RTEMS
5.1-rc2
NXP LPC32XX Board Support Package. More...
Modules | |
| Boot Support | |
| Boot support. | |
| Clock Support | |
| Clock support. | |
| DMA Support | |
| DMA support. | |
| EMC Support | |
| EMC Support. | |
| Ethernet Support | |
| Ethernet support. | |
| HSU Support | |
| HSU Support. | |
| I2C Support | |
| I2C Support. | |
| I2S Support | |
| I2S support. | |
| Interrupt Support | |
| LCD Support | |
| LCD support. | |
| MMU Support | |
| MMU support. | |
| NAND MLC Controller | |
| NAND MLC Controller. | |
| Register Definitions | |
| Register definitions. | |
| Timer Support | |
| Timer support. | |
Files | |
| file | console-config.c |
| Console configuration. | |
| file | hsu.c |
| High speed UART driver (14-clock). | |
| file | bsp.h |
| Global BSP definitions. | |
| file | nand-select.c |
| NAND controller selection. | |
| file | rtc-config.c |
| RTC configuration. | |
| file | bspidle.c |
| bsp_idle_thread() implementation. | |
| file | bspreset.c |
| Reset code. | |
| file | bspstart.c |
| Startup code. | |
| file | bspstarthooks.c |
| Startup code. | |
| file | restart.c |
| Restart implementation. | |
| file | system-clocks.c |
| System clocks. | |
| file | timer.c |
| Benchmark timer support. | |
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH lpc_eth_attach_detach |
| Standard network driver attach and detach function. | |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth0" |
| Standard network driver name. | |
| #define | LPC32XX_STANDARD_TIMER (&lpc32xx.timer_1) |
| #define | BSP_IDLE_TASK_BODY bsp_idle_thread |
| #define | BSP_CONSOLE_UART_BASE LPC32XX_BASE_UART_5 |
| #define | LPC32XX_DO_STOP_GPDMA |
| #define | LPC32XX_DO_STOP_ETHERNET |
| #define | LPC32XX_DO_STOP_USB |
| #define | LPC32XX_DO_RESTART(addr) |
Enumerations | |
| enum | lpc32xx_nand_controller { LPC32XX_NAND_CONTROLLER_NONE, LPC32XX_NAND_CONTROLLER_MLC, LPC32XX_NAND_CONTROLLER_SLC } |
| int | lpc_eth_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| Network driver attach and detach function. | |
| void * | lpc32xx_idle (uintptr_t ignored) |
| Optimized idle task. More... | |
| bool | lpc32xx_start_pll_setup (uint32_t hclkpll_ctrl, uint32_t hclkdiv_ctrl, bool force) |
| uint32_t | lpc32xx_sysclk (void) |
| uint32_t | lpc32xx_hclkpll_clk (void) |
| uint32_t | lpc32xx_periph_clk (void) |
| uint32_t | lpc32xx_hclk (void) |
| uint32_t | lpc32xx_arm_clk (void) |
| uint32_t | lpc32xx_ddram_clk (void) |
| void | lpc32xx_select_nand_controller (lpc32xx_nand_controller nand_controller) |
| void | bsp_restart (void *addr) |
| void * | bsp_idle_thread (uintptr_t arg) |
| uint32_t | lpc32xx_magic_zero_begin [] |
| Begin of magic zero area. More... | |
| uint32_t | lpc32xx_magic_zero_end [] |
| End of magic zero area. More... | |
| uint32_t | lpc32xx_magic_zero_size [] |
| Size of magic zero area. More... | |
| #define LPC32XX_DO_RESTART | ( | addr | ) |
| #define LPC32XX_DO_STOP_ETHERNET |
| #define LPC32XX_DO_STOP_GPDMA |
| #define LPC32XX_DO_STOP_USB |
| void* bsp_idle_thread | ( | uintptr_t | ignored | ) |
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
| void* lpc32xx_idle | ( | uintptr_t | ignored | ) |
| uint32_t lpc32xx_magic_zero_begin[] |
A read from this area returns zero. Writes have no effect.
| uint32_t lpc32xx_magic_zero_end[] |
| uint32_t lpc32xx_magic_zero_size[] |
1.8.15
