RTEMS  5.1
rtems-debugger-server.h
1 /*
2  * Copyright (c) 2016-2019 Chris Johns <chrisj@rtems.org>.
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  *
14  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24  * SUCH DAMAGE.
25  */
26
27 /*
28  * Debugger for RTEMS.
29  */
30
31 #ifndef _RTEMS_DEBUGGER_SERVER_h
32 #define _RTEMS_DEBUGGER_SERVER_h
33
34 #include <rtems.h>
35 #include <rtems/printer.h>
36
37 #include <rtems/rtems-debugger.h>
38
39 #ifdef __cplusplus
40 extern "C" {
41 #endif /* __cplusplus */
42
46 #define RTEMS_DEBUGGER_NUMOF(_d) (sizeof(_d) / sizeof(_d[0]))
47
51 #define DB_UINT uint32_t
52
53 /*
54  * Debugger signals.
55  */
56 #define RTEMS_DEBUGGER_SIGNAL_HUP 1 /* Hangup */
57 #define RTEMS_DEBUGGER_SIGNAL_INT 2 /* Interrupt */
58 #define RTEMS_DEBUGGER_SIGNAL_QUIT 3 /* Quit */
59 #define RTEMS_DEBUGGER_SIGNAL_ILL 4 /* Illegal instruction */
60 #define RTEMS_DEBUGGER_SIGNAL_TRAP 5 /* Trace/breakpoint trap */
61 #define RTEMS_DEBUGGER_SIGNAL_ABRT 6 /* Aborted */
62 #define RTEMS_DEBUGGER_SIGNAL_EMT 7 /* Emulation trap */
63 #define RTEMS_DEBUGGER_SIGNAL_FPE 8 /* Arithmetic exception */
64 #define RTEMS_DEBUGGER_SIGNAL_KILL 9 /* Killed */
65 #define RTEMS_DEBUGGER_SIGNAL_BUS 10 /* Bus error */
66 #define RTEMS_DEBUGGER_SIGNAL_SEGV 11 /* Segmentation fault */
67 #define RTEMS_DEBUGGER_SIGNAL_SYS 12 /* Bad system call */
68 #define RTEMS_DEBUGGER_SIGNAL_PIPE 13 /* Broken pipe */
69 #define RTEMS_DEBUGGER_SIGNAL_ALRM 14 /* Alarm clock */
70 #define RTEMS_DEBUGGER_SIGNAL_TERM 15 /* Terminated */
71 #define RTEMS_DEBUGGER_SIGNAL_URG 16 /* Urgent I/O condition */
72 #define RTEMS_DEBUGGER_SIGNAL_STOP 17 /* Stopped (signal) */
73 #define RTEMS_DEBUGGER_SIGNAL_TSTP 18 /* Stopped (user) */
74 #define RTEMS_DEBUGGER_SIGNAL_CONT 19 /* Continued */
75
79 #define RTEMS_DEBUGGER_TIMEOUT_STOP (5 * 1000 * 1000)
80
84 #define RTEMS_DEBUGGER_POLL_WAIT (10000)
85
89 #define RTEMS_DEBUGGER_STACKSIZE (16 * 1024)
90
94 #define RTEMS_DEBUGGER_BUFFER_SIZE (4 * 1024)
95
99 #define RTEMS_DEBUGGER_FLAG_VERBOSE (1 << 0)
100 #define RTEMS_DEBUGGER_FLAG_RESET (1 << 1)
101 #define RTEMS_DEBUGGER_FLAG_NON_STOP (1 << 2)
102 #define RTEMS_DEBUGGER_FLAG_VCONT (1 << 3)
103 #define RTEMS_DEBUGGER_FLAG_MULTIPROCESS (1 << 4)
104 #define RTEMS_DEBUGGER_FLAG_VERBOSE_LOCK (1 << 5)
105 #define RTEMS_DEBUGGER_FLAG_VERBOSE_CMDS (1 << 6)
106
113
117 typedef struct _Condition_Control rtems_rx_cond;
118 typedef struct _Mutex_recursive_Control rtems_rx_mutex;
119
123 typedef struct
124 {
125  int port;
126  int timeout;
127  rtems_task_priority priority;
128  rtems_rx_mutex lock;
129  rtems_debugger_remote* remote;
130  rtems_id server_task;
131  rtems_rx_cond server_cond;
132  volatile bool server_running;
133  volatile bool server_finished;
134  rtems_id events_task;
135  volatile bool events_running;
136  volatile bool events_finished;
137  rtems_printer printer;
138  uint32_t flags;
139  pid_t pid;
140  bool remote_debug;
141  bool ack_pending;
142  size_t output_level;
143  uint8_t input[RTEMS_DEBUGGER_BUFFER_SIZE];
144  uint8_t output[RTEMS_DEBUGGER_BUFFER_SIZE];
145  rtems_debugger_threads* threads;
146  rtems_chain_control exception_threads;
147  int signal;
148  rtems_debugger_target* target;
150
154 extern rtems_debugger_server* rtems_debugger;
155
159 extern int rtems_debugger_printf(const char* format, ...) RTEMS_PRINTFLIKE(1, 2);
160 extern int rtems_debugger_clean_printf(const char* format, ...) RTEMS_PRINTFLIKE(1, 2);
161 extern void rtems_debugger_printk_lock(rtems_interrupt_lock_context* lock_context);
162 extern void rtems_debugger_printk_unlock(rtems_interrupt_lock_context* lock_context);
163
167 extern void rtems_debugger_lock(void);
168
172 extern void rtems_debugger_unlock(void);
173
177 extern bool rtems_debugger_server_running(void);
178
182 extern void rtems_debugger_server_crash(void);
183
187 extern rtems_debugger_remote* rtems_debugger_remote_handle(void);
188
192 extern bool rtems_debugger_connected(void);
193
197 extern bool rtems_debugger_server_events_running(void);
198
202 extern void rtems_debugger_server_events_signal(void);
203
207 extern bool rtems_debugger_verbose(void);
208
212 static inline bool rtems_debugger_server_flag(uint32_t mask)
213 {
214  return (rtems_debugger->flags & mask) != 0;
215 }
216
217 #ifdef __cplusplus
218 }
219 #endif /* __cplusplus */
220
221
222 #endif
Definition: rtems-debugger-server.h:123
Definition: mknod-pack_dev.c:254
Definition: chain.h:86
Definition: printer.h:55
#define RTEMS_PRINTFLIKE(_format_pos, _ap_pos)
Tells the compiler that this function expects printf()-like arguments.
Definition: basedefs.h:249
Definition: rtems-debugger-remote.h:44
Definition: rtems-debugger-target.h:93
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
User print interface to the bspIO print plug in.
Definition: rtems-debugger-threads.h:112
uint32_t rtems_task_priority
Definition: tasks.h:55
