RTEMS 5.2-rc1
Data Structures | Typedefs | Functions
RTEMS File Systems Shell Commands Support. More...
#include <inttypes.h>
#include <rtems/rfs/rtems-rfs-block.h>
#include <rtems/rfs/rtems-rfs-buffer.h>
#include <rtems/rfs/rtems-rfs-group.h>
#include <rtems/rfs/rtems-rfs-inode.h>
#include <rtems/rfs/rtems-rfs-dir.h>
#include <rtems/rtems-rfs-format.h>
#include <sys/statvfs.h>
struct  rtems_rfs_shell_cmd
typedef int(* rtems_rfs_shell_handler) (rtems_rfs_file_system *fs, int argc, char *argv[])
int rtems_shell_debugrfs (int argc, char *argv[])
int rtems_shell_rfs_format (int argc, char *argv[])
Typedef Documentation
◆ rtems_rfs_shell_handler
The type of the shell handlers we have.
◆ rtems_shell_debugrfs()
int rtems_shell_debugrfs ( int  argc,
char *  argv[]
The shell command for the RFS debugger.
Parameters
[in]argcis the argument count.
[in]argvis a pointer to the argument variables.
Return values
0Successful operation.
error_codeAn error occurred.
◆ rtems_shell_rfs_format()
int rtems_shell_rfs_format ( int  argc,
char *  argv[]
The shell command for formatting an RFS file system.
Parameters
Return values
1An error occurred.
