38. Directive Status Codes¶
38.1. Introduction¶
The directive status code directives are:
rtems_status_text - Return the name for the status code
38.2. Directives¶
The directives are:
successful completion |
returned from a task |
multiprocessing not configured |
invalid object name |
invalid object id |
too many |
timed out waiting |
object was deleted while waiting |
invalid specified size |
invalid address specified |
number was invalid |
item not initialized |
resources outstanding |
request not satisfied |
task is in wrong state |
task already in state |
illegal for calling task |
illegal for remote object |
invalid environment |
invalid task priority |
invalid time buffer |
invalid node id |
directive not configured |
not owner of resource |
directive not implemented or feature not available in configuration |
RTEMS inconsistency detected |
could not get enough memory |
driver I/O error |
returned by driver to indicate interrupted operation |
38.2.1. STATUS_TEXT - Returns the enumeration name for a status code¶
- CALLING SEQUENCE:
const char *rtems_status_text( rtems_status_code code );
- DIRECTIVE STATUS CODES
The status code enumeration name or “?” in case the status code is invalid.
- DESCRIPTION:
Returns the enumeration name for the specified status code.
