RTEMS 5.2-rc1
RTEMS Run-Time Linker ELF Trace Support. More...
| #define | RTEMS_RTL_TRACE 1 |
| #define | RTEMS_RTL_TRACE_DETAIL (1UL << 0) |
| #define | RTEMS_RTL_TRACE_WARNING (1UL << 1) |
| #define | RTEMS_RTL_TRACE_LOAD (1UL << 2) |
| #define | RTEMS_RTL_TRACE_UNLOAD (1UL << 3) |
| #define | RTEMS_RTL_TRACE_SECTION (1UL << 4) |
| #define | RTEMS_RTL_TRACE_SYMBOL (1UL << 5) |
| #define | RTEMS_RTL_TRACE_RELOC (1UL << 6) |
| #define | RTEMS_RTL_TRACE_GLOBAL_SYM (1UL << 7) |
| #define | RTEMS_RTL_TRACE_LOAD_SECT (1UL << 8) |
| #define | RTEMS_RTL_TRACE_ALLOCATOR (1UL << 9) |
| #define | RTEMS_RTL_TRACE_UNRESOLVED (1UL << 10) |
| #define | RTEMS_RTL_TRACE_CACHE (1UL << 11) |
| #define | RTEMS_RTL_TRACE_ARCHIVES (1UL << 12) |
| #define | RTEMS_RTL_TRACE_ARCHIVE_SYMS (1UL << 13) |
| #define | RTEMS_RTL_TRACE_DEPENDENCY (1UL << 14) |
| #define | RTEMS_RTL_TRACE_BIT_ALLOC (1UL << 15) |
| #define | RTEMS_RTL_TRACE_COMP (1UL << 16) |
| #define | RTEMS_RTL_TRACE_ALL |
Typedefs | |
| typedef uint32_t | rtems_rtl_trace_mask |
| bool | rtems_rtl_trace (rtems_rtl_trace_mask mask) |
| rtems_rtl_trace_mask | rtems_rtl_trace_set_mask (rtems_rtl_trace_mask mask) |
| rtems_rtl_trace_mask | rtems_rtl_trace_clear_mask (rtems_rtl_trace_mask mask) |
| int | rtems_rtl_trace_shell_command (const rtems_printer *printer, int argc, char *argv[]) |
| #define RTEMS_RTL_TRACE 1 |
Set to 1 to build trace support in to the RTL code.
| #define RTEMS_RTL_TRACE_ALL |
| #define RTEMS_RTL_TRACE_DETAIL (1UL << 0) |
List of tracing bits for the various parts of the link editor.
| typedef uint32_t rtems_rtl_trace_mask |
The type of the mask.
| bool rtems_rtl_trace | ( | rtems_rtl_trace_mask | mask | ) |
Call to check if this part is bring traced. If RTEMS_RTL_TRACE is defined to 0 the code is dead code elminiated when built with -Os, -O2, or higher.
| mask | The part of the API to trace. |
| true | Tracing is active for the mask. |
| false | Do not trace. |
| rtems_rtl_trace_mask rtems_rtl_trace_clear_mask | ( | rtems_rtl_trace_mask | mask | ) |
Clear the mask.
| mask | The mask bits to clear. |
| rtems_rtl_trace_mask rtems_rtl_trace_set_mask | ( | rtems_rtl_trace_mask | mask | ) |
Set the mask.
| mask | The mask bits to set. |
| int rtems_rtl_trace_shell_command | ( | const rtems_printer * | printer, |
| int | argc, | ||
| char * | argv[] | ||
Add shell trace shell command.
