void | rtems_rbtree_initialize (rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique) |
| Initialize a RBTree header. More...
RTEMS_INLINE_ROUTINE void | rtems_rbtree_initialize_empty (rtems_rbtree_control *the_rbtree) |
| Initialize this RBTree as Empty. More...
RTEMS_INLINE_ROUTINE void | rtems_rbtree_set_off_tree (rtems_rbtree_node *node) |
| Set off RBtree. More...
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_node_off_tree (const rtems_rbtree_node *node) |
| Is the Node off RBTree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_root (const rtems_rbtree_control *the_rbtree) |
| Return pointer to RBTree root. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_min (const rtems_rbtree_control *the_rbtree) |
| Returns the minimum node of the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_max (const rtems_rbtree_control *the_rbtree) |
| Returns the maximum node of the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_left (const rtems_rbtree_node *the_node) |
| Return pointer to the left child node from this node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_right (const rtems_rbtree_node *the_node) |
| Return pointer to the right child node from this node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_parent (const rtems_rbtree_node *the_node) |
| Returns a pointer to the parent of this node. More...
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_empty (const rtems_rbtree_control *the_rbtree) |
| Is the RBTree empty. More...
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_min (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node) |
| Is this the minimum node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_max (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node) |
| Is this the maximum node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_root (const rtems_rbtree_node *the_node) |
| Checks if this node is the root node of a red-black tree. More...
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_equal (rtems_rbtree_compare_result compare_result) |
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_greater (rtems_rbtree_compare_result compare_result) |
RTEMS_INLINE_ROUTINE bool | rtems_rbtree_is_lesser (rtems_rbtree_compare_result compare_result) |
rtems_rbtree_node * | rtems_rbtree_find (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique) |
| Tries to find a node for the specified key in the tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_predecessor (const rtems_rbtree_node *node) |
| Returns the predecessor of a node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_successor (const rtems_rbtree_node *node) |
| Returns the successor of a node. More...
RTEMS_INLINE_ROUTINE void | rtems_rbtree_extract (rtems_rbtree_control *the_rbtree, rtems_rbtree_node *the_node) |
| Extracts (removes) the node from the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_get_min (rtems_rbtree_control *the_rbtree) |
| Gets a node with the minimum key value from the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_get_max (rtems_rbtree_control *the_rbtree) |
| Gets a node with the maximal key value from the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_peek_min (const rtems_rbtree_control *the_rbtree) |
| Peek at the min node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * | rtems_rbtree_peek_max (const rtems_rbtree_control *the_rbtree) |
| Peek at the max node on a rbtree. More...
rtems_rbtree_node * | rtems_rbtree_insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, rtems_rbtree_compare compare, bool is_unique) |
| Inserts the node into the red-black tree. More...
