RTEMS  5.1
Macros | Functions
sparc.h File Reference
Information Required to Build RTEMS for a Particular Member of the SPARC Family. More...
#define SPARC_HAS_BITSCAN   0
#define SPARC_NUMBER_OF_REGISTER_WINDOWS   8
#define SPARC_LEON3FT_B2BST_NOP
#define SPARC_HAS_FPU   1
#define CPU_MODEL_NAME   "w/FPU"
#define CPU_NAME   "SPARC"
#define SPARC_PSR_CWP_MASK   0x07 /* bits 0 - 4 */
#define SPARC_PSR_ET_MASK   0x00000020 /* bit 5 */
#define SPARC_PSR_PS_MASK   0x00000040 /* bit 6 */
#define SPARC_PSR_S_MASK   0x00000080 /* bit 7 */
#define SPARC_PSR_PIL_MASK   0x00000F00 /* bits 8 - 11 */
#define SPARC_PSR_EF_MASK   0x00001000 /* bit 12 */
#define SPARC_PSR_EC_MASK   0x00002000 /* bit 13 */
#define SPARC_PSR_ICC_MASK   0x00F00000 /* bits 20 - 23 */
#define SPARC_PSR_VER_MASK   0x0F000000 /* bits 24 - 27 */
#define SPARC_PSR_IMPL_MASK   0xF0000000 /* bits 28 - 31 */
#define SPARC_PSR_CWP_BIT_POSITION   0 /* bits 0 - 4 */
#define SPARC_PSR_ET_BIT_POSITION   5 /* bit 5 */
#define SPARC_PSR_PS_BIT_POSITION   6 /* bit 6 */
#define SPARC_PSR_S_BIT_POSITION   7 /* bit 7 */
#define SPARC_PSR_PIL_BIT_POSITION   8 /* bits 8 - 11 */
#define SPARC_PSR_EF_BIT_POSITION   12 /* bit 12 */
#define SPARC_PSR_EC_BIT_POSITION   13 /* bit 13 */
#define SPARC_PSR_ICC_BIT_POSITION   20 /* bits 20 - 23 */
#define SPARC_PSR_VER_BIT_POSITION   24 /* bits 24 - 27 */
#define SPARC_PSR_IMPL_BIT_POSITION   28 /* bits 28 - 31 */
#define LEON3_ASR17_PROCESSOR_INDEX_SHIFT   28
#define SPARC_SWTRAP_SYSCALL   0
#define SPARC_SWTRAP_IRQDIS   9
#define SPARC_SWTRAP_IRQEN   10
#define SPARC_SWTRAP_IRQDIS_FP   11
#define nop()
#define sparc_get_psr(_psr)
 Macro to obtain the PSR. More...
#define sparc_set_psr(_psr)
 Macro to set the PSR. More...
#define sparc_get_tbr(_tbr)
 Macro to obtain the TBR. More...
#define sparc_set_tbr(_tbr)
 Macro to set the TBR. More...
#define sparc_get_wim(_wim)
 Macro to obtain the WIM. More...
#define sparc_set_wim(_wim)
 Macro to set the WIM. More...
#define sparc_get_y(_y)
 Macro to obtain the Y register. More...
#define sparc_set_y(_y)
 Macro to set the Y register. More...
#define sparc_flash_interrupts(_psr)
 SPARC flash processor interrupts. More...
#define sparc_get_interrupt_level(_level)
 SPARC obtain interrupt level. More...
void sparc_syscall_exit (uint32_t exitcode1, uint32_t exitcode2) RTEMS_NO_RETURN
 SPARC exit through system call 1. More...
This file contains the information required to build RTEMS for a particular member of the SPARC family. It does this by setting variables to indicate which implementation dependent features are present in a particular member of the family.
◆ CPU_MODEL_NAME
This macro contains a string describing the multilib variant being build.
◆ CPU_NAME
Define the name of the CPU family.
◆ nop
#define nop ( )
Value:
do { \
__asm__ volatile ( "nop" ); \
} while ( 0 )
This macro is a standard nop instruction.
◆ sparc_flash_interrupts
#define sparc_flash_interrupts (   _psr)
Value:
do { \
sparc_enable_interrupts( (_psr) ); \
_psr = sparc_disable_interrupts(); \
} while ( 0 )
This method is invoked to temporarily enable all maskable interrupts.
Parameters
[in]_psris the PSR returned by sparc_disable_interrupts.
◆ sparc_get_interrupt_level
#define sparc_get_interrupt_level (   _level)
Value:
do { \
uint32_t _psr_level = 0; \
sparc_get_psr( _psr_level ); \
(_level) = \
} while ( 0 )
Definition: sparc.h:148
Definition: sparc.h:194
Definition: sparc.h:127
This method is invoked to obtain the current interrupt disable level.
Parameters
[in]_levelis the PSR returned by sparc_disable_interrupts.
◆ sparc_get_psr
#define sparc_get_psr (   _psr)
Value:
do { \
(_psr) = 0; \
__asm__ volatile( "rd %%psr, %0" : "=r" (_psr) : "0" (_psr) ); \
} while ( 0 )
This macro returns the current contents of the PSR register in _psr.
◆ sparc_get_tbr
#define sparc_get_tbr (   _tbr)
Value:
do { \
(_tbr) = 0; /* to avoid unitialized warnings */ \
__asm__ volatile( "rd %%tbr, %0" : "=r" (_tbr) : "0" (_tbr) ); \
} while ( 0 )
This macro returns the current contents of the TBR register in _tbr.
◆ sparc_get_wim
#define sparc_get_wim (   _wim)
Value:
do { \
__asm__ volatile( "rd %%wim, %0" : "=r" (_wim) : "0" (_wim) ); \
} while ( 0 )
This macro returns the current contents of the WIM field in _wim.
◆ sparc_get_y
#define sparc_get_y (   _y)
Value:
do { \
__asm__ volatile( "rd %%y, %0" : "=r" (_y) : "0" (_y) ); \
} while ( 0 )
This macro returns the current contents of the Y register in _y.
◆ SPARC_HAS_BITSCAN
Some higher end SPARCs have a bitscan instructions. It would be nice to take advantage of them. Right now, there is no port to a CPU model with this feature and no (untested) code that is based on this feature flag.
◆ SPARC_HAS_FPU
This macro indicates whether this multilib variation has hardware floating point or not. We use the gcc cpp predefine _SOFT_FLOAT to determine that.
◆ SPARC_LEON3FT_B2BST_NOP
See GRLIB-TN-0009: "LEON3FT Stale Cache Entry After Store with Data Tag Parity Error"
◆ SPARC_NUMBER_OF_REGISTER_WINDOWS
This should be OK until a port to a higher end SPARC processor is made that has more than 8 register windows. If this cannot be determined based on multilib settings (v7/v8/v9), then the cpu_asm.S code that depends on this will have to move to libcpu.
◆ SPARC_PSR_CWP_BIT_POSITION
This constant is the starting bit position of the CWP in the PSR.
◆ SPARC_PSR_CWP_MASK
PSR masks and starting bit positions
NOTE: Reserved bits are ignored.
◆ SPARC_PSR_EC_BIT_POSITION
This constant is the starting bit position of the EC in the PSR.
◆ SPARC_PSR_EC_MASK
This constant is a mask for the EC bits in the PSR.
◆ SPARC_PSR_EF_BIT_POSITION
This constant is the starting bit position of the EF in the PSR.
◆ SPARC_PSR_EF_MASK
This constant is a mask for the EF bits in the PSR.
◆ SPARC_PSR_ET_BIT_POSITION
This constant is the starting bit position of the ET in the PSR.
◆ SPARC_PSR_ET_MASK
This constant is a mask for the ET bits in the PSR.
◆ SPARC_PSR_ICC_BIT_POSITION
This constant is the starting bit position of the ICC in the PSR.
◆ SPARC_PSR_ICC_MASK
This constant is a mask for the ICC bits in the PSR.
◆ SPARC_PSR_IMPL_BIT_POSITION
This constant is the starting bit position of the IMPL in the PSR.
◆ SPARC_PSR_IMPL_MASK
This constant is a mask for the IMPL bits in the PSR.
◆ SPARC_PSR_PIL_BIT_POSITION
This constant is the starting bit position of the PIL in the PSR.
◆ SPARC_PSR_PIL_MASK
This constant is a mask for the PIL bits in the PSR.
◆ SPARC_PSR_PS_BIT_POSITION
This constant is the starting bit position of the PS in the PSR.
◆ SPARC_PSR_PS_MASK
This constant is a mask for the PS bits in the PSR.
◆ SPARC_PSR_S_BIT_POSITION
This constant is the starting bit position of the S in the PSR.
◆ SPARC_PSR_S_MASK
This constant is a mask for the S bits in the PSR.
◆ SPARC_PSR_VER_BIT_POSITION
This constant is the starting bit position of the VER in the PSR.
◆ SPARC_PSR_VER_MASK
This constant is a mask for the VER bits in the PSR.
◆ sparc_set_psr
#define sparc_set_psr (   _psr)
Value:
do { \
__asm__ volatile ( "mov %0, %%psr " : "=r" ((_psr)) : "0" ((_psr)) ); \
nop(); \
nop(); \
nop(); \
} while ( 0 )
This macro sets the PSR register to the value in _psr.
◆ sparc_set_tbr
#define sparc_set_tbr (   _tbr)
Value:
do { \
__asm__ volatile( "wr %0, 0, %%tbr" : "=r" (_tbr) : "0" (_tbr) ); \
} while ( 0 )
This macro sets the TBR register to the value in _tbr.
◆ sparc_set_wim
#define sparc_set_wim (   _wim)
Value:
do { \
__asm__ volatile( "wr %0, %%wim" : "=r" (_wim) : "0" (_wim) ); \
nop(); \
nop(); \
nop(); \
} while ( 0 )
This macro sets the WIM field to the value in _wim.
◆ sparc_set_y
#define sparc_set_y (   _y)
Value:
do { \
__asm__ volatile( "wr %0, %%y" : "=r" (_y) : "0" (_y) ); \
} while ( 0 )
This macro sets the Y register to the value in _y.
◆ sparc_syscall_exit()
void sparc_syscall_exit ( uint32_t  exitcode1,
uint32_t  exitcode2
This method is invoked to go into system error halt. The optional arguments can be given to hypervisor, hardware debugger, simulator or similar.
System error mode is entered when taking a trap when traps have been disabled. What happens when error mode is entered depends on the motherboard. In a typical development systems the CPU relingish control to the debugger, simulator, hypervisor or similar. The following steps are taken:
  1. Going into system error mode by Software Trap 0
  2. g1=1 (syscall 1 - Exit)
  3. g2=Primary exit code
  4. g3=Secondary exit code. Dependends on g2 exit type.
This function never returns.
Parameters
[in]exitcode1Primary exit code stored in CPU g2 register after exit
[in]exitcode2Primary exit code stored in CPU g3 register after exit
