RTEMS
5.1-rc2
NXP LPC176X Board Support Package. More...
Modules | |
| DMA Support | |
| Direct memory access (DMA) support. | |
| System Clocks | |
| System clocks. | |
Files | |
| file | btimer.c |
| Timer benchmark functions for the lpc176x bsp. | |
| file | can.c |
| CAN controller for the mbed lpc1768 board. | |
| file | console-config.c |
| Console configuration. | |
| file | lpc-gpio.c |
| GPIO library for the lpc176x bsp. | |
| file | adc-defs.h |
| ADC library for the lpc176x bsp. | |
| file | adc.h |
| file | can-defs.h |
| CAN controller for the lpc176x controller. | |
| file | can.h |
| file | common-types.h |
| Definitions types used by some devices in common. | |
| file | gpio-defs.h |
| API definitions of the GPIO driver for the lpc176x bsp in RTEMS. | |
| file | io-defs.h |
| Input/output module definitions. | |
| file | io.h |
| Input/output module methods definitions. | |
| file | lpc-clock-config.h |
| Clock driver configuration. | |
| file | lpc-gpio.h |
| API of the GPIO driver for the lpc176x bsp in RTEMS. | |
| file | lpc176x.h |
| Specific register definitions according to lpc176x family boards. | |
| file | mbed-pinmap.h |
| Pins of the mbed lpc1768 See http://mbed.org/media/uploads/chris/mbed-005.1.pdf for references. | |
| file | pwmout-defs.h |
| PWM-Out controller for the mbed lpc1768 board. | |
| file | pwmout.h |
| file | timer-defs.h |
| API definitions of the for the timer of the lpc176x bsp. | |
| file | timer.h |
| Timer API for the lpc176x bsp. | |
| file | watchdog-defs.h |
| API definitions of the Watchdog driver for the lpc176x bsp in RTEMS. | |
| file | watchdog.h |
| API of the Watchdog driver for the lpc176x bsp in RTEMS. | |
| file | bsp.h |
| Global BSP definitions. | |
| file | pwmout.c |
| file | rtc-config.c |
| RTC configuration. | |
| file | adc.c |
| file | bspidle.c |
| Idle task. | |
| file | bspstart.c |
| Startup code. | |
| file | bspstarthooks.c |
| First configurations and initializations to the correct functionality of the board. | |
| file | io.c |
| Input/output module methods. | |
| file | restart.c |
| Restart implementation. | |
| file | watchdog.c |
| Watchdog controller for the mbed lpc176x family boards. | |
| file | timer.c |
| Timer controller for the mbed lpc1768 board. | |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. More... | |
| void | bsp_restart (const void *addr) |
| Restarts the bsp with "addr" address. More... | |
| void* bsp_idle_thread | ( | uintptr_t | ignored | ) |
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
| void bsp_restart | ( | const void * | addr | ) |
| addr | Address used to restart the bsp |
1.8.15
