RTEMS 5.2-rc1
lcd.h
1
9/*
10 * Copyright (c) 2010-2012 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef LIBBSP_ARM_LPC24XX_LCD_H
24#define LIBBSP_ARM_LPC24XX_LCD_H
25
26#include <rtems.h>
27
28#include <bsp/io.h>
29
30#ifdef __cplusplus
31extern "C" {
32#endif
33
44typedef enum {
45 #ifdef ARM_MULTILIB_ARCH_V4
46 LCD_MODE_STN_4_BIT = 0,
47 LCD_MODE_STN_8_BIT,
48 LCD_MODE_STN_DUAL_PANEL_4_BIT,
49 LCD_MODE_STN_DUAL_PANEL_8_BIT,
50 LCD_MODE_TFT_12_BIT_4_4_4,
51 LCD_MODE_TFT_16_BIT_5_6_5,
52 LCD_MODE_TFT_16_BIT_1_5_5_5,
53 LCD_MODE_TFT_24_BIT,
54 LCD_MODE_DISABLED
55 #else
56 LCD_MODE_STN_4_BIT = 0x4,
57 LCD_MODE_STN_8_BIT = 0x6,
58 LCD_MODE_STN_DUAL_PANEL_4_BIT = 0x84,
59 LCD_MODE_STN_DUAL_PANEL_8_BIT = 0x86,
60 LCD_MODE_TFT_12_BIT_4_4_4 = 0x2e,
61 LCD_MODE_TFT_16_BIT_5_6_5 = 0x2c,
62 LCD_MODE_TFT_16_BIT_1_5_5_5 = 0x28,
63 LCD_MODE_TFT_24_BIT = 0x2a,
64 LCD_MODE_DISABLED = 0xff
65 #endif
66} lpc24xx_lcd_mode;
67
79 lpc24xx_lcd_mode mode,
80 const lpc24xx_pin_range *pins
81);
82
83lpc24xx_lcd_mode lpc24xx_lcd_current_mode(void);
84
87#ifdef __cplusplus
88}
89#endif /* __cplusplus */
90
91#endif /* LIBBSP_ARM_LPC24XX_LCD_H */
rtems_status_code
Classic API Status.
Definition: status.h:43
rtems_status_code lpc24xx_lcd_set_mode(lpc24xx_lcd_mode mode, const lpc24xx_pin_range *pins)
Set the LCD mode.
Definition: lcd.c:35
Definition: io.h:224
