RTEMS
5.1
Internal Support for POSIX Shared Memory. More...
struct | POSIX_Shm_Object |
Encapsulation for the storage and manipulation of shm objects. More... | |
struct | POSIX_Shm_Object_operations |
Operations on POSIX Shared Memory Objects. More... | |
struct | POSIX_Shm_Control |
Control for a POSIX Shared Memory Object. More... | |
#define | POSIX_SHM_INFORMATION_DEFINE(max) |
Macro to define the objects information for the POSIX Shared Memory objects. More... | |
Typedefs | |
typedef struct POSIX_Shm_Object_operations | POSIX_Shm_Object_operations |
int | _POSIX_Shm_Object_create_from_workspace (POSIX_Shm_Object *shm_obj, size_t size) |
object_create operation for shm objects stored in RTEMS Workspace. | |
int | _POSIX_Shm_Object_delete_from_workspace (POSIX_Shm_Object *shm_obj) |
object_delete operation for shm objects stored in RTEMS Workspace. | |
int | _POSIX_Shm_Object_resize_from_workspace (POSIX_Shm_Object *shm_obj, size_t size) |
object_resize operation for shm objects stored in RTEMS Workspace. | |
int | _POSIX_Shm_Object_read_from_workspace (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
object_read operation for shm objects stored in RTEMS Workspace. | |
void * | _POSIX_Shm_Object_mmap_from_workspace (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
object_mmap operation for shm objects stored in RTEMS Workspace. | |
int | _POSIX_Shm_Object_create_from_heap (POSIX_Shm_Object *shm_obj, size_t size) |
object_create operation for shm objects stored in C program heap. | |
int | _POSIX_Shm_Object_delete_from_heap (POSIX_Shm_Object *shm_obj) |
object_delete operation for shm objects stored in C program heap. | |
int | _POSIX_Shm_Object_resize_from_heap (POSIX_Shm_Object *shm_obj, size_t size) |
object_resize operation for shm objects stored in C program heap. | |
int | _POSIX_Shm_Object_read_from_heap (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
object_read operation for shm objects stored in C program heap. | |
void * | _POSIX_Shm_Object_mmap_from_heap (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
object_mmap operation for shm objects stored in C program heap. | |
const POSIX_Shm_Object_operations | _POSIX_Shm_Object_operations |
Objects_Information | _POSIX_Shm_Information |
The POSIX Shared Memory objects information. | |
