RTEMS 5.2-rc1
bsp Directory Reference
file  dma.h [code]
 Direct memory access (DMA) support.
file  i2c.h [code]
file  io.h [code]
 Input and output module.
file  irq.h [code]
 LPC24XX interrupt definitions.
file  lcd.h [code]
 LCD support.
file  lpc-clock-config.h [code]
 Clock driver configuration.
file  lpc-ethernet-config.h [code]
 Ethernet driver configuration.
file  lpc17xx.h [code]
 Register definitions.
file  lpc24xx.h [code]
file  ssp.h [code]
file  start-config.h [code]
 BSP start configuration.
file  system-clocks.h [code]
 System clocks.
