RTEMS  5.1
Typedefs | Functions
rtl-unwind-dw2.h File Reference
RTEMS Run-Time Linker Unwind DWARF Support. More...
#include "rtl-elf.h"
typedef long rtems_rtl_elf_unwind_dw2_sleb128
typedef unsigned long rtems_rtl_elf_unwind_dw2_uleb128
bool rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj *obj, const char *name, uint32_t flags)
bool rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj *obj)
bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj *obj)
const uint8_t * rtems_rtl_elf_unwind_dw2_read_uleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_uleb128 *val)
const uint8_t * rtems_rtl_elf_unwind_dw2_read_sleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_sleb128 *val)
bool rtems_rtl_elf_unwind_dw2_relocate (const Elf_Addr *where, Elf_Word value, Elf_Word mask)
◆ rtems_rtl_elf_unwind_dw2_deregister()
bool rtems_rtl_elf_unwind_dw2_deregister ( const rtems_rtl_obj obj)
Architecture specific handler to remove an object file's unwind information from the base image.
Parameters
objThe object file.
Return values
trueThe unwind information has been deregistered.
falseThe unwind information could not be deregistered.
◆ rtems_rtl_elf_unwind_dw2_parse()
bool rtems_rtl_elf_unwind_dw2_parse ( const rtems_rtl_obj obj,
const char *  name,
uint32_t  flags
Architecture specific handler to check if a section contains exception handler data..
Parameters
objThe object file.
nameThe section's name.
uint32flags The object file's flags.
Return values
trueThe section contains unwind information.
falseThe section does not contain unwind information.
◆ rtems_rtl_elf_unwind_dw2_read_uleb128()
const uint8_t* rtems_rtl_elf_unwind_dw2_read_uleb128 ( const uint8_t *  data,
rtems_rtl_elf_unwind_dw2_uleb128 *  val
Read signed and unsigned LEB128 values.
◆ rtems_rtl_elf_unwind_dw2_register()
bool rtems_rtl_elf_unwind_dw2_register ( const rtems_rtl_obj obj)
Architecture specific handler to add an object file's unwind information to the base image.
Parameters
objThe object file.
Return values
trueThe unwind information has been registered.
falseThe unwind information could not be registered.
