#define | SAM(a, b, c) ((a << b) & c) |
#define | SIM_VOLATILE_USHORT_POINTER (volatile unsigned short int * const) |
#define | SIM_VOLATILE_UCHAR_POINTER (volatile unsigned char * const) |
#define | SIM_CRB 0x7ffa00 |
#define | SIMCR SIM_VOLATILE_USHORT_POINTER(0x00 + SIM_CRB) |
#define | EXOFF 0x8000 /* External Clock Off */ |
#define | FRZSW 0x4000 /* Freeze Software Enable */ |
#define | FRZBM 0x2000 /* Freeze Bus Monitor Enable */ |
#define | SLVEN 0x0800 /* Factory Test Model Enabled (ro)*/ |
#define | SHEN 0x0300 /* Show Cycle Enable */ |
#define | SUPV 0x0080 /* Supervisor/Unrestricted Data Space */ |
#define | MM 0x0040 /* Module Mapping */ |
#define | IARB 0x000f /* Interrupt Arbitration Field */ |
#define | SIMTR SIM_VOLATILE_USHORT_POINTER(0x02 + SIM_CRB) |
#define | SYNCR SIM_VOLATILE_USHORT_POINTER(0x04 + SIM_CRB) |
#define | VCO 0x8000 /* Frequency Control (VCO) */ |
#define | PRESCALE 0x4000 /* Frequency Control Bit (Prescale) */ |
#define | COUNTER 0x3f00 /* Frequency Control Counter */ |
#define | EDIV 0x0080 /* ECLK Divide Rate */ |
#define | SLIMP 0x0010 /* Limp Mode Status */ |
#define | SLOCK 0x0008 /* Synthesizer Lock */ |
#define | RSTEN 0x0004 /* Reset Enable */ |
#define | STSIM 0x0002 /* Stop Mode SIM Clock */ |
#define | STEXT 0x0001 /* Stop Mode External Clock */ |
#define | RSR SIM_VOLATILE_UCHAR_POINTER(0x07 + SIM_CRB) |
#define | EXT 0x0080 /* External Reset */ |
#define | POW 0x0040 /* Power-On Reset */ |
#define | SW 0x0020 /* Software Watchdog Reset */ |
#define | DBF 0x0010 /* Double Bus Fault Reset */ |
#define | LOC 0x0004 /* Loss of Clock Reset */ |
#define | SYS 0x0002 /* System Reset */ |
#define | TST 0x0001 /* Test Submodule Reset */ |
#define | SIMTRE SIM_VOLATILE_USHORT_POINTER(0x08 + SIM_CRB) |
#define | PORTE0 SIM_VOLATILE_UCHAR_POINTER(0x11 + SIM_CRB) |
#define | PORTE1 SIM_VOLATILE_UCHAR_POINTER(0x13 + SIM_CRB) |
#define | DDRE SIM_VOLATILE_UCHAR_POINTER(0x15 + SIM_CRB) |
#define | PEPAR SIM_VOLATILE_UCHAR_POINTER(0x17 + SIM_CRB) |
#define | PORTF0 SIM_VOLATILE_UCHAR_POINTER(0x19 + SIM_CRB) |
#define | PORTF1 SIM_VOLATILE_UCHAR_POINTER(0x1b + SIM_CRB) |
#define | DDRF SIM_VOLATILE_UCHAR_POINTER(0x1d + SIM_CRB) |
#define | PFPAR SIM_VOLATILE_UCHAR_POINTER(0x1f + SIM_CRB) |
#define | SYPCR SIM_VOLATILE_UCHAR_POINTER(0x21 + SIM_CRB) |
#define | SWE 0x80 /* Software Watch Enable */ |
#define | SWP 0x40 /* Software Watchdog Prescale */ |
#define | SWT 0x30 /* Software Watchdog Timing */ |
#define | HME 0x08 /* Halt Monitor Enable */ |
#define | BME 0x04 /* Bus Monitor External Enable */ |
#define | BMT 0x03 /* Bus Monitor Timing */ |
#define | PICR SIM_VOLATILE_USHORT_POINTER(0x22 + SIM_CRB) |
#define | PIRQL 0x0700 /* Periodic Interrupt Request Level */ |
#define | PIV 0x00ff /* Periodic Interrupt Level */ |
#define | PITR SIM_VOLATILE_USHORT_POINTER(0x24 + SIM_CRB) |
#define | PTP 0x0100 /* Periodic Timer Prescaler Control */ |
#define | PITM 0x00ff /* Periodic Interrupt Timing Modulus */ |
#define | SWSR SIM_VOLATILE_UCHAR_POINTER(0x27 + SIM_CRB) |
#define | TSTMSRA SIM_VOLATILE_USHORT_POINTER(0x30 + SIM_CRB) |
#define | TSTMSRB SIM_VOLATILE_USHORT_POINTER(0x32 + SIM_CRB) |
#define | TSTSC SIM_VOLATILE_USHORT_POINTER(0x34 + SIM_CRB) |
#define | TSTRC SIM_VOLATILE_USHORT_POINTER(0x36 + SIM_CRB) |
#define | CREG SIM_VOLATILE_USHORT_POINTER(0x38 + SIM_CRB) |
#define | DREG SIM_VOLATILE_USHORT_POINTER(0x3a + SIM_CRB) |
#define | PORTC SIM_VOLATILE_UCHAR_POINTER(0x41 + SIM_CRB) |
#define | CSPAR0 SIM_VOLATILE_USHORT_POINTER(0x44 + SIM_CRB) |
#define | CSPAR1 SIM_VOLATILE_USHORT_POINTER(0x46 + SIM_CRB) |
#define | DisOut 0x0 |
#define | AltFun 0x1 |
#define | CS8bit 0x2 |
#define | CS16bit 0x3 |
#define | CS_5 12 /* !CS5 | FC2 | PC2 */ |
#define | CS_4 10 /* !CS4 | FC1 | PC1 */ |
#define | CS_3 8 /* !CS3 | FC0 | PC0 */ |
#define | CS_2 6 /* !CS2 | !BGACK | */ |
#define | CS_1 4 /* !CS1 | !BG | */ |
#define | CS_0 2 /* !CS0 | !BR | */ |
#define | CSBOOT 0 /* !CSBOOT | | */ |
#define | CS_10 8 /* !CS10 | ADDR23 | ECLK */ |
#define | CS_9 6 /* !CS9 | ADDR22 | PC6 */ |
#define | CS_8 4 /* !CS8 | ADDR21 | PC5 */ |
#define | CS_7 2 /* !CS7 | ADDR20 | PC4 */ |
#define | CS_6 0 /* !CS6 | ADDR19 | PC3 */ |
#define | BS_2K 0x0 |
#define | BS_8K 0x1 |
#define | BS_16K 0x2 |
#define | BS_64K 0x3 |
#define | BS_128K 0x4 |
#define | BS_256K 0x5 |
#define | BS_512K 0x6 |
#define | BS_1M 0x7 |
#define | CSBARBT SIM_VOLATILE_USHORT_POINTER(0x48 + SIM_CRB) |
#define | CSBAR0 SIM_VOLATILE_USHORT_POINTER(0x4c + SIM_CRB) |
#define | CSBAR1 SIM_VOLATILE_USHORT_POINTER(0x50 + SIM_CRB) |
#define | CSBAR2 SIM_VOLATILE_USHORT_POINTER(0x54 + SIM_CRB) |
#define | CSBAR3 SIM_VOLATILE_USHORT_POINTER(0x58 + SIM_CRB) |
#define | CSBAR4 SIM_VOLATILE_USHORT_POINTER(0x5c + SIM_CRB) |
#define | CSBAR5 SIM_VOLATILE_USHORT_POINTER(0x60 + SIM_CRB) |
#define | CSBAR6 SIM_VOLATILE_USHORT_POINTER(0x64 + SIM_CRB) |
#define | CSBAR7 SIM_VOLATILE_USHORT_POINTER(0x68 + SIM_CRB) |
#define | CSBAR8 SIM_VOLATILE_USHORT_POINTER(0x6c + SIM_CRB) |
#define | CSBAR9 SIM_VOLATILE_USHORT_POINTER(0x70 + SIM_CRB) |
#define | CSBAR10 SIM_VOLATILE_USHORT_POINTER(0x74 + SIM_CRB) |
#define | MODE 0x8000 |
#define | Disable 0 |
#define | LowerByte 0x2000 |
#define | UpperByte 0x4000 |
#define | BothBytes 0x6000 |
#define | ReadOnly 0x0800 |
#define | WriteOnly 0x1000 |
#define | ReadWrite 0x1800 |
#define | SyncAS 0x0 |
#define | SyncDS 0x0400 |
#define | WaitStates_0 (0x0 << 6) |
#define | WaitStates_1 (0x1 << 6) |
#define | WaitStates_2 (0x2 << 6) |
#define | WaitStates_3 (0x3 << 6) |
#define | WaitStates_4 (0x4 << 6) |
#define | WaitStates_5 (0x5 << 6) |
#define | WaitStates_6 (0x6 << 6) |
#define | WaitStates_7 (0x7 << 6) |
#define | WaitStates_8 (0x8 << 6) |
#define | WaitStates_9 (0x9 << 6) |
#define | WaitStates_10 (0xa << 6) |
#define | WaitStates_11 (0xb << 6) |
#define | WaitStates_12 (0xc << 6) |
#define | WaitStates_13 (0xd << 6) |
#define | FastTerm (0xe << 6) |
#define | External (0xf << 6) |
#define | CPUSpace (0x0 << 4) |
#define | UserSpace (0x1 << 4) |
#define | SupSpace (0x2 << 4) |
#define | UserSupSpace (0x3 << 4) |
#define | IPLevel_any 0x0 |
#define | IPLevel_1 0x2 |
#define | IPLevel_2 0x4 |
#define | IPLevel_3 0x6 |
#define | IPLevel_4 0x8 |
#define | IPLevel_5 0xa |
#define | IPLevel_6 0xc |
#define | IPLevel_7 0xe |
#define | AVEC 1 |
#define | CSORBT SIM_VOLATILE_USHORT_POINTER(0x4a + SIM_CRB) |
#define | CSOR0 SIM_VOLATILE_USHORT_POINTER(0x4e + SIM_CRB) |
#define | CSOR1 SIM_VOLATILE_USHORT_POINTER(0x52 + SIM_CRB) |
#define | CSOR2 SIM_VOLATILE_USHORT_POINTER(0x56 + SIM_CRB) |
#define | CSOR3 SIM_VOLATILE_USHORT_POINTER(0x5a + SIM_CRB) |
#define | CSOR4 SIM_VOLATILE_USHORT_POINTER(0x5e + SIM_CRB) |
#define | CSOR5 SIM_VOLATILE_USHORT_POINTER(0x62 + SIM_CRB) |
#define | CSOR6 SIM_VOLATILE_USHORT_POINTER(0x66 + SIM_CRB) |
#define | CSOR7 SIM_VOLATILE_USHORT_POINTER(0x6a + SIM_CRB) |
#define | CSOR8 SIM_VOLATILE_USHORT_POINTER(0x6e + SIM_CRB) |
#define | CSOR9 SIM_VOLATILE_USHORT_POINTER(0x72 + SIM_CRB) |
#define | CSOR10 SIM_VOLATILE_USHORT_POINTER(0x76 + SIM_CRB) |
