RTEMS 5.2-rc1
rtl-trace.h
1/*
2 * COPYRIGHT (c) 2012-2014 Chris Johns <chrisj@rtems.org>
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
16#if !defined (_RTEMS_RTL_TRACE_H_)
17#define _RTEMS_RTL_TRACE_H_
18
19#ifdef __cplusplus
20extern "C" {
21#endif /* __cplusplus */
22
23#include <stdbool.h>
24#include <stdint.h>
25
26#include <rtems/printer.h>
27
31#define RTEMS_RTL_TRACE 1
32
36typedef uint32_t rtems_rtl_trace_mask;
37
41#define RTEMS_RTL_TRACE_DETAIL (1UL << 0)
42#define RTEMS_RTL_TRACE_WARNING (1UL << 1)
43#define RTEMS_RTL_TRACE_LOAD (1UL << 2)
44#define RTEMS_RTL_TRACE_UNLOAD (1UL << 3)
45#define RTEMS_RTL_TRACE_SECTION (1UL << 4)
46#define RTEMS_RTL_TRACE_SYMBOL (1UL << 5)
47#define RTEMS_RTL_TRACE_RELOC (1UL << 6)
48#define RTEMS_RTL_TRACE_GLOBAL_SYM (1UL << 7)
49#define RTEMS_RTL_TRACE_LOAD_SECT (1UL << 8)
50#define RTEMS_RTL_TRACE_ALLOCATOR (1UL << 9)
51#define RTEMS_RTL_TRACE_UNRESOLVED (1UL << 10)
52#define RTEMS_RTL_TRACE_CACHE (1UL << 11)
53#define RTEMS_RTL_TRACE_ARCHIVES (1UL << 12)
54#define RTEMS_RTL_TRACE_ARCHIVE_SYMS (1UL << 13)
55#define RTEMS_RTL_TRACE_DEPENDENCY (1UL << 14)
56#define RTEMS_RTL_TRACE_BIT_ALLOC (1UL << 15)
57#define RTEMS_RTL_TRACE_COMP (1UL << 16)
58#define RTEMS_RTL_TRACE_ALL (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE | \
59 RTEMS_RTL_TRACE_COMP | \
60 RTEMS_RTL_TRACE_GLOBAL_SYM | \
61 RTEMS_RTL_TRACE_ARCHIVE_SYMS))
62
71#if RTEMS_RTL_TRACE
73#else
74#define rtems_rtl_trace(_m) (0)
75#endif
76
83#if RTEMS_RTL_TRACE
85#else
86#define rtems_rtl_trace_set_mask(_m)
87#endif
88
95#if RTEMS_RTL_TRACE
97#else
98#define rtems_rtl_trace_clear_mask(_m)
99#endif
100
104#if RTEMS_RTL_TRACE
106 int argc,
107 char* argv[]);
108#endif
109
110#ifdef __cplusplus
111}
112#endif /* __cplusplus */
113
114#endif
User print interface to the bspIO print plug in.
Definition: rtl-trace.h:36
rtems_rtl_trace_mask rtems_rtl_trace_set_mask(rtems_rtl_trace_mask mask)
rtems_rtl_trace_mask rtems_rtl_trace_clear_mask(rtems_rtl_trace_mask mask)
bool rtems_rtl_trace(rtems_rtl_trace_mask mask)
int rtems_rtl_trace_shell_command(const rtems_printer *printer, int argc, char *argv[])
Definition: printer.h:55
