RTEMS  5.1
sc16is752_context Struct Reference
SC16IS752 device context. More...
#include <sc16is752.h>
rtems_termios_device_context base
int(* write_reg )(sc16is752_context *ctx, uint8_t addr, const uint8_t *data, size_t len)
 Writes a register. More...
int(* read_reg )(sc16is752_context *ctx, uint8_t addr, uint8_t *data, size_t len)
 Reads a register. More...
int(* read_2_reg )(sc16is752_context *ctx, uint8_t addr_0, uint8_t addr_1, uint8_t data[2])
 Reads two registers. More...
bool(* first_open )(sc16is752_context *ctx)
 First open. More...
void(* last_close )(sc16is752_context *ctx)
 Last close. More...
bool(* install_irq )(sc16is752_context *ctx)
 Shall install the interrupt handler. More...
void(* remove_irq )(sc16is752_context *ctx)
 Shall remove the interrupt handler. More...
sc16is752_mode mode
 Device mode. More...
uint32_t input_frequency
 Input frequency in Hertz (dependent on crystal, see XTAL1 and XTAL2 pins). More...
rtems_termios_ttytty
 Corresponding Termios structure. More...
uint8_t ier
 Shadow Interrupt Enable Register (IER). More...
uint8_t tx_in_progress
 Characters placed into transmit FIFO. More...
uint8_t tx_fifo_free
 Count of free characters in the transmit FIFO. More...
uint8_t lcr
 Shadow Line Control Register (LCR). More...
uint8_t efcr
 Shadow Extra Features Control Register (EFCR). More...
Field Documentation
◆ efcr
uint8_t sc16is752_context::efcr
Internal variable.
◆ first_open
bool(* sc16is752_context::first_open) (sc16is752_context *ctx)
First open.
Internal handler.
◆ ier
uint8_t sc16is752_context::ier
Internal variable.
◆ input_frequency
uint32_t sc16is752_context::input_frequency
Must be initialized by the user before the device creation.
◆ install_irq
bool(* sc16is752_context::install_irq) (sc16is752_context *ctx)
◆ last_close
void(* sc16is752_context::last_close) (sc16is752_context *ctx)
Last close.
Internal handler.
◆ lcr
uint8_t sc16is752_context::lcr
Internal variable.
◆ mode
sc16is752_mode sc16is752_context::mode
Device mode.
◆ read_2_reg
int(* sc16is752_context::read_2_reg) (sc16is752_context *ctx, uint8_t addr_0, uint8_t addr_1, uint8_t data[2])
Internal handler.
◆ read_reg
int(* sc16is752_context::read_reg) (sc16is752_context *ctx, uint8_t addr, uint8_t *data, size_t len)
Reads a register.
Internal handler.
◆ remove_irq
void(* sc16is752_context::remove_irq) (sc16is752_context *ctx)
◆ tty
rtems_termios_tty* sc16is752_context::tty
Internal variable.
◆ tx_fifo_free
uint8_t sc16is752_context::tx_fifo_free
Internal variable.
◆ tx_in_progress
uint8_t sc16is752_context::tx_in_progress
Internal variable.
◆ write_reg
int(* sc16is752_context::write_reg) (sc16is752_context *ctx, uint8_t addr, const uint8_t *data, size_t len)
Writes a register.
Internal handler.
