RTEMS  5.1
uti596.h
1 /* uti596.h: Contains the defines and structures used by the uti596 driver */
2
3 /*
4  * EII: March 11: Created v. 0.0
5  */
6
7 #ifndef UTI596_H
8 #define UTI596_H
9 #include <rtems/error.h>
10 #include <rtems/rtems_bsdnet.h>
11
12 #include <sys/param.h>
13 #include <sys/mbuf.h>
14 #include <sys/socket.h>
15 #include <sys/sockio.h>
16
17 #include <net/if.h>
18
19 #include <netinet/in.h>
20 #include <netinet/if_ether.h>
21
22 /* Ethernet statistics */
23
25  int rx_packets; /* total packets received */
26  int tx_packets; /* total packets transmitted */
27  int rx_errors; /* bad packets received */
28  int tx_errors; /* packet transmit problems */
29  int rx_dropped; /* no space in buffers */
30  int tx_dropped;
31  int tx_retries_exceeded; /* excessive retries */
32  int multicast; /* multicast packets received */
33  int collisions;
34
35  /* detailed rx_errors: */
36  int rx_length_errors;
37  int rx_over_errors; /* receiver ring buff overflow */
38  int rx_crc_errors; /* recved pkt with crc error */
39  int rx_frame_errors; /* recv'd frame alignment error */
40  int rx_fifo_errors; /* recv'r fifo overrun */
41  int rx_missed_errors; /* receiver missed packet */
42
43  /* detailed tx_errors */
44  int tx_aborted_errors;
45  int tx_carrier_errors;
46  int tx_fifo_errors;
47  int tx_heartbeat_errors;
48  int tx_window_errors;
49
50  /* NIC reset errors */
51  int nic_reset_count; /* The number of times uti596reset() has been called. */
52 };
53
54 #define CMD_EOL 0x8000 /* The last command of the list, stop. */
55 #define CMD_SUSP 0x4000 /* Suspend after doing cmd. */
56 #define CMD_INTR 0x2000 /* Interrupt after doing cmd. */
57
58 #define CMD_FLEX 0x0008 /* Enable flexible memory model */
59
60 #define SCB_STAT_CX 0x8000 /* Cmd completes with 'I' bit set */
61 #define SCB_STAT_FR 0x4000 /* Frame Received */
62 #define SCB_STAT_CNA 0x2000 /* Cmd unit Not Active */
63 #define SCB_STAT_RNR 0x1000 /* Receiver Not Ready */
64
65 #define SCB_CUS_SUSPENDED 0x0100
66 #define SCB_CUS_ACTIVE 0x0200
67
68 #define STAT_C 0x8000 /* Set to 1 after execution */
69 #define STAT_B 0x4000 /* 1 : Cmd being executed, 0 : Cmd done. */
70 #define STAT_OK 0x2000 /* 1: Command executed ok 0 : Error */
71 #define STAT_A 0x1000 /* command has been aborted */
72
73 #define STAT_S11 0x0800
74 #define STAT_S10 0x0400
75 #define STAT_S9 0x0200
76 #define STAT_S8 0x0100
77 #define STAT_S7 0x0080
78 #define STAT_S6 0x0040
79 #define STAT_S5 0x0020
80 #define STAT_MAX_COLLS 0x000F
81
82 #define RBD_STAT_P 0x4000 /* prefetch */
83 #define RBD_STAT_F 0x4000 /* used */
84
85 #define CUC_START 0x0100
86 #define CUC_RESUME 0x0200
87 #define CUC_SUSPEND 0x0300
88 #define CUC_ABORT 0x0400
89 #define RX_START 0x0010
90 #define RX_RESUME 0x0020
91 #define RX_SUSPEND 0x0030
92 #define RX_ABORT 0x0040
93
94 #define RU_SUSPENDED 0x0010
95 #define RU_NO_RESOURCES 0x0020
96 #define RU_READY 0x0040
97
98 #define I596_NULL ( ( void * ) 0xffffffff)
99 #define UTI_596_END_OF_FRAME 0x8000
100
101 struct i596_tbd; /* necessary forward declaration */
102
103 enum commands {
104  CmdNOp = 0,
105  CmdSASetup = 1,
106  CmdConfigure = 2,
107  CmdMulticastList = 3,
108  CmdTx = 4,
109  CmdTDR = 5,
110  CmdDump = 6,
111  CmdDiagnose = 7
112 };
113
114 /*
115  * 82596 Dump Command Result
116  */
117 typedef volatile struct i596_dump_result {
118  unsigned char bf;
119  unsigned char config_bytes[11];
120  unsigned char reserved1[2];
121  unsigned char ia_bytes[6];
122  unsigned short last_tx_status;
123  unsigned short tx_crc_byte01;
124  unsigned short tx_crc_byte23;
125  unsigned short rx_crc_byte01;
126  unsigned short rx_crc_byte23;
127  unsigned short rx_temp_mem01;
128  unsigned short rx_temp_mem23;
129  unsigned short rx_temp_mem45;
130  unsigned short last_rx_status;
131  unsigned short hash_reg01;
132  unsigned short hash_reg23;
133  unsigned short hash_reg45;
134  unsigned short hash_reg67;
135  unsigned short slot_time_counter;
136  unsigned short wait_time_counter;
137  unsigned short rx_frame_length;
138  unsigned long reserved2;
139  unsigned long cb_in3;
140  unsigned long cb_in2;
141  unsigned long cb_in1;
142  unsigned long la_cb_addr;
143  unsigned long rdb_pointer;
144  unsigned long int_memory;
145  unsigned long rfd_size;
146  unsigned long tbd_pointer;
147  unsigned long base_addr;
148  unsigned long ru_temp_reg;
149  unsigned long tcb_count;
150  unsigned long next_rb_size;
151  unsigned long next_rb_addr;
152  unsigned long curr_rb_size;
153  unsigned long la_rbd_addr;
154  unsigned long next_rbd_addr;
155  unsigned long curr_rbd_addr;
156  unsigned long curr_rb_count;
157  unsigned long next_fd_addr;
158  unsigned long curr_fd_add;
159  unsigned long temp_cu_reg;
160  unsigned long next_tb_count;
161  unsigned long buffer_addr;
162  unsigned long la_tbd_addr;
163  unsigned long next_tbd_addr;
164  unsigned long cb_command;
165  unsigned long next_cb_addr;
166  unsigned long curr_cb_addr;
167  unsigned long scb_cmd_word;
168  unsigned long scb_pointer;
169  unsigned long cb_stat_word;
170  unsigned long mm_lfsr;
171  unsigned char micro_machine_bit_array[28];
172  unsigned char cu_port[16];
173  unsigned long mm_alu;
174  unsigned long reserved3;
175  unsigned long mm_temp_a_rr;
176  unsigned long mm_temp_a;
177  unsigned long tx_dma_b_cnt;
178  unsigned long mm_input_port_addr_reg;
179  unsigned long tx_dma_addr;
180  unsigned long mm_port_reg1;
181  unsigned long rx_dma_b_cnt;
182  unsigned long mm_port_reg2;
183  unsigned long rx_dma_addr;
184  unsigned long reserved4;
185  unsigned long bus_t_timers;
186  unsigned long diu_cntrl_reg;
187  unsigned long reserved5;
188  unsigned long sysbus;
189  unsigned long biu_cntrl_reg;
190  unsigned long mm_disp_reg;
191  unsigned long mm_status_reg;
192  unsigned short dump_status;
194
195 typedef volatile struct i596_selftest {
196  unsigned long rom_signature;
197  unsigned long results;
198 } i596_selftest;
199
200 /*
201  * Action commands
202  * (big endian, linear mode)
203  */
204 typedef volatile struct i596_cmd {
205  unsigned short status;
206  unsigned short command;
207  volatile struct i596_cmd *next;
208 } i596_cmd;
209
210 typedef volatile struct i596_nop {
211  i596_cmd cmd;
212 } i596_nop;
213
214 typedef volatile struct i596_set_add {
215  i596_cmd cmd;
216  char data[8];
217 } i596_set_add;
218
219 typedef volatile struct i596_configure {
220  i596_cmd cmd;
221  char data[16];
223
224 typedef volatile struct i596_tx {
225  i596_cmd cmd;
226  volatile struct i596_tbd *pTbd;
227  unsigned short count;
228  unsigned short pad;
229  char data[6];
230  unsigned short length;
231 } i596_tx;
232
233 typedef volatile struct i596_tdr {
234  i596_cmd cmd;
235  unsigned long data;
236 } i596_tdr;
237
238 typedef volatile struct i596_dump {
239  i596_cmd cmd;
240  char *pData;
241 } i596_dump;
242
243 /*
244  * Transmit buffer descriptor
245  */
246 typedef volatile struct i596_tbd {
247  unsigned short size;
248  unsigned short pad;
249  volatile struct i596_tbd *next;
250  char *data;
251 } i596_tbd;
252
253 /*
254  * Receive buffer descriptor
255  * (flexible memory structure)
256  */
257 typedef volatile struct i596_rbd {
258  unsigned short count;
259  unsigned short offset;
260  volatile struct i596_rbd *next;
261  char *data;
262  unsigned short size;
263  unsigned short pad;
264 } i596_rbd;
265
266 /*
267  * Receive Frame Descriptor
268  */
269 typedef volatile struct i596_rfd {
270  unsigned short stat;
271  unsigned short cmd;
272  volatile struct i596_rfd *next;
273  i596_rbd *pRbd;
274  unsigned short count;
275  unsigned short size;
276  char data [1532];
277 } i596_rfd;
278
279 /*
280  * System Control Block
281  */
282 typedef volatile struct i596_scb {
283  unsigned short status;
284  unsigned short command;
285  unsigned long cmd_pointer;
286  unsigned long rfd_pointer;
287  unsigned long crc_err;
288  unsigned long align_err;
289  unsigned long resource_err;
290  unsigned long over_err;
291  unsigned long rcvdt_err;
292  unsigned long short_err;
293  unsigned short t_off;
294  unsigned short t_on;
295  i596_cmd *pCmd;
296  i596_rfd *pRfd;
297 } i596_scb;
298
299 /*
300  * Intermediate System Configuration Pointer
301  */
302 typedef volatile struct i596_iscp {
303  uint8_t null1; /* Always zero */
304  uint8_t busy; /* Busy byte */
305  unsigned short scb_offset; /* Not used in linear mode */
306  unsigned long scb_pointer; /* Swapped pointer to scb */
307  i596_scb *scb; /* Real pointer to scb */
308 } i596_iscp;
309
310 /*
311  * System Configuration Pointer
312  */
313 typedef volatile struct i596_scp {
314  unsigned long sysbus; /* Only low 8 bits are used */
315  unsigned long pad; /* Must be zero */
316  unsigned long iscp_pointer; /* Swapped pointer to iscp */
317  i596_iscp *iscp; /* Real pointer to iscp */
318 } i596_scp;
319
320 /*
321  * Device Dependent Data Structure
322  */
323 typedef volatile struct uti596_softc {
324  struct arpcom arpcom;
325  i596_scp *pScp; /* Block aligned on 16 byte boundary */
326  i596_scp *base_scp; /* Unaligned block. Need for free() */
327  i596_iscp iscp;
328  i596_scb scb;
329  i596_set_add set_add;
330  i596_configure set_conf;
331  i596_tdr tdr;
332  i596_nop nop;
333  i596_tx *pTxCmd;
334  i596_tbd *pTbd;
335
336  i596_rfd *pBeginRFA;
337  i596_rfd *pEndRFA;
338  i596_rfd *pLastUnkRFD;
339  i596_rbd *pLastUnkRBD;
340  i596_rfd *pEndSavedQueue;
341  i596_cmd *pCmdHead;
342  i596_cmd *pCmdTail; /* unneeded, as chaining not used, but implemented */
343
344  rtems_id rxDaemonTid;
345  rtems_id txDaemonTid;
346  rtems_id resetDaemonTid;
347
348  struct enet_statistics stats;
349  int started;
350  unsigned long rxInterrupts;
351  unsigned long txInterrupts;
352  volatile int cmdOk;
353  unsigned short * pCurrent_command_status;
354  int resetDone;
355  unsigned long txRawWait;
356  i596_rfd *pInboundFrameQueue;
357  short int rxBdCount;
358  short int txBdCount;
359  short int countRFD;
360  short int savedCount;
361  i596_rfd *pSavedRfdQueue;
362  rtems_name semaphore_name;
363  rtems_id semaphore_id;
364  char zeroes[64];
365  unsigned long rawsndcnt;
366  int nic_reset; /* flag for requesting that ISR issue a reset quest */
367 } uti596_softc_;
368
369 #endif /* UTI596_H */
Definition: uti596.h:233
Definition: uti596.h:238
Definition: uti596.h:282
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
Definition: uti596.h:195
#define nop()
Definition: sparc.h:175
Definition: uti596.h:214
RTEMS Error Reporting.
Definition: uti596.h:302
Definition: uti596.h:257
Definition: uti596.h:246
Definition: uti596.h:204
Definition: uti596.h:219
Definition: uti596.h:117
Definition: uti596.h:269
Definition: uti596.h:323
Definition: uti596.h:224
Definition: uti596.h:210
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: uti596.h:313
