RTEMS
5.1
RTEMS Run-Time Link Editor. More...
#include <fcntl.h>
#include <inttypes.h>
#include <unistd.h>
#include <rtems/rtl/rtl.h>
#include "rtl-elf.h"
#include "rtl-error.h"
#include <rtems/rtl/rtl-trace.h>
#include "rtl-trampoline.h"
#include "rtl-unwind.h"
#include <rtems/rtl/rtl-unresolved.h>
struct | rtems_rtl_elf_reloc_data |
struct | rtems_rtl_elf_common_data |
struct | rtems_rtl_tramp_data |
#define | REL_R_OFFSET (0) |
#define | REL_R_INFO (1) |
#define | REL_R_ADDEND (2) |
#define | SEPARATED_PREFIX(_p) { _p, sizeof (_p) - 1 } |
Typedefs | |
typedef bool(* | rtems_rtl_elf_reloc_handler) (rtems_rtl_obj *obj, bool is_rela, void *relbuf, rtems_rtl_obj_sect *targetsect, rtems_rtl_obj_sym *symbol, Elf_Sym *sym, const char *symname, Elf_Word symvalue, bool resolved, void *data) |
typedef struct rtems_rtl_tramp_data | rtems_rtl_tramp_data |
bool | rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc *reloc, rtems_rtl_obj_sym *sym) |
bool | rtems_rtl_elf_file_check (rtems_rtl_obj *obj, int fd) |
bool | rtems_rtl_elf_file_load (rtems_rtl_obj *obj, int fd) |
bool | rtems_rtl_elf_file_unload (rtems_rtl_obj *obj) |
rtems_rtl_loader_format * | rtems_rtl_elf_file_sig (void) |
This is the RTL implementation.
#define REL_R_OFFSET (0) |
The offsets in the reloc words.
typedef bool(* rtems_rtl_elf_reloc_handler) (rtems_rtl_obj *obj, bool is_rela, void *relbuf, rtems_rtl_obj_sect *targetsect, rtems_rtl_obj_sym *symbol, Elf_Sym *sym, const char *symname, Elf_Word symvalue, bool resolved, void *data) |
Relocation worker routine.
typedef struct rtems_rtl_tramp_data rtems_rtl_tramp_data |
Struct to handle trampoline reloc recs in the unresolved table.
bool rtems_rtl_elf_file_check | ( | rtems_rtl_obj * | obj, |
int | fd | ||
The ELF format check handler.
obj | The object being checked. |
fd | The file descriptor. |
bool rtems_rtl_elf_file_load | ( | rtems_rtl_obj * | obj, |
int | fd | ||
The ELF format load handler.
obj | The object to load. |
rtems_rtl_loader_format* rtems_rtl_elf_file_sig | ( | void | ) |
The ELF format signature handler.
bool rtems_rtl_elf_file_unload | ( | rtems_rtl_obj * | obj | ) |
The ELF format unload handler.
obj | The object to unload. |
bool rtems_rtl_obj_relocate_unresolved | ( | rtems_rtl_unresolv_reloc * | reloc, |
rtems_rtl_obj_sym * | sym | ||
Relocate an object file's unresolved reference.
rec | The unresolved relocation record. |
sym | The unresolved relocation's referenced symbol. |
true | The object file record was relocated. |
false | The relocation failed. The RTL error is set. |
