RTEMS  5.1
rtems_rtl_obj_sect Struct Reference
#include <rtl-obj.h>
rtems_chain_node node
int section
const char * name
size_t size
off_t offset
uint32_t alignment
int link
int info
uint32_t flags
void * base
int load_order
An object file is made up of sections and the can be more than one of a specific type of sections. All sections and grouped together in memory.
Field Documentation
◆ alignment
uint32_t rtems_rtl_obj_sect::alignment
Alignment of this section.
◆ base
void* rtems_rtl_obj_sect::base
The base address of the section in memory.
◆ flags
uint32_t rtems_rtl_obj_sect::flags
The section's flags.
◆ info
int rtems_rtl_obj_sect::info
Secfion info field.
◆ link
int rtems_rtl_obj_sect::link
Section link field.
◆ load_order
int rtems_rtl_obj_sect::load_order
Order we load sections.
◆ name
const char* rtems_rtl_obj_sect::name
The section's name.
◆ node
rtems_chain_node rtems_rtl_obj_sect::node
The node's link in the chain.
◆ offset
off_t rtems_rtl_obj_sect::offset
Offset into the object file. Relative to the start of the object file.
◆ section
int rtems_rtl_obj_sect::section
The section number.
◆ size
size_t rtems_rtl_obj_sect::size
The size of the section in memory.
