RTEMS  5.1
rtems_rfs_block_pos_s Struct Reference
#include <rtems-rfs-block-pos.h>
rtems_rfs_block_no bno
rtems_rfs_block_off boff
rtems_rfs_block_no block
A block position is a block number times the block size plus the offset. The block field can be used hold a block number for the position as a look up cache.
Field Documentation
◆ block
rtems_rfs_block_no rtems_rfs_block_pos_s::block
The block number that the bpos + boff map to. The 0 value is invalid and means no block number has been set.
◆ bno
rtems_rfs_block_no rtems_rfs_block_pos_s::bno
The block index in the map. Range is from 0 to the maps block count minus 1.
◆ boff
rtems_rfs_block_off rtems_rfs_block_pos_s::boff
The offset into the block. Must be less than the block size.
