RTEMS  5.1
schedulernodeimpl.h
1
9 /*
10  * Copyright (c) 2014, 2017 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _RTEMS_SCORE_SCHEDULERNODEIMPL_H
24 #define _RTEMS_SCORE_SCHEDULERNODEIMPL_H
25
28
35 struct _Scheduler_Control;
36
37 #ifdef __cplusplus
38 extern "C" {
39 #endif /* __cplusplus */
40
41 #define SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE( node ) \
42  RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority.Node.Node.Chain )
43
44 #define SCHEDULER_NODE_OF_WAIT_PRIORITY( node ) \
45  RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority )
46
51 #define SCHEDULER_PRIORITY_APPEND_FLAG 1
52
56 #define SCHEDULER_PRIORITY_MAP( priority ) ( ( priority ) << 1 )
57
61 #define SCHEDULER_PRIORITY_UNMAP( priority ) ( ( priority ) >> 1 )
62
66 #define SCHEDULER_PRIORITY_PURIFY( priority ) \
67  ( ( priority ) & ~( (Priority_Control) SCHEDULER_PRIORITY_APPEND_FLAG ) )
68
72 #define SCHEDULER_PRIORITY_APPEND( priority ) \
73  ( ( priority ) | SCHEDULER_PRIORITY_APPEND_FLAG )
74
80 #define SCHEDULER_PRIORITY_IS_APPEND( priority ) \
81  ( ( ( priority ) & SCHEDULER_PRIORITY_APPEND_FLAG ) != 0 )
82
92  const struct _Scheduler_Control *scheduler,
93  Scheduler_Node *node,
94  Thread_Control *the_thread,
95  Priority_Control priority
96 )
97 {
98  node->owner = the_thread;
99
100  node->Priority.value = priority;
101
102 #if defined(RTEMS_SMP)
103  _Chain_Initialize_node( &node->Thread.Wait_node );
104  node->Wait.Priority.scheduler = scheduler;
105  node->user = the_thread;
106  node->idle = NULL;
107  _SMP_sequence_lock_Initialize( &node->Priority.Lock );
108 #else
109  (void) scheduler;
110  (void) the_thread;
111 #endif
112 }
113
122  const Scheduler_Node *node
123 )
124 {
125  return _Priority_Get_scheduler( &node->Wait.Priority );
126 }
127
136  const Scheduler_Node *node
137 )
138 {
139  return node->owner;
140 }
141
150  Scheduler_Node *node
151 )
152 {
153  Priority_Control priority;
154
155 #if defined(RTEMS_SMP)
156  unsigned int seq;
157
158  do {
159  seq = _SMP_sequence_lock_Read_begin( &node->Priority.Lock );
160 #endif
161
162  priority = node->Priority.value;
163
164 #if defined(RTEMS_SMP)
165  } while ( _SMP_sequence_lock_Read_retry( &node->Priority.Lock, seq ) );
166 #endif
167
168  return priority;
169 }
170
179  Scheduler_Node *node,
180  Priority_Control new_priority,
181  bool prepend_it
182 )
183 {
184 #if defined(RTEMS_SMP)
185  unsigned int seq;
186
187  seq = _SMP_sequence_lock_Write_begin( &node->Priority.Lock );
188 #endif
189
190  new_priority |= ( prepend_it ? 0 : SCHEDULER_PRIORITY_APPEND_FLAG );
191  node->Priority.value = new_priority;
192
193 #if defined(RTEMS_SMP)
194  _SMP_sequence_lock_Write_end( &node->Priority.Lock, seq );
195 #endif
196 }
197
198 #if defined(RTEMS_SMP)
199
206 RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Node_get_user(
207  const Scheduler_Node *node
208 )
209 {
210  return node->user;
211 }
212
219 RTEMS_INLINE_ROUTINE void _Scheduler_Node_set_user(
220  Scheduler_Node *node,
221  Thread_Control *user
222 )
223 {
224  node->user = user;
225 }
226
234 RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Node_get_idle(
235  const Scheduler_Node *node
236 )
237 {
238  return node->idle;
239 }
240 #endif
241
242 #ifdef __cplusplus
243 }
244 #endif /* __cplusplus */
245
248 #endif /* _RTEMS_SCORE_SCHEDULERNODEIMPL_H */
RTEMS_INLINE_ROUTINE Thread_Control * _Scheduler_Node_get_owner(const Scheduler_Node *node)
Gets the owner of the node.
Definition: schedulernodeimpl.h:135
RTEMS_INLINE_ROUTINE void _Scheduler_Node_set_priority(Scheduler_Node *node, Priority_Control new_priority, bool prepend_it)
Sets the priority of the node.
Definition: schedulernodeimpl.h:178
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node(Chain_Node *the_node)
Initializes a chain node.
Definition: chainimpl.h:122
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Scheduler_Node_get_scheduler(const Scheduler_Node *node)
Gets the scheduler of the node.
Definition: schedulernodeimpl.h:121
Priority Handler API Implementation.
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Priority_Get_scheduler(const Priority_Aggregation *aggregation)
Gets the priority aggregation's scheduler.
Definition: priorityimpl.h:284
RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_initialize(const struct _Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes a node.
Definition: schedulernodeimpl.h:91
RTEMS_INLINE_ROUTINE Priority_Control _Scheduler_Node_get_priority(Scheduler_Node *node)
Gets the priority of the node.
Definition: schedulernodeimpl.h:149
Definition: thread.h:732
Priority append indicator for the priority control used for the scheduler node priority.
Definition: schedulernodeimpl.h:51
struct _Thread_Control * owner
The thread owning this node.
Definition: schedulernode.h:123
Scheduler control.
Definition: scheduler.h:269
Scheduler node for per-thread data.
Definition: schedulernode.h:79
struct Scheduler_Node::@3980 Wait
Thread wait support block.
Handles Scheduler Nodes.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
