RTEMS  5.1
watchdog-defs.h
1
9 /*
10  * Copyright (c) 2014 Taller Technologies.
11  *
12  * @author Boretto Martin (martin.boretto@tallertechnologies.com)
13  * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
14  * @author Lenarduzzi Federico (federico.lenarduzzi@tallertechnologies.com)
15  * @author Daniel Chicco (daniel.chicco@tallertechnologies.com)
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef LIBBSP_ARM_LPC176X_WATCHDOG_DEFS_H
23 #define LIBBSP_ARM_LPC176X_WATCHDOG_DEFS_H
24
25 #include <rtems/score/cpu.h>
26 #include <bsp.h>
27 #include <bspopts.h>
28 #include <bsp/utility.h>
29 #include <bsp/irq.h>
30 #include <bsp/common-types.h>
31
32 #ifdef __cplusplus
33 extern "C" {
34 #endif /* __cplusplus */
35
36 #define LPC176X_WDMOD_BASE 0x40000000U
37 #define LPC176X_WDFEED_CON 0XAAU
38 #define LPC176X_WDFEED_CFG 0X55U
39 #define LPC176X_WD_PRESCALER_DIVISOR 4000000U
40 #define LPC176X_WWDT_MOD_WDEN BSP_BIT32( 0 )
41 #define LPC176X_WWDT_MOD_WDRESET BSP_BIT32( 1 )
42 #define LPC176X_WWDT_MOD_WDTOF BSP_BIT32( 2 )
43 #define LPC176X_WWDT_MOD_WDINT BSP_BIT32( 3 )
44 #define LPC176X_WWDT_CLKSEL_WDSEL_IRC 0x0U
45 #define LPC176X_WWDT_CLKSEL_WDSEL_PCLK 0x1U
46 #define LPC176X_WWDT_CLKSEL_WDSEL_RTC 0x2U
47 #define LPC176X_WD_INTERRUPT_VECTOR_NUMBER 0U
48 #define LPC176X_WDMOD ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + 0x00U ) )
49 #define LPC176X_WDTC ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + 0x04U ) )
50 #define LPC176X_WDFEED ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + \
51  0x08U ) )
52 #define LPC176X_WDTV ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + 0x0CU ) )
53 #define LPC176X_WDCLKSEL ( *(volatile uint32_t *) ( LPC176X_WDMOD_BASE + \
54  0x10U ) )
55
60
61 #ifdef __cplusplus
62 }
63 #endif /* __cplusplus */
64
65 #endif /* LIBBSP_ARM_LPC176X_WATCHDOG_DEFS_H */
Utility macros.
Definitions types used by some devices in common.
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
rtems_interrupt_handler lpc176x_wd_isr_funct
A function that attends an interruption for a watchdog.
Definition: watchdog-defs.h:59
