RTEMS  5.1
rtems_rate_monotonic_period_statistics Struct Reference
#include <ratemon.h>
uint32_t count
uint32_t missed_count
struct timespec min_cpu_time
struct timespec max_cpu_time
struct timespec total_cpu_time
struct timespec min_wall_time
struct timespec max_wall_time
struct timespec total_wall_time
The following defines the PUBLIC data structure that has the statistics kept on each period instance.
Note
The public structure uses struct timespec while the internal one uses Timestamp_Control.
Field Documentation
◆ count
uint32_t rtems_rate_monotonic_period_statistics::count
This field contains the number of periods executed.
◆ max_cpu_time
struct timespec rtems_rate_monotonic_period_statistics::max_cpu_time
This field contains the highest amount of CPU time used in a period.
◆ max_wall_time
struct timespec rtems_rate_monotonic_period_statistics::max_wall_time
This field contains the highest amount of wall time used in a period.
◆ min_cpu_time
struct timespec rtems_rate_monotonic_period_statistics::min_cpu_time
This field contains the least amount of CPU time used in a period.
◆ min_wall_time
struct timespec rtems_rate_monotonic_period_statistics::min_wall_time
This field contains the least amount of wall time used in a period.
◆ missed_count
uint32_t rtems_rate_monotonic_period_statistics::missed_count
This field contains the number of periods missed.
◆ total_cpu_time
struct timespec rtems_rate_monotonic_period_statistics::total_cpu_time
This field contains the total amount of wall time used in a period.
◆ total_wall_time
struct timespec rtems_rate_monotonic_period_statistics::total_wall_time
This field contains the total amount of CPU time used in a period.
