RTEMS 5.2-rc1
_rtems_rfs_file_system Struct Reference
#include <rtems-rfs-file-system.h>
uint32_t flags
size_t blocks
size_t block_size
int device
size_t size
uint32_t inodes
uint32_t bad_blocks
uint32_t max_name_length
rtems_rfs_groupgroups
int group_count
size_t group_blocks
size_t group_inodes
size_t inodes_per_block
size_t blocks_per_block
size_t block_map_singly_blocks
size_t block_map_doubly_blocks
uint32_t max_held_buffers
rtems_chain_control buffers
uint32_t buffers_count
rtems_chain_control release
uint32_t release_count
rtems_chain_control release_modified
uint32_t release_modified_count
rtems_chain_control file_shares
void * user
RFS File System data.
Field Documentation
◆ bad_blocks
uint32_t _rtems_rfs_file_system::bad_blocks
Bad block blocks. This is a table of blocks that have been found to be bad.
◆ block_map_doubly_blocks
size_t _rtems_rfs_file_system::block_map_doubly_blocks
Block map double indirect count. This is the block number per block squared and multiplied by the slots in the inode. It is the maximum number of blocks a map (file/directory) can have.
◆ block_map_singly_blocks
size_t _rtems_rfs_file_system::block_map_singly_blocks
Block map single indirect count. This is the block number per block multiplied but the slots in the inode.
◆ block_size
size_t _rtems_rfs_file_system::block_size
The size of a block. This must be a multiple of the disk's media block size.
◆ blocks
size_t _rtems_rfs_file_system::blocks
The number of blocks in the disk. The size of the disk is the number of blocks by the block size. This should be within a block size of the size returned by the media driver.
◆ blocks_per_block
size_t _rtems_rfs_file_system::blocks_per_block
Number of block numbers in a block.
◆ buffers
rtems_chain_control _rtems_rfs_file_system::buffers
List of buffers attached to buffer handles. Allows sharing.
◆ buffers_count
uint32_t _rtems_rfs_file_system::buffers_count
Number of buffers held on the buffers list.
◆ device
int _rtems_rfs_file_system::device
The file descriptor for device I/O.
◆ file_shares
rtems_chain_control _rtems_rfs_file_system::file_shares
List of open shared file node data. The shared node data such as the inode and block map allows a single file to be open more than once.
◆ flags
uint32_t _rtems_rfs_file_system::flags
Flags to control the file system. Some can be controlled via the ioctl.
◆ group_blocks
size_t _rtems_rfs_file_system::group_blocks
Number of blocks in a group.
◆ group_count
int _rtems_rfs_file_system::group_count
Number of groups.
◆ group_inodes
size_t _rtems_rfs_file_system::group_inodes
Number of inodes in a group.
◆ groups
rtems_rfs_group* _rtems_rfs_file_system::groups
A disk is broken down into a series of groups.
◆ inodes
uint32_t _rtems_rfs_file_system::inodes
Inode count.
◆ inodes_per_block
size_t _rtems_rfs_file_system::inodes_per_block
Number of inodes in each block.
◆ max_held_buffers
uint32_t _rtems_rfs_file_system::max_held_buffers
Number of buffers held before releasing back to the cache.
◆ max_name_length
uint32_t _rtems_rfs_file_system::max_name_length
Maximum length of names supported by this file system.
◆ release
rtems_chain_control _rtems_rfs_file_system::release
List of buffers that need to be released when the processing of a file system request has completed.
◆ release_count
uint32_t _rtems_rfs_file_system::release_count
Number of buffers held on the release list.
◆ release_modified
rtems_chain_control _rtems_rfs_file_system::release_modified
List of buffers that need to be released modified when the processing of a file system request has completed.
◆ release_modified_count
uint32_t _rtems_rfs_file_system::release_modified_count
Number of buffers held on the release modified list.
◆ size
size_t _rtems_rfs_file_system::size
The number of blocks in the file system.
◆ user
void* _rtems_rfs_file_system::user
Pointer to user data supplied when opening.
