RTEMS  5.1
rtl-shell.c File Reference
RTEMS Run-Time Link Editor Shell Commands. More...
#include <inttypes.h>
#include <sys/stat.h>
#include <regex.h>
#include <dlfcn.h>
#include <rtems/printer.h>
#include <rtems/rtl/rtl.h>
#include <rtems/rtl/rtl-archive.h>
#include <rtems/rtl/rtl-shell.h>
#include <rtems/rtl/rtl-trace.h>
#include "rtl-chain-iterator.h"
struct  rtems_rtl_shell_cmd
struct  rtems_rtl_obj_summary
struct  rtems_rtl_obj_print
struct  rtems_rtl_dep_data
#define SYM_DUPLICATE   (1 << ((8 * sizeof (size_t)) - 1))
#define CALL_ARG_COUNT   (4)
typedef int(* rtems_rtl_shell_handler) (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_list (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_sym (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_object (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_archive (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_call (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_command (int argc, char *argv[])
A simple RTL command to aid using the RTL.
Typedef Documentation
◆ rtems_rtl_shell_handler
The type of the shell handlers we have.
◆ rtems_rtl_shell_archive()
int rtems_rtl_shell_archive ( const rtems_printer printer,
int  argc,
char *  argv[]
Archive files.
◆ rtems_rtl_shell_call()
int rtems_rtl_shell_call ( const rtems_printer printer,
int  argc,
char *  argv[]
Call text symbol.
◆ rtems_rtl_shell_command()
int rtems_rtl_shell_command ( int  argc,
char *  argv[]
The RTL single shell command contains sub-commands.
Parameters
argcThe argument count.
argvArray of argument strings.
Return values
0No error.
Returns
int The exit code.
◆ rtems_rtl_shell_list()
int rtems_rtl_shell_list ( const rtems_printer printer,
int  argc,
char *  argv[]
List object files.
◆ rtems_rtl_shell_object()
int rtems_rtl_shell_object ( const rtems_printer printer,
int  argc,
char *  argv[]
Object files.
◆ rtems_rtl_shell_sym()
int rtems_rtl_shell_sym ( const rtems_printer printer,
int  argc,
char *  argv[]
Symbols.
