RTEMS  5.1
sim.h
1
28 /*
29  * This file was created by John S. Gwynne to support Motorola's 68332 MCU.
30  *
31  * Redistribution and use in source and binary forms are permitted
32  * provided that the following conditions are met:
33  * 1. Redistribution of source code and documentation must retain
34  * the above authorship, this list of conditions and the
35  * following disclaimer.
36  * 2. The name of the author may not be used to endorse or promote
37  * products derived from this software without specific prior
38  * written permission.
39  *
40  * This software is provided "AS IS" without warranty of any kind,
41  * either expressed or implied, including, but not limited to, the
42  * implied warranties of merchantability, title and fitness for a
43  * particular purpose.
44  *
45  *------------------------------------------------------------------
46  */
47
48 #ifndef _RTEMS_M68K_SIM_H
49 #define _RTEMS_M68K_SIM_H
50
51
52 /* SAM-- shift and mask */
53 #undef SAM
54 #define SAM(a,b,c) ((a << b) & c)
55
56 /*
57  * These macros make this file usable from assembly.
58  */
59
60 #ifdef ASM
61 #define SIM_VOLATILE_USHORT_POINTER
62 #define SIM_VOLATILE_UCHAR_POINTER
63 #else
64 #define SIM_VOLATILE_USHORT_POINTER (volatile unsigned short int * const)
65 #define SIM_VOLATILE_UCHAR_POINTER (volatile unsigned char * const)
66 #endif
67
68 /* SIM_CRB (SIM Control Register Block) base address of the SIM
69  control registers */
70 #ifndef SIM_CRB
71 #if SIM_MM == 0
72 #define SIM_CRB 0x7ffa00
73 #else /* SIM_MM */
74 #undef SIM_MM
75 #define SIM_MM 1
76 #define SIM_CRB 0xfffa00
77 #endif /* SIM_MM */
78 #endif /* SIM_CRB */
79
80
81 #define SIMCR SIM_VOLATILE_USHORT_POINTER(0x00 + SIM_CRB)
82  /* Module Configuration Register */
83 #define EXOFF 0x8000 /* External Clock Off */
84 #define FRZSW 0x4000 /* Freeze Software Enable */
85 #define FRZBM 0x2000 /* Freeze Bus Monitor Enable */
86 #define SLVEN 0x0800 /* Factory Test Model Enabled (ro)*/
87 #define SHEN 0x0300 /* Show Cycle Enable */
88 #define SUPV 0x0080 /* Supervisor/Unrestricted Data Space */
89 #define MM 0x0040 /* Module Mapping */
90 #define IARB 0x000f /* Interrupt Arbitration Field */
91
92
93
94 #define SIMTR SIM_VOLATILE_USHORT_POINTER(0x02 + SIM_CRB)
95  /* SIM Test Register */
96 /* Used only for factor testing */
97
98
99
100 #define SYNCR SIM_VOLATILE_USHORT_POINTER(0x04 + SIM_CRB)
101  /* Clock Synthesizer Control Register */
102 #define VCO 0x8000 /* Frequency Control (VCO) */
103 #define PRESCALE 0x4000 /* Frequency Control Bit (Prescale) */
104 #define COUNTER 0x3f00 /* Frequency Control Counter */
105 #define EDIV 0x0080 /* ECLK Divide Rate */
106 #define SLIMP 0x0010 /* Limp Mode Status */
107 #define SLOCK 0x0008 /* Synthesizer Lock */
108 #define RSTEN 0x0004 /* Reset Enable */
109 #define STSIM 0x0002 /* Stop Mode SIM Clock */
110 #define STEXT 0x0001 /* Stop Mode External Clock */
111
112
113
114 #define RSR SIM_VOLATILE_UCHAR_POINTER(0x07 + SIM_CRB)
115  /* Reset Status Register */
116 #define EXT 0x0080 /* External Reset */
117 #define POW 0x0040 /* Power-On Reset */
118 #define SW 0x0020 /* Software Watchdog Reset */
119 #define DBF 0x0010 /* Double Bus Fault Reset */
120 #define LOC 0x0004 /* Loss of Clock Reset */
121 #define SYS 0x0002 /* System Reset */
122 #define TST 0x0001 /* Test Submodule Reset */
123
124
125
126 #define SIMTRE SIM_VOLATILE_USHORT_POINTER(0x08 + SIM_CRB)
127  /* System Integration Test Register */
128 /* Used only for factor testing */
129
130
131
132 #define PORTE0 SIM_VOLATILE_UCHAR_POINTER(0x11 + SIM_CRB)
133 #define PORTE1 SIM_VOLATILE_UCHAR_POINTER(0x13 + SIM_CRB)
134  /* Port E Data Register */
135 #define DDRE SIM_VOLATILE_UCHAR_POINTER(0x15 + SIM_CRB)
136  /* Port E Data Direction Register */
137 #define PEPAR SIM_VOLATILE_UCHAR_POINTER(0x17 + SIM_CRB)
138  /* Port E Pin Assignment Register */
139 /* Any bit cleared (zero) defines the corresponding pin to be an I/O
140  pin. Any bit set defines the corresponding pin to be a bus control
141  signal. */
142
143
144
145 #define PORTF0 SIM_VOLATILE_UCHAR_POINTER(0x19 + SIM_CRB)
146 #define PORTF1 SIM_VOLATILE_UCHAR_POINTER(0x1b + SIM_CRB)
147  /* Port F Data Register */
148 #define DDRF SIM_VOLATILE_UCHAR_POINTER(0x1d + SIM_CRB)
149  /* Port E Data Direction Register */
150 #define PFPAR SIM_VOLATILE_UCHAR_POINTER(0x1f + SIM_CRB)
151 /* Any bit cleared (zero) defines the corresponding pin to be an I/O
152  pin. Any bit set defines the corresponding pin to be a bus control
153  signal. */
154
155
156
157 #define SYPCR SIM_VOLATILE_UCHAR_POINTER(0x21 + SIM_CRB)
158 /* !!! can write to only once after reset !!! */
159  /* System Protection Control Register */
160 #define SWE 0x80 /* Software Watch Enable */
161 #define SWP 0x40 /* Software Watchdog Prescale */
162 #define SWT 0x30 /* Software Watchdog Timing */
163 #define HME 0x08 /* Halt Monitor Enable */
164 #define BME 0x04 /* Bus Monitor External Enable */
165 #define BMT 0x03 /* Bus Monitor Timing */
166
167
168
169 #define PICR SIM_VOLATILE_USHORT_POINTER(0x22 + SIM_CRB)
170  /* Periodic Interrupt Control Reg. */
171 #define PIRQL 0x0700 /* Periodic Interrupt Request Level */
172 #define PIV 0x00ff /* Periodic Interrupt Level */
173
174
175
176 #define PITR SIM_VOLATILE_USHORT_POINTER(0x24 + SIM_CRB)
177  /* Periodic Interrupt Timer Register */
178 #define PTP 0x0100 /* Periodic Timer Prescaler Control */
179 #define PITM 0x00ff /* Periodic Interrupt Timing Modulus */
180
181
182
183 #define SWSR SIM_VOLATILE_UCHAR_POINTER(0x27 + SIM_CRB)
184  /* Software Service Register */
185 /* write 0x55 then 0xaa to service the software watchdog */
186
187
188
189 #define TSTMSRA SIM_VOLATILE_USHORT_POINTER(0x30 + SIM_CRB)
190  /* Test Module Master Shift A */
191 #define TSTMSRB SIM_VOLATILE_USHORT_POINTER(0x32 + SIM_CRB)
192  /* Test Module Master Shift A */
193 #define TSTSC SIM_VOLATILE_USHORT_POINTER(0x34 + SIM_CRB)
194  /* Test Module Shift Count */
195 #define TSTRC SIM_VOLATILE_USHORT_POINTER(0x36 + SIM_CRB)
196  /* Test Module Repetition Counter */
197 #define CREG SIM_VOLATILE_USHORT_POINTER(0x38 + SIM_CRB)
198  /* Test Module Control */
199 #define DREG SIM_VOLATILE_USHORT_POINTER(0x3a + SIM_CRB)
200  /* Test Module Distributed */
201 /* Used only for factor testing */
202
203
204
205 #define PORTC SIM_VOLATILE_UCHAR_POINTER(0x41 + SIM_CRB)
206  /* Port C Data */
207
208
209
210 #define CSPAR0 SIM_VOLATILE_USHORT_POINTER(0x44 + SIM_CRB)
211  /* Chip Select Pin Assignment
212  Resgister 0 */
213 /* CSPAR0 contains seven two-bit fields that determine the functions
214  of corresponding chip-select pins. CSPAR0[15:14] are not
215  used. These bits always read zero; write have no effect. CSPAR0 bit
216  1 always reads one; writes to CSPAR0 bit 1 have no effect. */
217 #define CSPAR1 SIM_VOLATILE_USHORT_POINTER(0x46 + SIM_CRB)
218  /* Chip Select Pin Assignment
219  Register 1 */
220 /* CSPAR1 contains five two-bit fields that determine the finctions of
221  corresponding chip-select pins. CSPAR1[15:10] are not used. These
222  bits always read zero; writes have no effect. */
223 /*
224  *
225  * Bit Field | Description
226  * ------------+---------------
227  * 00 | Discrete Output
228  * 01 | Alternate Function
229  * 10 | Chip Select (8-bit port)
230  * 11 | Chip Select (16-bit port)
231  */
232 #define DisOut 0x0
233 #define AltFun 0x1
234 #define CS8bit 0x2
235 #define CS16bit 0x3
236 /*
237  *
238  * CSPARx Field |Chip Select Signal | Alternate Signal | Discrete Output
239  *-----------------+--------------------+--------------------+---------------*/
240 #define CS_5 12 /* !CS5 | FC2 | PC2 */
241 #define CS_4 10 /* !CS4 | FC1 | PC1 */
242 #define CS_3 8 /* !CS3 | FC0 | PC0 */
243 #define CS_2 6 /* !CS2 | !BGACK | */
244 #define CS_1 4 /* !CS1 | !BG | */
245 #define CS_0 2 /* !CS0 | !BR | */
246 #define CSBOOT 0 /* !CSBOOT | | */
247 /* | | | */
248 #define CS_10 8 /* !CS10 | ADDR23 | ECLK */
249 #define CS_9 6 /* !CS9 | ADDR22 | PC6 */
250 #define CS_8 4 /* !CS8 | ADDR21 | PC5 */
251 #define CS_7 2 /* !CS7 | ADDR20 | PC4 */
252 #define CS_6 0 /* !CS6 | ADDR19 | PC3 */
253
254 #define BS_2K 0x0
255 #define BS_8K 0x1
256 #define BS_16K 0x2
257 #define BS_64K 0x3
258 #define BS_128K 0x4
259 #define BS_256K 0x5
260 #define BS_512K 0x6
261 #define BS_1M 0x7
262
263 #define CSBARBT SIM_VOLATILE_USHORT_POINTER(0x48 + SIM_CRB)
264 #define CSBAR0 SIM_VOLATILE_USHORT_POINTER(0x4c + SIM_CRB)
265 #define CSBAR1 SIM_VOLATILE_USHORT_POINTER(0x50 + SIM_CRB)
266 #define CSBAR2 SIM_VOLATILE_USHORT_POINTER(0x54 + SIM_CRB)
267 #define CSBAR3 SIM_VOLATILE_USHORT_POINTER(0x58 + SIM_CRB)
268 #define CSBAR4 SIM_VOLATILE_USHORT_POINTER(0x5c + SIM_CRB)
269 #define CSBAR5 SIM_VOLATILE_USHORT_POINTER(0x60 + SIM_CRB)
270 #define CSBAR6 SIM_VOLATILE_USHORT_POINTER(0x64 + SIM_CRB)
271 #define CSBAR7 SIM_VOLATILE_USHORT_POINTER(0x68 + SIM_CRB)
272 #define CSBAR8 SIM_VOLATILE_USHORT_POINTER(0x6c + SIM_CRB)
273 #define CSBAR9 SIM_VOLATILE_USHORT_POINTER(0x70 + SIM_CRB)
274 #define CSBAR10 SIM_VOLATILE_USHORT_POINTER(0x74 + SIM_CRB)
275
276 #define MODE 0x8000
277 #define Disable 0
278 #define LowerByte 0x2000
279 #define UpperByte 0x4000
280 #define BothBytes 0x6000
281 #define ReadOnly 0x0800
282 #define WriteOnly 0x1000
283 #define ReadWrite 0x1800
284 #define SyncAS 0x0
285 #define SyncDS 0x0400
286
287 #define WaitStates_0 (0x0 << 6)
288 #define WaitStates_1 (0x1 << 6)
289 #define WaitStates_2 (0x2 << 6)
290 #define WaitStates_3 (0x3 << 6)
291 #define WaitStates_4 (0x4 << 6)
292 #define WaitStates_5 (0x5 << 6)
293 #define WaitStates_6 (0x6 << 6)
294 #define WaitStates_7 (0x7 << 6)
295 #define WaitStates_8 (0x8 << 6)
296 #define WaitStates_9 (0x9 << 6)
297 #define WaitStates_10 (0xa << 6)
298 #define WaitStates_11 (0xb << 6)
299 #define WaitStates_12 (0xc << 6)
300 #define WaitStates_13 (0xd << 6)
301 #define FastTerm (0xe << 6)
302 #define External (0xf << 6)
303
304 #define CPUSpace (0x0 << 4)
305 #define UserSpace (0x1 << 4)
306 #define SupSpace (0x2 << 4)
307 #define UserSupSpace (0x3 << 4)
308
309 #define IPLevel_any 0x0
310 #define IPLevel_1 0x2
311 #define IPLevel_2 0x4
312 #define IPLevel_3 0x6
313 #define IPLevel_4 0x8
314 #define IPLevel_5 0xa
315 #define IPLevel_6 0xc
316 #define IPLevel_7 0xe
317
318 #define AVEC 1
319
320 #define CSORBT SIM_VOLATILE_USHORT_POINTER(0x4a + SIM_CRB)
321 #define CSOR0 SIM_VOLATILE_USHORT_POINTER(0x4e + SIM_CRB)
322 #define CSOR1 SIM_VOLATILE_USHORT_POINTER(0x52 + SIM_CRB)
323 #define CSOR2 SIM_VOLATILE_USHORT_POINTER(0x56 + SIM_CRB)
324 #define CSOR3 SIM_VOLATILE_USHORT_POINTER(0x5a + SIM_CRB)
325 #define CSOR4 SIM_VOLATILE_USHORT_POINTER(0x5e + SIM_CRB)
326 #define CSOR5 SIM_VOLATILE_USHORT_POINTER(0x62 + SIM_CRB)
327 #define CSOR6 SIM_VOLATILE_USHORT_POINTER(0x66 + SIM_CRB)
328 #define CSOR7 SIM_VOLATILE_USHORT_POINTER(0x6a + SIM_CRB)
329 #define CSOR8 SIM_VOLATILE_USHORT_POINTER(0x6e + SIM_CRB)
330 #define CSOR9 SIM_VOLATILE_USHORT_POINTER(0x72 + SIM_CRB)
331 #define CSOR10 SIM_VOLATILE_USHORT_POINTER(0x76 + SIM_CRB)
332
333 #endif /* _RTEMS_M68K_SIM_H */
