RTEMS
5.1
EDF SMP Scheduler Implementation. More...
void | _Scheduler_EDF_SMP_Initialize (const Scheduler_Control *scheduler) |
Initializes the context of the scheduler control. More... | |
void | _Scheduler_EDF_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
Initializes the node with the given priority. More... | |
void | _Scheduler_EDF_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
Blocks the thread. More... | |
void | _Scheduler_EDF_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
Unblocks the thread. More... | |
void | _Scheduler_EDF_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
Updates the priority of the node. More... | |
bool | _Scheduler_EDF_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
Asks for help operation. More... | |
void | _Scheduler_EDF_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
Reconsiders help operation. More... | |
void | _Scheduler_EDF_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
Withdraws node operation. More... | |
void | _Scheduler_EDF_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
Adds processor. More... | |
Thread_Control * | _Scheduler_EDF_SMP_Remove_processor (const Scheduler_Control *scheduler, Per_CPU_Control *cpu) |
Removes an idle thread from the given cpu. More... | |
void | _Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
Performs the yield of a thread. More... | |
void | _Scheduler_EDF_SMP_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, Per_CPU_Control *cpu) |
Starts an idle thread. More... | |
void | _Scheduler_EDF_SMP_Pin (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, struct Per_CPU_Control *cpu) |
Pin thread operation. More... | |
void | _Scheduler_EDF_SMP_Unpin (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, struct Per_CPU_Control *cpu) |
Unpin thread operation. More... | |
bool | _Scheduler_EDF_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, const Processor_mask *affinity) |
Checks if the processor set of the scheduler is the subset of the affinity set. More... | |
