tr_opts {
647 /* Translate CPU RAM Address (input) to DMA unit accessible address
648 * (output), this is an upstreams translation in reverse order.
649 *
650 * Typical Usage:
651 * It is common to translate a CPU accessible RAM address to an
652 * address that DMA units can access over bridges.
653 */
654 CPUMEM_TO_DMA = 0x0,
655
656 /* Translate DMA Unit Accessible address mapped to CPU RAM (input) to
657 * CPU accessible address (output). This is an upstreams translation.
658 *
659 * Typical Usage (not often used):
660 * The DMA unit descriptors contain pointers to DMA buffers located at
661 * CPU RAM addresses that the DMA unit can access, the CPU processes
662 * the descriptors and want to access the data but a translation back
663 * to CPU address is required.
664 */
665 CPUMEM_FROM_DMA = 0x1,
666
667 /* Translate DMA Memory Address (input) to CPU accessible address
668 * (output), this is a downstreams translation in reverse order.
669 *
670 * Typical Usage:
671 * A PCI network card puts packets into its memory not doing DMA over
672 * PCI, in order for the CPU to access them the PCI address must be
673 * translated.
674 */
675 DMAMEM_TO_CPU = 0x2,
676
677 /* Translate CPU accessible address (input) mapped to DMA Memory Address
678 * to DMA Unit accessible address (output). This is a downstreams
679 * translation.
680 */
681 DMAMEM_FROM_CPU = 0x3,
682};
683#define DRVMGR_TR_REVERSE 0x1 /* do reverse translation direction order */
684#define DRVMGR_TR_PATH 0x2 /* 0x0=down-stream 0x2=up-stream address path */
685
722extern unsigned int drvmgr_translate(
723 struct drvmgr_dev *dev,
724 unsigned int options,
725 void *src_address,
726 void **dst_address);
727
728/* Translate addresses between buses, used internally to implement
729 * drvmgr_translate. Function is not limited to translate from/to root bus
730 * where CPU is resident, however buses must be on a straight path relative
731 * to each other (parent of parent of parent and so on).
732 *
733 * \param from src_address is given for this bus
734 * \param to src_address is translated to this bus
735 * \param reverse Selects translation method, if map entries are used in
736 * the reverse order (map_up->to is used as map_up->from)
737 * \param src_address Address to be translated
738 * \param dst_address Translated address is stored here on success (return=0)
739 *
740 * Returns 0 if unable to translate. The remaining length from the given
741 * address of the map is returned on success and the result is stored into
742 * *dst_address. For example if a map starts at 0x40000000 of size 0x100000
743 * the result will be 0x40000 if the address was translated into 0x400C0000.
744 * If dev is on root-bus no translation is performed 0xffffffff is returned.
745 * and src_address is stored in *dst_address.
746 */
747extern unsigned int drvmgr_translate_bus(
748 struct drvmgr_bus *from,
749 struct drvmgr_bus *to,
750 int reverse,
751 void *src_address,
752 void **dst_address);
753
754/* Calls drvmgr_translate() to translate an address range and checks the result,
755 * a printout is generated if the check fails. All parameters are passed on to
756 * drvmgr_translate() except for size, see paramters of drvmgr_translate().
757 *
758 * If size=0 only the starting address is not checked.
759 *
760 * If mapping failes a non-zero result is returned.
761 */
762extern int drvmgr_translate_check(
763 struct drvmgr_dev *dev,
764 unsigned int options,
765 void *src_address,
766 void **dst_address,
767 unsigned int size);
768
773extern int drvmgr_func_get(void *obj, int funcid, void **func);
774
776extern int drvmgr_func_call(void *obj, int funcid, void *a, void *b, void *c, void *d);
777
778/* Builds a Function ID.
779 *
780 * Used to request optional functions by a bus or device driver
781 */
782#define DRVMGR_FUNCID(major, minor) ((((major) & 0xfff) << 20) | ((minor) & 0xfffff))
783#define DRVMGR_FUNCID_NONE 0
784#define DRVMGR_FUNCID_END DRVMGR_FUNCID(DRVMGR_FUNCID_NONE, 0)
785
786/* Major Function ID. Most significant 12-bits. */
787enum {
788 FUNCID_NONE = 0x000,
789 FUNCID_RW = 0x001, /* Read/Write functions */
790};
791
792/* Select Sub-Function Read/Write function by ID */
793#define RW_SIZE_1 0x00001 /* Access Size */
794#define RW_SIZE_2 0x00002
795#define RW_SIZE_4 0x00004
796#define RW_SIZE_8 0x00008
797#define RW_SIZE_ANY 0x00000
798#define RW_SIZE(id) ((unsigned int)(id) & 0xf)
799
800#define RW_DIR_ANY 0x00000 /* Access Direction */
801#define RW_READ 0x00000 /* Read */
802#define RW_WRITE 0x00010 /* Write */
803#define RW_SET 0x00020 /* Write with same value (memset) */
804#define RW_DIR(id) (((unsigned int)(id) >> 4) & 0x3)
805
806#define RW_RAW 0x00000 /* Raw access - no swapping (machine default) */
807#define RW_LITTLE 0x00040 /* Little Endian */
808#define RW_BIG 0x00080 /* Big Endian */
809#define RW_ENDIAN(id) (((unsigned int)(id) >> 6) & 0x3)
810
811#define RW_TYPE_ANY 0x00000 /* Access type */
812#define RW_REG 0x00100
813#define RW_MEM 0x00200
814#define RW_MEMREG 0x00300
815#define RW_CFG 0x00400
816#define RW_TYPE(id) (((unsigned int)(id) >> 8) & 0xf)
817
818#define RW_ARG 0x01000 /* Optional Argument */
819#define RW_ERR 0x02000 /* Optional Error Handler */
820
821/* Build a Read/Write function ID */
822#define DRVMGR_RWFUNC(minor) DRVMGR_FUNCID(FUNCID_RW, minor)
823
824/* Argument to Read/Write functions, the "void *arg" pointer is returned by
825 * RW_ARG. If NULL is returned no argument is needed.
826 */
827struct drvmgr_rw_arg {
828 void *arg;
829 struct drvmgr_dev *dev;
830};
831
832/* Standard Read/Write function types */
833typedef uint8_t (*drvmgr_r8)(uint8_t *srcadr);
834typedef uint16_t (*drvmgr_r16)(uint16_t *srcadr);
835typedef uint32_t (*drvmgr_r32)(uint32_t *srcadr);
836typedef uint64_t (*drvmgr_r64)(uint64_t *srcadr);
837typedef void (*drvmgr_w8)(uint8_t *dstadr, uint8_t data);
838typedef void (*drvmgr_w16)(uint16_t *dstadr, uint16_t data);
839typedef void (*drvmgr_w32)(uint32_t *dstadr, uint32_t data);
840typedef void (*drvmgr_w64)(uint64_t *dstadr, uint64_t data);
841/* READ/COPY a memory area located on bus into CPU memory.
842 * From 'src' (remote) to the destination 'dest' (local), n=number of bytes
843 */
844typedef int (*drvmgr_rmem)(void *dest, const void *src, int n);
845/* WRITE/COPY a user buffer located in CPU memory to a location on the bus.
846 * From 'src' (local) to the destination 'dest' (remote), n=number of bytes
847 */
848typedef int (*drvmgr_wmem)(void *dest, const void *src, int n);
849/* Set a memory area to the byte value given in c, see LIBC memset(). Memset is
850 * implemented by calling wmem() multiple times with a "large" buffer.
851 */
852typedef int (*drvmgr_memset)(void *dstadr, int c, size_t n);
853
854/* Read/Write function types with additional argument */
855typedef uint8_t (*drvmgr_r8_arg)(uint8_t *srcadr, void *a);
856typedef uint16_t (*drvmgr_r16_arg)(uint16_t *srcadr, void *a);
857typedef uint32_t (*drvmgr_r32_arg)(uint32_t *srcadr, void *a);
858typedef uint64_t (*drvmgr_r64_arg)(uint64_t *srcadr, void *a);
859typedef void (*drvmgr_w8_arg)(uint8_t *dstadr, uint8_t data, void *a);
860typedef void (*drvmgr_w16_arg)(uint16_t *dstadr, uint16_t data, void *a);
861typedef void (*drvmgr_w32_arg)(uint32_t *dstadr, uint32_t data, void *a);
862typedef void (*drvmgr_w64_arg)(uint64_t *dstadr, uint64_t data, void *a);
863typedef int (*drvmgr_rmem_arg)(void *dest, const void *src, int n, void *a);
864typedef int (*drvmgr_wmem_arg)(void *dest, const void *src, int n, void *a);
865typedef int (*drvmgr_memset_arg)(void *dstadr, int c, size_t n, void *a);
866
867/* Report an error to the parent bus of the device */
868typedef void (*drvmgr_rw_err)(struct drvmgr_rw_arg *a, struct drvmgr_bus *bus,
869 int funcid, void *adr);
870
871/* Helper function for buses that implement the memset() over wmem() */
872extern void drvmgr_rw_memset(
873 void *dstadr,
874 int c,
875 size_t n,
876 void *a,
877 drvmgr_wmem_arg wmem
878 );
879
880/*** PRINT INFORMATION ABOUT DRIVER MANAGER ***/
881
906extern int drvmgr_for_each_listdev(
907 struct drvmgr_list *devlist,
908 unsigned int state_set_mask,
909 unsigned int state_clr_mask,
910 int (*func)(struct drvmgr_dev *dev, void *arg),
911 void *arg);
912
913/* Print all devices */
914#define PRINT_DEVS_FAILED 0x01 /* Failed during initialization */
915#define PRINT_DEVS_ASSIGNED 0x02 /* Driver assigned */
916#define PRINT_DEVS_UNASSIGNED 0x04 /* Driver not assigned */
917#define PRINT_DEVS_IGNORED 0x08 /* Device ignored on user's request */
918#define PRINT_DEVS_ALL (PRINT_DEVS_FAILED | \
919 PRINT_DEVS_ASSIGNED | \
920 PRINT_DEVS_UNASSIGNED |\
921 PRINT_DEVS_IGNORED)
922
924extern void drvmgr_summary(void);
925
927extern void drvmgr_print_devs(unsigned int options);
928
930extern void drvmgr_print_topo(void);
931
935extern void drvmgr_print_mem(void);
936
937#define OPTION_DEV_GENINFO 0x00000001
938#define OPTION_DEV_BUSINFO 0x00000002
939#define OPTION_DEV_DRVINFO 0x00000004
940#define OPTION_DRV_DEVS 0x00000100
941#define OPTION_BUS_DEVS 0x00010000
942#define OPTION_RECURSIVE 0x01000000
943#define OPTION_INFO_ALL 0xffffffff
944
946extern void drvmgr_info(void *id, unsigned int options);
947
949extern void drvmgr_info_dev(struct drvmgr_dev *dev, unsigned int options);
950
952extern void drvmgr_info_bus(struct drvmgr_bus *bus, unsigned int options);
953
955extern void drvmgr_info_drv(struct drvmgr_drv *drv, unsigned int options);
956
958extern void drvmgr_info_devs_on_bus(struct drvmgr_bus *bus, unsigned int options);
959
961extern void drvmgr_info_devs(unsigned int options);
962
964extern void drvmgr_info_drvs(unsigned int options);
965
967extern void drvmgr_info_buses(unsigned int options);
968
970extern struct drvmgr_drv *drvmgr_drv_by_id(uint64_t id);
971
973extern struct drvmgr_drv *drvmgr_drv_by_name(const char *name);
974
976extern struct drvmgr_dev *drvmgr_dev_by_name(const char *name);
977
978#ifdef __cplusplus
979}
980#endif
981
982#endif
Basic Definitions.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
SuperCore SMP Implementation.
Definition: drvmgr.h:129
void(* get_info_dev)(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p)
Definition: drvmgr.h:153
int(* unite)(struct drvmgr_drv *, struct drvmgr_dev *)
Definition: drvmgr.h:133
Definition: drvmgr.h:121
char * dev_prefix
Definition: drvmgr.h:122
Definition: drvmgr.h:214
struct drvmgr_drv_res resource[]
Definition: drvmgr.h:216
struct drvmgr_bus_res * next
Definition: drvmgr.h:215
Definition: drvmgr.h:237
struct drvmgr_func * funcs
Definition: drvmgr.h:246
int error
Definition: drvmgr.h:255
int state
Definition: drvmgr.h:254
int obj_type
Definition: drvmgr.h:238
void * priv
Definition: drvmgr.h:243
struct drvmgr_map_entry * maps_down
Definition: drvmgr.h:250
struct drvmgr_dev * dev
Definition: drvmgr.h:242
struct drvmgr_bus_res * reslist
Definition: drvmgr.h:248
unsigned char depth
Definition: drvmgr.h:240
struct drvmgr_bus * next
Definition: drvmgr.h:241
int dev_cnt
Definition: drvmgr.h:247
struct drvmgr_bus_ops * ops
Definition: drvmgr.h:245
struct drvmgr_map_entry * maps_up
Definition: drvmgr.h:249
int level
Definition: drvmgr.h:253
Definition: drvmgr.h:239
struct drvmgr_dev * children
Definition: drvmgr.h:244
Definition: drvmgr.h:273
struct drvmgr_bus * bus
Definition: drvmgr.h:286
int level
Definition: drvmgr.h:290
struct drvmgr_dev * next
Definition: drvmgr.h:275
char * name
Definition: drvmgr.h:283
unsigned int state
Definition: drvmgr.h:289
struct drvmgr_dev * next_in_bus
Definition: drvmgr.h:276
struct drvmgr_drv * drv
Definition: drvmgr.h:279
void * priv
Definition: drvmgr.h:284
struct drvmgr_dev * next_in_drv
Definition: drvmgr.h:277
struct drvmgr_bus * parent
Definition: drvmgr.h:280
int obj_type
Definition: drvmgr.h:274
int error
Definition: drvmgr.h:291
short minor_drv
Definition: drvmgr.h:281
void * businfo
Definition: drvmgr.h:285
short minor_bus
Definition: drvmgr.h:282
Definition: drvmgr.h:295
int(* info)(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p, int, char *argv[])
Definition: drvmgr.h:298
int(* remove)(struct drvmgr_dev *)
Definition: drvmgr.h:297
Definition: drvmgr.h:207
int minor_bus
Definition: drvmgr.h:209
struct drvmgr_key * keys
Definition: drvmgr.h:210
uint64_t drv_id
Definition: drvmgr.h:208
Definition: drvmgr.h:303
char * name
Definition: drvmgr.h:309
struct drvmgr_drv * next
Definition: drvmgr.h:305
Definition: drvmgr.h:313
struct drvmgr_drv_ops * ops
Definition: drvmgr.h:311
Definition: drvmgr.h:312
Definition: drvmgr.h:314
Definition: drvmgr.h:306
int obj_type
Definition: drvmgr.h:304
uint64_t drv_id
Definition: drvmgr.h:308
int bus_type
Definition: drvmgr.h:310
Definition: drvmgr.h:158
Definition: drvmgr.h:198
Definition: drvmgr_list.h:24
Definition: drvmgr.h:225
unsigned int size
Definition: drvmgr.h:227
char * name
Definition: drvmgr.h:226
char * to_adr
Definition: drvmgr.h:230
char * from_adr
Definition: drvmgr.h:228
Definition: drvmgr.h:825
unsigned size
Definition: tte.h:1
unsigned p
Definition: tte.h:17
Definition: drvmgr.h:191
unsigned int i
Definition: drvmgr.h:192
char * str
Definition: drvmgr.h:193
void * ptr
Definition: drvmgr.h:194
