#define | TFSINFOSIZE 23 /* Max size of info string (mod4-1). */ |
#define | TFSNAMESIZE 23 /* name that can be used in TFS. */ |
#define | TFS_CHANGELOG_SIZE 0 /* facility within tfs. */ |
#define | TFS_CHANGELOG_FILE ".tfschlog" |
#define | SYMFILE "symtbl" /* used by the monitor for the symbol */ |
#define | MINUSRLEVEL 0 /* Minimum user level supported. */ |
#define | MAXUSRLEVEL 3 /* Maximum user level supported. */ |
#define | TFS_RESERVED 4 /* Number of "reserved" entries (ulong) */ |
#define | TFS_EXEC 0x00000001 /* 'e': Executable script. */ |
#define | TFS_BRUN 0x00000002 /* 'b': To be executed at boot. */ |
#define | TFS_QRYBRUN 0x00000004 /* 'B': To be executed at boot if */ |
#define | TFS_SYMLINK 0x00000008 /* 'l': Symbolic link file. */ |
#define | TFS_EBIN 0x00000010 /* 'E': Executable binary (coff/elf/a.out). */ |
#define | TFS_CPRS 0x00000040 /* 'c': File is compressed. */ |
#define | TFS_IPMOD 0x00000080 /* 'i': File is in-place modifiable. */ |
#define | TFS_UNREAD 0x00000100 /* 'u': File is not even readable if the */ |
#define | TFS_ULVLMSK 0x00000600 /* User level mask defines 4 access levels: */ |
#define | TFS_ULVL0 0x00000000 /* '0' level 0 */ |
#define | TFS_ULVL1 0x00000200 /* '1' level 1 */ |
#define | TFS_ULVL2 0x00000400 /* '2' level 2 */ |
#define | TFS_ULVL3 0x00000600 /* '3' level 3 */ |
#define | TFS_NSTALE |
#define | TFS_ACTIVE 0x00008000 /* Used to indicate that file is not deleted. */ |
#define | TFS_ULVLMAX TFS_ULVL3 |
#define | TFS_USRLVL(f) ((f->flags & TFS_ULVLMSK) >> 9) |
#define | TFS_RDONLY 0x00010000 /* File is opened for reading. */ |
#define | TFS_CREATE 0x00020000 /* File is to be created. Error if file */ |
#define | TFS_APPEND 0x00040000 /* Append to existing file. If OR'ed */ |
#define | TFS_ALLFFS 0x00080000 /* File is created with all FFs. */ |
#define | TFS_CREATERM 0x00100000 /* File is to be created. If file with */ |
#define | TFS_RCFILE "monrc" |
#define | TFS_ERRMSG 1 |
#define | TFS_MEMUSE 2 |
#define | TFS_MEMDEAD 3 |
#define | TFS_DEFRAG 4 |
#define | TFS_TELL 5 |
#define | TFS_UNOPEN 7 |
#define | TFS_FATOB 8 |
#define | TFS_FBTOA 9 |
#define | TFS_MEMAVAIL 10 |
#define | TFS_TIMEFUNCS 11 |
#define | TFS_DOCOMMAND 12 |
#define | TFS_INITDEV 13 |
#define | TFS_CHECKDEV 14 |
#define | TFS_DEFRAGDEV 15 |
#define | TFS_DEFRAGOFF 16 |
#define | TFS_DEFRAGON 17 |
#define | TFS_HEADROOM 18 |
#define | TFS_FCOUNT 19 |
#define | TFSHDRSIZ sizeof(struct tfshdr) |
#define | TFS_OKAY 0 |
#define | TFSERR_NOFILE -1 |
#define | TFSERR_NOSLOT -2 |
#define | TFSERR_EOF -3 |
#define | TFSERR_BADARG -4 |
#define | TFSERR_NOTEXEC -5 |
#define | TFSERR_BADCRC -6 |
#define | TFSERR_FILEEXISTS -7 |
#define | TFSERR_FLASHFAILURE -8 |
#define | TFSERR_WRITEMAX -9 |
#define | TFSERR_RDONLY -10 |
#define | TFSERR_BADFD -11 |
#define | TFSERR_BADHDR -12 |
#define | TFSERR_CORRUPT -13 |
#define | TFSERR_MEMFAIL -14 |
#define | TFSERR_NOTIPMOD -16 |
#define | TFSERR_MUTEXFAILURE -17 |
#define | TFSERR_FLASHFULL -18 |
#define | TFSERR_USERDENIED -19 |
#define | TFSERR_NAMETOOBIG -20 |
#define | TFSERR_FILEINUSE -21 |
#define | TFSERR_NOTCPRS -22 |
#define | TFSERR_NOTAVAILABLE -23 |
#define | TFSERR_BADFLAG -24 |
#define | TFSERR_CLEANOFF -25 |
#define | TFSERR_FLAKEYSOURCE -26 |
#define | TFSERR_BADEXTENSION -27 |
#define | TFSERR_MIN -100 |
#define | TFS_BEGIN 1 |
#define | TFS_CURRENT 2 |
#define | TFS_END 3 |
#define | TFS_DELETED(fp) (!((fp)->flags & TFS_ACTIVE)) |
#define | TFS_FILEEXISTS(fp) ((fp)->flags & TFS_ACTIVE) |
#define | TFS_ISCPRS(fp) ((fp)->flags & TFS_CPRS) |
#define | TFS_ISEXEC(fp) ((fp)->flags & TFS_EXEC) |
#define | TFS_ISBOOT(fp) ((fp)->flags & TFS_BRUN) |
#define | TFS_ISLINK(fp) ((fp)->flags & TFS_SYMLINK) |
#define | TFS_STALE(fp) (!((fp)->flags & TFS_NSTALE)) |
#define | TFS_FLAGS(fp) ((fp)->flags) |
#define | TFS_NAME(fp) ((fp)->name) |
#define | TFS_SIZE(fp) ((fp)->filsize) |
#define | TFS_TIME(fp) ((fp)->modtime) |
#define | TFS_INFO(fp) ((fp)->info) |
#define | TFS_NEXT(fp) ((fp)->next) |
#define | TFS_CRC(fp) ((fp)->filcrc) |
#define | TFS_ENTRY(fp) ((fp)->entry) |
#define | TFS_BASE(fp) ((char *)(fp)+(fp)->hdrsize) |
