RTEMS  5.1
Data Structures | Typedefs | Functions
RTEMS File System Format. More...
#include <stddef.h>
#include <stdbool.h>
#include <stdint.h>
#include <rtems/rfs/rtems-rfs-trace.h>
struct  _rtems_rfs_format_config
typedef struct _rtems_rfs_format_config rtems_rfs_format_config
int rtems_rfs_format (const char *name, const rtems_rfs_format_config *config)
This function lets you format a disk in the RFS format.
Typedef Documentation
◆ rtems_rfs_format_config
RFS File System Configuration data used to format the file system. For default values leave the field set to 0.
◆ rtems_rfs_format()
int rtems_rfs_format ( const char *  name,
const rtems_rfs_format_config config
RFS Format command.
Parameters
[in]nameis the device name to format.
[in]configis a pointer to the configuration table.
Return values
-1Error. See errno.
0No error. Format successful.
