RTEMS
5.1
Data Fields | |
struct arpcom | arpcom |
i596_scp * | pScp |
i596_scp * | base_scp |
i596_iscp | iscp |
i596_scb | scb |
i596_set_add | set_add |
i596_configure | set_conf |
i596_tdr | tdr |
i596_nop | nop |
i596_tx * | pTxCmd |
i596_tbd * | pTbd |
i596_rfd * | pBeginRFA |
i596_rfd * | pEndRFA |
i596_rfd * | pLastUnkRFD |
i596_rbd * | pLastUnkRBD |
i596_rfd * | pEndSavedQueue |
i596_cmd * | pCmdHead |
i596_cmd * | pCmdTail |
rtems_id | rxDaemonTid |
rtems_id | txDaemonTid |
rtems_id | resetDaemonTid |
struct enet_statistics | stats |
int | started |
unsigned long | rxInterrupts |
unsigned long | txInterrupts |
volatile int | cmdOk |
unsigned short * | pCurrent_command_status |
int | resetDone |
unsigned long | txRawWait |
i596_rfd * | pInboundFrameQueue |
short int | rxBdCount |
short int | txBdCount |
short int | countRFD |
short int | savedCount |
i596_rfd * | pSavedRfdQueue |
rtems_name | semaphore_name |
rtems_id | semaphore_id |
char | zeroes [64] |
unsigned long | rawsndcnt |
int | nic_reset |
