RTEMS
5.1
#include <rtems/libio.h>
#include <rtems/imfs.h>
#include <ctype.h>
#include <termios.h>
#include <unistd.h>
#include <sys/fcntl.h>
#include <sys/filio.h>
#include <sys/ttycom.h>
#include <rtems/termiostypes.h>
#define | CBUFSIZE (rtems_termios_cbufsize) |
#define | RAW_INPUT_BUFFER_SIZE (rtems_termios_raw_input_size) |
#define | RAW_OUTPUT_BUFFER_SIZE (rtems_termios_raw_output_size) |
#define | FL_IREQXOF 1U /* input queue requests stop of incoming data */ |
#define | FL_ISNTXOF 2U /* XOFF has been sent to other side of line */ |
#define | FL_IRTSOFF 4U /* RTS has been turned off for other side.. */ |
#define | FL_ORCVXOF 0x10U /* XOFF has been received */ |
#define | FL_OSTOP 0x20U /* output has been stopped due to XOFF */ |
#define | FL_MDRTS 0x100U /* input controlled with RTS/CTS handshake */ |
#define | FL_MDXON 0x200U /* input controlled with XON/XOFF protocol */ |
#define | FL_MDXOF 0x400U /* output controlled with XON/XOFF protocol */ |
#define | NODISC(n) |
#define | TERMIOS_TXTASK_PRIO 10 |
#define | TERMIOS_RXTASK_PRIO 9 |
#define | TERMIOS_TXTASK_STACKSIZE 1024 |
#define | TERMIOS_RXTASK_STACKSIZE 1024 |
#define | TERMIOS_TX_START_EVENT RTEMS_EVENT_1 |
#define | TERMIOS_TX_TERMINATE_EVENT RTEMS_EVENT_0 |
#define | TERMIOS_RX_PROC_EVENT RTEMS_EVENT_1 |
#define | TERMIOS_RX_TERMINATE_EVENT RTEMS_EVENT_0 |
rtems_status_code | rtems_termios_device_install (const char *device_file, const rtems_termios_device_handler *handler, const rtems_termios_device_flow *flow, rtems_termios_device_context *context) |
Installs a Termios device. More... | |
rtems_status_code | rtems_termios_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg, const rtems_termios_callbacks *callbacks) |
rtems_status_code | rtems_termios_close (void *arg) |
rtems_status_code | rtems_termios_bufsize (size_t cbufsize, size_t raw_input, size_t raw_output) |
rtems_status_code | rtems_termios_ioctl (void *arg) |
void | rtems_termios_puts (const void *_buf, size_t len, struct rtems_termios_tty *tty) |
rtems_status_code | rtems_termios_write (void *arg) |
rtems_termios_iproc_status_code | rtems_termios_default_isig_handler (unsigned char c, struct rtems_termios_tty *tty) |
Default handler for ISIG (VINTR/VKILL) More... | |
rtems_status_code | rtems_termios_register_isig_handler (rtems_termios_isig_handler handler) |
Register handler for ISIG (VINTR/VKILL) More... | |
rtems_status_code | rtems_termios_read (void *arg) |
void | rtems_termios_rxirq_occured (struct rtems_termios_tty *tty) |
int | rtems_termios_enqueue_raw_characters (void *ttyp, const char *buf, int len) |
int | rtems_termios_dequeue_characters (void *ttyp, int len) |
struct rtems_termios_linesw | rtems_termios_linesw [MAXLDISC] |
int | rtems_termios_nlinesw |
TERMIOS serial line support
#define NODISC | ( | n | ) |
rtems_status_code rtems_termios_device_install | ( | const char * | device_file, |
const rtems_termios_device_handler * | handler, | ||
const rtems_termios_device_flow * | flow, | ||
rtems_termios_device_context * | context | ||
The installed Termios device may be removed via unlink().
[in] | device_file | The device file path. |
[in] | handler | The device handler. It must be persistent throughout the installed time of the device. |
[in] | flow | The device flow control handler. The device flow control handler are optional and may be NULL . If present must be persistent throughout the installed time of the device. |
[in] | context | The device context. It must be persistent throughout the installed time of the device. |
RTEMS_SUCCESSFUL | Successful operation. |
RTEMS_NO_MEMORY | Not enough memory to create a device node. |
RTEMS_UNSATISFIED | Creation of the device file failed. |
RTEMS_INCORRECT_STATE | Termios is not initialized. |
struct rtems_termios_linesw rtems_termios_linesw[MAXLDISC] |
int rtems_termios_nlinesw |
