RTEMS
5.1
Definitions types used by some devices in common. More...
struct | lpc176x_fio |
Fast Input/Output registers representation. More... | |
Typedefs | |
typedef uint32_t | lpc176x_pin_number |
A pin of the board. | |
typedef uint32_t | lpc176x_microseconds |
Microseconds representation. | |
Enumerations | |
enum | lpc176x_module { LPC176X_MODULE_WD, LPC176X_MODULE_ADC, LPC176X_MODULE_CAN_0, LPC176X_MODULE_CAN_1, LPC176X_MODULE_ACCF, LPC176X_MODULE_DAC, LPC176X_MODULE_GPDMA, LPC176X_MODULE_GPIO, LPC176X_MODULE_I2S, LPC176X_MODULE_MCI, LPC176X_MODULE_MCPWM, LPC176X_MODULE_PCB, LPC176X_MODULE_PWM_0, LPC176X_MODULE_PWM_1, LPC176X_MODULE_QEI, LPC176X_MODULE_RTC, LPC176X_MODULE_SYSCON, LPC176X_MODULE_TIMER_0, LPC176X_MODULE_TIMER_1, LPC176X_MODULE_TIMER_2, LPC176X_MODULE_TIMER_3, LPC176X_MODULE_UART_0, LPC176X_MODULE_UART_1, LPC176X_MODULE_UART_2, LPC176X_MODULE_UART_3, LPC176X_MODULE_USB } |
lpc176x module representation. More... | |
enum | lpc176x_module_clock { LPC176X_MODULE_PCLK_DEFAULT = 0x4U, LPC176X_MODULE_CCLK = 0x1U, LPC176X_MODULE_CCLK_2 = 0x2U, LPC176X_MODULE_CCLK_4 = 0x0U, LPC176X_MODULE_CCLK_6 = 0x3U, LPC176X_MODULE_CCLK_8 = 0x3U } |
Defines all the clock modules. More... | |
enum lpc176x_module |
Enumerated type to define the set of modules for a lpc176x board.
enum lpc176x_module_clock |
Enumerated type to define the set of clock modules for a lpc176x board.
