RTEMS  5.1
Dual_ported_memory_Control Struct Reference
#include <dpmemdata.h>
Objects_Control Object
void * internal_base
void * external_base
uint32_t length
The following structure defines the port control block. Each port has a control block associated with it. This control block contains all information required to support the port related operations.
Field Documentation
◆ external_base
void* Dual_ported_memory_Control::external_base
This field is the base external address of the port.
◆ internal_base
void* Dual_ported_memory_Control::internal_base
This field is the base internal address of the port.
◆ length
uint32_t Dual_ported_memory_Control::length
This field is the length of dual-ported area of the port.
◆ Object
Objects_Control Dual_ported_memory_Control::Object
This field is the object management portion of a Port instance.
